Old Nov 06, 2007, 04:05 PM
shschon's Avatar
United States, CA, SF
Joined Aug 2004
Originally Posted by SHELBY1
How to eliminate the wobble on the spinners, at least how I did it.
The 2410-9Y motors have long shafts on them. What I did was cut them down and install prop adapters. The backplate on the Dubros was drilled just enough to clear the first step on the back of the prop adapter. So when it is installed it seats on the back of the prop adapter. Assembly goes something like this. Backplate, prop adapter body, prop, prop adapter nut, spinner nosecone, spinner screws.
This way the prop is on tight, and the backplate and spinner are centered and tight on the prop and adapter. Just watch when you tighten the mount screws on the nosecone. If you go too far on one of them they can tend to jamb and not allow the nose cone to seat correctly on the backplate. Hence a wobble.
Also check to be sure the adapter isn't riding on one of the prop blades. If it is the nose cone won't seat fully and you get the wobble.
Thanks a lot for long and detailed answer. However I am not asking about 3rd party spinners I have no problem with them. My issue is specific with the thin stock spinner that comes with the kit. They are too thin and soft by itself to be secured reliable by collet prop adaptor.
shschon is offline Find More Posts by shschon
Old Nov 06, 2007, 08:21 PM
Palo Alto, CA, USA
Joined Nov 2000
I used the clear plastic spacer in front of the three bladed prop mounted with a small washer to distribute the load. I then cut the openings for the three bladed prop such that the actual nose cone is supported by the spacer and the three blade roots. I mounted with two scrws per instructons. I skipped the ply back plate and the ply washer. The hardest part in mounting the cowlings and the spinners is to get a sharp (new) 1/16 drill bit to make the holes accurately. One of my spinners is slightly off due to this but it is easy to redo.
kasra is online now Find More Posts by kasra
Old Nov 07, 2007, 10:29 AM
diligentia vis celeritas
gunracer's Avatar
Corona, CA
Joined Feb 2006
Originally Posted by kasra
...The hardest part in mounting the cowlings and the spinners is to get a sharp (new) 1/16 drill bit to make the holes accurately. One of my spinners is slightly off due to this but it is easy to redo.
for making small holes in plastic, i use a hot t pin held in small vice grips...
gunracer is offline Find More Posts by gunracer
Old Nov 07, 2007, 01:43 PM
I hate waiting for parts
Mike_Then's Avatar
Rocky Mount, NC
Joined Apr 2001
Maybe this is what I need. I've destroyed two Nitroplanes P-38's in the last year, both to tipstalling. The last one was on its 3rd flight and it augered in from about 40 ft. I want another P-38 and not only does this one look great, you can't beat the price since it comes with motors, ESC, and wiring. An easy hand-launch I'm assuming, for those that left off the landing gear?
Mike_Then is offline Find More Posts by Mike_Then
Latest blog entry: Chaos 600 ESP build
Old Nov 08, 2007, 02:31 AM
Palo Alto, CA, USA
Joined Nov 2000
The hand launch is very easy and the plane also slows down well without tip stalling.
Gunracer, Thanks for that tip.
Kasra
Old Nov 08, 2007, 09:32 AM
ekotil's Avatar
Athens, Texas, United States
Joined Jul 2004
P-38 on sale!
New Creations R/C has it on sale and in stock. I got mine yesterday. Call Kirk Massey at 936-856-4630.
ekotil is offline Find More Posts by ekotil
Old Nov 10, 2007, 10:40 PM
LuckyDuc's Avatar
Formerly Denver. Now West Bend, WI
Joined Dec 2005
I'm in the process of building my kit and had a few questions. Nice kit BTW
I'm missing one of the plastic canopy hooks that attach to the canopy/rubber band. It wasn't in the kit
Seeing that the piece is missing... what other solutions have people used to attach the canopy? I was considering canopy magnets, but not sure how to fit them
Also, I don't want to use velcro to secure the turbo charger covers. It looks too loose. Do they need to be removeable? I might just attach them with a couple of dabs of foam safe CA. Any reason to not just glue them in place?
LuckyDuc is offline Find More Posts by LuckyDuc
Old Nov 11, 2007, 01:33 AM
Palo Alto, CA, USA
Joined Nov 2000
I used velcro on the canopy mainly to allow some room for the battery pack to get some air. I have found the battery pack does not get that warm anyways so I am not sure this was necessary. I used velcro on the pod covers also. I think CA should work fine. I like to have access for inspection. PM me your address and I can mail the hooks to you.
Kasra
Old Nov 11, 2007, 01:39 AM
Joined Dec 2006
Duc,
A servo horn works out the problem.
Devilic Angel is offline Find More Posts by Devilic Angel
Old Nov 11, 2007, 02:34 AM
Palo Alto, CA, USA
Joined Nov 2000
Originally Posted by Devilic Angel
Duc,
And looks nicer in the process
Kasra
Old Nov 11, 2007, 11:43 AM
gunracer's Avatar
Corona, CA
Joined Feb 2006
screw down the turbo charger covers for a tighter fit...
http://www.rcgroups.com/forums/showp...&postcount=395
Old Nov 11, 2007, 02:56 PM
LuckyDuc's Avatar
Joined Dec 2005
Kasra
Thanks for the offer, but I think I'll try the servo horn trick as I have plenty laying around the work bench.
Old Nov 11, 2007, 02:57 PM
LuckyDuc's Avatar
Joined Dec 2005
Thanks for the tip
Old Nov 11, 2007, 05:55 PM
Dert Farmur
Harv's Avatar
Saskatchewan
Joined Jan 2005
Another trigger pulled on this one. I've been trying to decide on my next Alfa warbird purchase, but after some issues with HL and seeing this I think it's time to expand my horizons to another manufacturer.
Only 2 Q's...will HS-55's work? And is mixing the two motors for pseudo rudders effective and/or recommended?
Thanks for the great info on this model guys...it looks like a real sweetheart.
Harv is offline Find More Posts by Harv
Old Nov 11, 2007, 06:37 PM
latinflyer
latinflyer's Avatar
United States, CA, Milpitas
Joined Dec 2004
Well,
I think I miss alot since my last post; I have been flying formation with Kasra and let me tell u, at less you are flying like us u don't know what u missing.
It's a joy and fun to fly two P-38's it is completely different than other airplanes not to forget the scale look It is fast and can slow down also. I am very pleased with performance. I hope to keep flying with Kasra, very good pilot and comrad.
I will bring my camera again so we can shoot more pic in mid air.
Latinflyer.
latinflyer is offline Find More Posts by latinflyer
P-38 construction update..... jbrundt Scale Electric Planes 21 Jan 17, 2008 04:31 PM
What's the best P-38 kit out there? slowflyer Scale Electric Planes 20 May 14, 2002 07:33 PM
I need a website with P-38 pictures GregG Scale Electric Planes 3 Sep 11, 2001 11:09 PM
Got my P-38, retracts or no? slowflyer Scale Electric Planes 15 Jul 27, 2001 10:10 PM
So which plane to train with, before the P-38? slowflyer Scale Electric Planes 9 May 23, 2001 10:13 PM
