Old Dec 08, 2002, 02:01 PM
J Morgan is offline
Find More Posts by J Morgan
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
CG on an old CL/FF plan
I've built a all blue foam Cessna L-19 from an old Berkeley 1953 Controline/Free Flight plan.
WS: 38.5 " From extended ACE tapered foam wing
Avg Chord: 4 1/2", Middle section 5 1/2"
WA: approx 180 sq. in.
Length: 25"
DX-A with 9-7 prop
AUW with 6-270 ni-cads is 10.2 oz( heavier than I wanted)
Problem: Before I hand launch this beast, I'm a little worried about the CG. The plan shows the CL cg @ 1 1/4" from leading edge ( 23%) and Free Flight @ 2 3/8" from leading edge (43%)
The original plan had a LIFTING stab so I know i can't use the free flight number and the CL seems a too forward.
Should I start at about 30% and hope for the best or what?
Any help would be appreciated, your guess is probably better than mine.
J Morgan is offline Find More Posts by J Morgan
Old Dec 08, 2002, 02:23 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
I built that plane, when it was first released as a kit way back when.
I don't recall the specifics, but it fly as a free-flight. Cub .049 power.
A 30% c.g. is probably OK. Don't overdo the elevator travel.
Sparky Paul is offline Find More Posts by Sparky Paul
Old Dec 08, 2002, 06:36 PM
J Morgan is offline
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Thanks Sparky, that's what I thought would be a logical approach. I knew I couldn't use the FF CG, I didn't put a lifting stab on it. You're right, Iit was powered by OK Cub .049 or Thimble-Drome .049.
Old Dec 20, 2002, 09:29 PM
J Morgan is offline
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Well, started with a DX-a and CG @ 30%. Kept elevator travel at 1/2" both directions.
First attemt at flight:
Gentle toss and could tell right off it was a little underpowered and it was wallowing from side to side. To far aft on the CG!
Aborted flight and as soon as I tried to level the wings with rudder, tip stalled into the ground. Only from about 5 feet so no damage other than a little tear in the foam around the landing gear wire.
Replaced the DX-a with a M100. Decided to run on 6 cells to minimize weight. Moved the CG to the C/L position which is 23% of wing chord. Little worried about being too far forward but tried it anyway.
Second attempt: Man, this M100 is strong. Rev up and gentle toss. Climbed straight ahead and gain altitude. Flew like it was on rails. First attempt to turn, WOW! Forgot to reduce the rudder throws like I did the elevator. Very carefully turned and did a few circuits. Then scared to land. But it is a happy ending. Landed just fine and now off to the paint shop to detail her. And reduce the rudder movement!
Sparky Paul,
Thanks for the help on reducing the throws. I'm sure it saved me alot of pain.
Plane in a tree - new ideas on an old problem! jdpowell22 Beginner Training Area (Aircraft-Electric) 31 Aug 28, 2013 11:11 PM
CG on an old 3m eclipse wrmbrnr Thermal 0 Jun 25, 2005 06:51 PM
CG on an L-39 wing! BandDButton Electric Ducted Fan Jet Talk 11 Mar 31, 2004 08:48 PM
New 3D twist on an old idea... Bill K. 3D Flying 4 Dec 22, 2003 11:40 PM
Identifying ABC vs Ring on an old OS ? grot Engines 3 Oct 31, 2003 10:02 AM
