Old Nov 05, 2007, 10:05 PM
Matt Halton is offline
Find More Posts by Matt Halton
Wannabe B-26 pilot!
Matt Halton's Avatar
Southwold, Suffolk, UK.
Joined Nov 2002
Where did you get the 3 blade spinners to use with FSK 3 blade props?
Yes please,me too,all help gratefully received
Matt Halton is offline Find More Posts by Matt Halton
Old Nov 06, 2007, 03:11 AM
kasra is online now
Find More Posts by kasra
Palo Alto, CA, USA
Joined Nov 2000
I used the stock spinners with extra cutouts. Shelby suggested using Dubro spinners but my plane is already nose heavy and the stock spinners are very light. I left out the plywood pieces as well. In fact, I left out a lot of parts
kasra is online now Find More Posts by kasra
Latest blog entry: Car Show
Old Nov 06, 2007, 03:31 AM
shschon is offline
Find More Posts by shschon
shschon's Avatar
United States, CA, SF
Joined Aug 2004
I wonder how you can install the spinner without the plywood reinforcement. I tried it and it wobbles.
The P-38 is prone to nose heavy as all the heavy parts are at the front (2 motors) and not much room to move the battery backward. Real P-38 require counter weight at the tail for balance as well.
shschon is offline Find More Posts by shschon
Old Nov 06, 2007, 09:11 AM
Wannabe B-26 pilot!
Joined Nov 2002
kasra-can you list the bits you left out please?
I'm wondering too how you got the spinners on without wobble..Another great in flight pic, awesome looker with 3 bladers!
Old Nov 06, 2007, 09:17 AM
LuckyDuc is offline
Find More Posts by LuckyDuc
LuckyDuc's Avatar
Formerly Denver. Now West Bend, WI
Joined Dec 2005
I couldn't resist.
Mine should be here Sat.
LuckyDuc is offline Find More Posts by LuckyDuc
Old Nov 06, 2007, 09:20 AM
Wannabe B-26 pilot!
Joined Nov 2002
You won't regret it!
This kit just pee's over the competition.
Old Nov 06, 2007, 09:32 AM
LuckyDuc is offline
LuckyDuc's Avatar
Joined Dec 2005
What servos are people using?
Old Nov 06, 2007, 10:14 AM
beafraid8 is offline
Find More Posts by beafraid8
Mom says I'm special...
beafraid8's Avatar
Aurora, CO
Joined Apr 2003
HS-55's!!
beafraid8 is offline Find More Posts by beafraid8
Old Nov 06, 2007, 10:16 AM
LuckyDuc is offline
LuckyDuc's Avatar
Joined Dec 2005
Originally Posted by beafraid8
HS-55's!!
No way. Never again
Old Nov 06, 2007, 11:17 AM
SHELBY1 is offline
Find More Posts by SHELBY1
It's me Glacier Girl
Joined Aug 2004
How to eliminate the wobble on the spinners, at least how I did it.
The 2410-9Y motors have long shafts on them. What I did was cut them down and install prop adapters. The backplate on the Dubros was drilled just enough to clear the first step on the back of the prop adapter. So when it is installed it seats on the back of the prop adapter. Assembly goes something like this. Backplate, prop adapter body, prop, prop adapter nut, spinner nosecone, spinner screws.
This way the prop is on tight, and the backplate and spinner are centered and tight on the prop and adapter. Just watch when you tighten the mount screws on the nosecone. If you go too far on one of them they can tend to jamb and not allow the nose cone to seat correctly on the backplate. Hence a wobble.
Also check to be sure the adapter isn't riding on one of the prop blades. If it is the nose cone won't seat fully and you get the wobble.
SHELBY1 is offline Find More Posts by SHELBY1
Old Nov 06, 2007, 11:36 AM
LuckyDuc is offline
LuckyDuc's Avatar
Joined Dec 2005
What props come with the kit? 8x6, 9x6?
Old Nov 06, 2007, 11:51 AM
LuckyDuc is offline
LuckyDuc's Avatar
Joined Dec 2005
Thanks for the description.
What adapters did you use? (size, manuf.)
Old Nov 06, 2007, 12:57 PM
gunracer is offline
Find More Posts by gunracer
diligentia vis celeritas
gunracer's Avatar
Corona, CA
Joined Feb 2006
8.5x8s...
gunracer is offline Find More Posts by gunracer
Old Nov 06, 2007, 02:32 PM
SHELBY1 is offline
Joined Aug 2004
Lucky,
From MPI, Maxx Products inc.
http://www.maxxprod.com/mpi/mpi-291....op.%20Adapters
ACC 364, 374, or 356 would work
Old Nov 06, 2007, 03:26 PM
LuckyDuc is offline
LuckyDuc's Avatar
Joined Dec 2005
Thanks for the replies.
P-38 construction update..... jbrundt Scale Kit/Scratch Built 21 Jan 17, 2008 04:31 PM
What's the best P-38 kit out there? slowflyer Scale Kit/Scratch Built 20 May 14, 2002 07:33 PM
I need a website with P-38 pictures GregG Scale Kit/Scratch Built 3 Sep 11, 2001 11:09 PM
Got my P-38, retracts or no? slowflyer Scale Kit/Scratch Built 15 Jul 27, 2001 10:10 PM
So which plane to train with, before the P-38? slowflyer Scale Kit/Scratch Built 9 May 23, 2001 10:13 PM
