Espritmodel.com Heli Air
Old Apr 23, 2001, 06:44 PM
Tork it or Dork it
Ryan Nau's Avatar
Elizabethville,PA USA
Joined Jul 2000
Upgrade for Pico Jet Combat
I am happy with the way my Pico Jet Combat flies and does areobatics but would like a little more verticle. I am using a Permax 480, Gunther 5-4 prop, and 8x800ar.
I was thinking about going to a Permax 450 Turbo and staying with the 8x800ar. Would the 450 fit in the motor mount with the rudder on right? Would the AreoNaut 6.5-4 prop be good for it? Did anybody ever try the 450 turbo, how did you like it in the Pico?
Ryan Nau is offline Find More Posts by Ryan Nau
Old Apr 24, 2001, 05:24 AM
JP
Portugal
Joined Mar 2001
I think you just need a prop change. Go to a Graupner 5,5x4,3 or a 6x4 and you will have another plane in your hand.
I like Gunther props, but their are not the best, just the cheapest.
JP
Lisbon,PORTUGAL
JP is offline Find More Posts by JP
Old Apr 24, 2001, 02:42 PM
Kyri's Avatar
England
Joined May 2000
Graupner speed 480BB race has adjustable timing, so if you time it for backwards running and use a APC 5.7x3 prop on the 8x800AR pack you will get awesome performance. I used this setup, and it was my favourite combination. I tried all the other props, 4.7x4.7, 6x4, 5.4x4.3 etc but the 5.7x3 was the best with this motor and battery.
Kyri is offline Find More Posts by Kyri
Old Apr 24, 2001, 04:01 PM
LJH
Moths do not fly inverted
LJH's Avatar
Greenwich CT.
Joined Sep 2000
Kyri,
I have used a SP480BB race but I found the duration un-acceptable. What kind of AMP draw did you get out of the 480 Race and the mentioned prop. I was seeing way over 20 AMP's with a Cox 6X3 (don't rememeber the exact #) I finally broke down and ordered a 4014 Colbolt motor. Should have it on Thursday and should be able to try it out over the weekend. Will let you know.
Cheers,
Jim
LJH is offline Find More Posts by LJH
Old Apr 24, 2001, 07:03 PM
Memphis, IN, USA
Joined Jan 2001
I have ordered the permax 450 turbo, I will be using 8x800ar and a grish 6x4 pusher.
I will let you guys know how it flies!
glovesave39 is offline Find More Posts by glovesave39
Whats the best speed controller for a pico jet combat? Jeremy_D Foamies (Kits) 2 Apr 22, 2002 04:10 AM
New Videos for Wingo and Pico Jet Combat Patrick Plawner Foamies (Kits) 0 Apr 19, 2002 04:54 PM
Pico Jet Combat for flying Combat motor full speed Patrick Plawner Foamies (Kits) 1 Nov 28, 2001 08:31 AM
Motor/Prop for Pico Jet Combat sgil2001 Foamies (Kits) 2 Oct 08, 2001 07:09 AM
Any suggestions for my new Pico Jet Combat? windsurfer Foamies (Kits) 5 May 07, 2001 03:27 PM
