Old Oct 27, 2007, 02:18 AM
Ginger Adam is offline
Find More Posts by Ginger Adam
I'm Ginger & called Adam
Ginger Adam's Avatar
Hereford, UK
Joined Oct 2002
Question
Headspeed from video footage?
Can the headspead of a chopper be worked out from video (actually the audio channel) of a flight - either filmed from the ground or onboard footage?
Adam
Ginger Adam is offline Find More Posts by Ginger Adam
Old Oct 27, 2007, 02:56 AM
DarkHorse is offline
Find More Posts by DarkHorse
0 Carbon fp? don't breed!
DarkHorse's Avatar
www.dhrc.rchomepage.com Gloucester/Cheltenham Gloucester, Great Britain (UK)
If the motor, gear and paddle noise doesn't cloud the audio too much. Yes if you can filter out the noise to reveal a clear fat low frequency sine wave of the main rotor. Then you can measure the number of samples or time taken for 2 cycles and work out the RPM (using an audio editor program).
DarkHorse is offline Find More Posts by DarkHorse
Old Oct 27, 2007, 03:30 AM
Hereford, UK
Joined Oct 2002
KISS principle - I hadn't thought of that ! I was thinking a bit of software (like that used to measure aircraft speed by doppler) but you're right about simply viewing the wave in an editor.
I'll give it a go and see how clear it looks.
Maths check - 1600 rpm would be about 53Hz (assuming I get a 'beat' from both blades)?
Adam
Old Oct 27, 2007, 09:11 AM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
I have been told with video at around 30 fps the rotors will looked "stopped" about every 900 rpm.
This shows in a couple videos I have of a Raven with a 1800 HS, the blades seem stationary much of the time.
FB
Fred Bronk is offline Find More Posts by Fred Bronk
Still picture taken from video Canada Goose Aerial Photography 1 Aug 17, 2004 06:34 AM
Sloper Wing video footage? asmokindeal Flying Wings 2 May 31, 2004 12:31 PM
Yippee! My first pic from the video camera on my helicopter. WRONO Aerial Photography 3 Feb 26, 2004 03:16 AM
Video footage of S&B Komets in Combat Jeremy_D Foamies (Kits) 4 Feb 04, 2003 05:31 PM
Combat Video Footage darenm Aerial Photography 7 Dec 28, 2002 05:27 PM
