Old Dec 08, 2002, 10:11 AM
Paul Penney is offline
Find More Posts by Paul Penney
Senior Member
Paul Penney's Avatar
Ancaster, Ontario, Canada
Joined Nov 2000
Can Kokams be charged with ANY cell phone charger?
Hey,
I was just wondering if this was possible. I already have a charger and would like to not have to ordr in another
Paul
Paul Penney is offline Find More Posts by Paul Penney
Old Dec 08, 2002, 10:19 AM
SoaringDragon is offline
Find More Posts by SoaringDragon
SoaringDragon's Avatar
New Hampshire
Joined Feb 2002
I also have a 110v charger that came with my Audiovox cell phone. I bought a 12v charger but I'd like to use my 110v one, if I can.
SoaringDragon is offline Find More Posts by SoaringDragon
Old Dec 09, 2002, 08:57 PM
Senior Member
Joined Nov 2000
*bump*
Surely Tres might have something to say?
Old Dec 09, 2002, 09:08 PM
Peter Khor is offline
Find More Posts by Peter Khor
Peter Khor's Avatar
Mostly in Norman, OK
Joined May 2002
Probably not, most of the time, all of the charge control circuit is in the phone itself - the phone charger is a simple A/C adaptor. If it's one of those external charger that will charge a battery pack alone, it might - there will probably be a 3rd pin for the temp probe in the battery pack itself, so without that in a Kokam, the charger might not begin the charge process. Same goes with Camcoder chargers.
Peter Khor is offline Find More Posts by Peter Khor
Old Dec 09, 2002, 09:11 PM
KnifeEdge51 is offline
Find More Posts by KnifeEdge51
central AZ
Joined May 2002
I'd be really interested to know as well. I'm hoping to get a flight pack for Xmas with a few Kokams (145mah) and I can't afford to push out $70+ for a charger. That amount of money might be justified if the charger works with ALL current chemistries, but even then that's quite a handfull of money. Anything that would help would be highly appreciated! Thanks!
Nick R.
KnifeEdge51 is offline Find More Posts by KnifeEdge51
Old Dec 09, 2002, 09:14 PM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
I figured someone else would field this one, so I skipped it...
Simple answer, NO.
Real answer, IT DEPENDS.
If the charger is designed for Lithium cells, then PROBABLY will work. Check the output voltage without anything connected (open) except the voltmeter. If the voltage is 4.0-4.2v, it MIGHT be setup for a single cell. If it's 8.0-8.4v, it MIGHT be set up for a 2 cell.
Now, connect a load of about 1 amp at rated voltage, say 4-5 ohms or 8-10 ohms, and measure the voltage and current. The voltage should sag and the current should be proportional (V/ohms). Now try half the resistance. The current shouldn't go up any more to speak of, since it should be limited to about 600-900mA, based on the intended cells.
The max current you read will tell wether you can use the charger for what size cells. The cells should not be charged at > MAH capacity... ie: 570mah cells, charge max at 570ma...
Clear?
Gene Bond is offline Find More Posts by Gene Bond
Old Dec 09, 2002, 11:37 PM
Sparr is offline
Find More Posts by Sparr
Crashmaster Extraordinair
Clarksville, TN
Joined Apr 2002
there are options with reasonable prices. I currently use the 1-3 cell charger from flyifo but it doesnt like charging partially-discharged cells.
1-3 cell, 100-1000mA charger from FlyIFO.com for $49
2 cell 200mA charger from FlyIFO.com for $24
1-2 cell ???mA charger from FlyIFO.com for $27
1 cell, 140mA charger from Bob Selman for $25
does-everything (nicad, nimh, li-ion) charger for $83
Sparr is offline Find More Posts by Sparr
Old Dec 10, 2002, 12:16 AM
ls77 is offline
Find More Posts by ls77
Former bpp dude
Joined Oct 2001
I stock a surplus cell phone charger that works very well on two cell packs. Output is set at 750ma. You can probably find other surplus cell phone chargers out there that will work, you have to be very careful though as if you overcharge a Kokam pack, things get ugly fast.
-Troy
ls77 is offline Find More Posts by ls77
Old Dec 10, 2002, 06:04 AM
New Hampshire
Joined Feb 2002
That's the one I'm using now, with no problems. I'd just like to use my 110v one, so I'll take a look at the voltage & decide if I want to try using it, I guess.
Old Dec 10, 2002, 10:35 AM
frankenfoamy is offline
Find More Posts by frankenfoamy
Strange Plane Central
frankenfoamy's Avatar
Poway (near San Diego), CA US
Joined Dec 2000
I have two cell phone chargers for my cell phone. One charges the phone in on hour and the other takes 4 hours. So be aware there are differences.
Also, most current cell phone chargers are designed for one cell (4.2 volts)
The 145 mah cells would not appreciate a 750 mah charge.
Life of the cell would be affected.
A charger builder told me that these cells like a slow charge.
Fast charges fill the battery up to 80% at best and shorten thier life.
Hey Don't shoot me....I am just the messenger
http://rcguy.tripod.com/
frankenfoamy is offline Find More Posts by frankenfoamy
Old Dec 10, 2002, 09:59 PM
electroman is offline
Find More Posts by electroman
Gaithersburg, MD, USA
Joined Jun 2000
[QUOTE]Originally posted by frankenfoamy
Please open www.fmadirect.com Click on Support, then scroll down to AN000001 to read the Applications Note for Kokam LiPoly cells. there you will find theproper information on charging and all other aspects of the liPoly cells. The cells are normally charged ay 1C. Work done recently has it appear that we can charge at 2C without harming the cells. More about that later.
electroman is offline Find More Posts by electroman
Old Dec 11, 2002, 03:04 AM
Robbie d is offline
Find More Posts by Robbie d
Crazy Cessna Owner
Robbie d's Avatar
Australia, SA, Windsor Gardens
Joined May 2001
I know that the nokia phones have the charging circuit built into the phone, i recently switched from a nimh pack to li-ion and the same charger works for both
Robbie d is offline Find More Posts by Robbie d
Help with cell phone charger! splatman Life, The Universe, and Politics 4 Dec 15, 2004 05:46 AM
Can QC830's be charged with out the pcb? jra111 Batteries and Chargers 2 Mar 31, 2003 02:36 PM
Kontronik ESC's-- Can they be used for any dual brushless? Clayton Power Systems 1 Feb 01, 2003 12:00 AM
Can Hitec be buddyed with Futaba? D W Radios 6 Nov 24, 2002 11:36 AM
Cell phone charger Tipsy_WA Batteries and Chargers 3 Oct 29, 2002 09:17 AM
