This thread is privately moderated by GWS CHEN, who may elect to delete unwanted replies.
Old Jan 27, 2008, 02:33 PM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Jason,
GWS and UHU glues are both contact cements. Are you using them correctly? You must apply to one side, press both sides together briefly, then pull apart and let air dry for 10 minutes. Both sides should still be slightly tacky after drying, then press together tightly. I've glued fuses together using these cements correctly, and couldn't pull them apart 30 minutes later.
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Jan 27, 2008, 03:06 PM
jamesdr is offline
Find More Posts by jamesdr
Unrepentant Carnivore
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
Originally Posted by crxmanpat
Jim,
Did I mention my dad lives in Riverview right off the I-75 on 301? I'm visiting him soon. Where do you fly, I'll bring my camera!
Pat
Sarasota Silent Flyers - just down the road in Parrish. But it is "No Camera with Pat" Club.
Concur with the GWS glue. Used correctly (Pat explained it properly) the stuff will be stronger than foam.
Jim
jamesdr is offline Find More Posts by jamesdr
Old Jan 27, 2008, 04:46 PM
FresnoJay is offline
Find More Posts by FresnoJay
To drive or to fly......BOTH!!
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
I used the UHU to put the halves together after posting the question. I use the UHU in my scratch Panther build and it impressed me so I went with it. I am guessing that the GWS glue is similair to UHU? Previous to using the UHU in the panther build I had only used Epoxy to join fuse sections or any section under large strains. I think I am now pretty much hooked on UHU now as its so simple and alot less messy to use.
Ok now for the pics of my work to this point. Enjoy.
Jason
FresnoJay is offline Find More Posts by FresnoJay
Old Jan 27, 2008, 06:25 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
I find that UHU (I use Creativ, pretty much the same as Por) tends to set up a little quicker than GWS glue. I can let it set about 5 minutes and then it's ready to go. But GWS glue works wonders if used correctly, and comes in the kits (I have about 10 tubes of it right now). UHU is about $7 a pack.
Pat
Old Jan 27, 2008, 06:34 PM
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
I happened to have an unopened bottle of Creative UHU which is what I am going to use on the entire plane. I will use the trick with the GWS glue on the next model and give it a go.
Jason
Old Jan 27, 2008, 07:10 PM
AirWarriorBelgy is offline
Find More Posts by AirWarriorBelgy
Captain Carnage says......
AirWarriorBelgy's Avatar
Seminole (St Pete.), Florida/ Seminole Crash Fest
Joined Jun 2002
GWS is a 3M Contact Cement product
and if you want immediate results here is what I do with it
I use the cheapie 'rubber glue type" paint brushes to spread the contact cement out as thinly as possible (ya'll know the kind..metal tube handle cheap black bristles, cost 15 cents each at the LHS)
1) spread each halve of the assembly as thin as possible and I mean thin
2) by the time the second half is coated the first half should be dry to the touch (Contact cements should be dry to the touch to bond quickly and properly)
3) Let the second half sit for as long as the first half did
4) carefully align your two halves and press together
5) clean the brush out with alcohol.. denatured or Isopropyl (rubbing) and hey..15 cents is 15 cents
5) read about your next steps if it includes that assembly
6) Continue with assembly
a)If you use this method you will get an instant bond that is dry...
b)If you use this method you will get very little realignment time
c)If you use this method you don't get the stringy, stretchy, hairs of glue pull that fall all over the finished surface
its always light weight and bulletproof
Chuck
AirWarriorBelgy is offline Find More Posts by AirWarriorBelgy
Old Jan 27, 2008, 07:33 PM
jamesdr is offline
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
But don't use #M Contact Cement. That stuff is not foam safe. Trust me.
Jim
Old Jan 27, 2008, 08:49 PM
GWS4CEO is offline
Find More Posts by GWS4CEO
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
GWS glue is a 3M foam safe Contact Cement product
GWS glue is a 3M foam safe Contact Cement product!
Not a no name cheap clones glue.
GWS4CEO is offline Find More Posts by GWS4CEO
Old Jan 28, 2008, 04:44 AM
Joined Jun 2002
Jim
Too True!!!
but 3M does make a Foamsafe version As Mr. Lin indicates
if you go way back in the threads from about 5 yrs ago we were using it. It came in a Spray canand was somewhat available at Home Depots, Lowes, Hechingers...etc.
but they sold two types Foam safe and regular..it was 77M or something like that...at HD supply it was in the paint section with the other adhesives.
Chuck
Old Jan 28, 2008, 05:03 AM
camship is offline
Find More Posts by camship
Resistance is Futile
camship's Avatar
United States, FL, Panama City Beach
Joined Oct 2001
Too True!!!
Chuck
77M, I bought a bunch of cans...still have two left....NOTE, I can not vouch for 3M 77M spray adhesive as being foam-safe in it's currently distributed form. Do a test FIRST. Do TWO TESTS!
Hey, just caught this on the J-10 thread...Thanks Chen.
Nose gear for our planes.....
http://www.gwsus.com/english/product...gear_rg-mn.htm
It can be used on electrical R/C airplane at the full weight (AUW) of less than 1000g(35.33 oz), the best retract nose gear for GWS-38, GWS-262, GWS-15, GWS-A4, GWS-J10.
I note it seems to be specifically designed for these larger GWS planes and rated to 35 oz., .....
camship
camship is offline Find More Posts by camship
Old Jan 28, 2008, 12:02 PM
THREEWING is offline
Find More Posts by THREEWING
Dam Dutch Fokker.
USA, UT, Farmington
Joined Jul 2003
I just got off the phone with Terry a Darehobbies. They have a lot of armament missiles ,smart bombs ,and Jet drop tanks . The Drop tanks are not on their web site Stock # 1035-4 is 11" X 1-1/4" and 1035-5 is 13.75"X1.875" $ 7.95 each and $ 8.95 each .Call Terry at Dare Hobbies 1-800-578-3273
THREEWING is offline Find More Posts by THREEWING
Old Jan 28, 2008, 09:00 PM
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
Ok got the fuse seam sanded and looking good. Fan unit installed along with the ESC. Also got the wing blocks installed, tail feathers assembled and dry fitted.
Got some test munbers after getting the power system installed.
Single Loong Max 3s 2250 20c
34A +/-
high 300W range
around 588 grams of thrust installed sticker on fan stated 600 grams
Pics later.
Jason
Old Jan 29, 2008, 01:39 PM
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
Ok pics of work done recently. Taking a day off from building today for family time. Check back in later gents.
Jason
Old Jan 30, 2008, 08:55 AM
GWS4CEO is offline
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
You guys always ask me when will the GWS new airplanes come?
But, I will ask you guys: When will you finished and Take GWS airplanes?
GWS EDF Jet Trainer flies! steve neill Parkflyers 19 Jul 09, 2010 01:04 PM
GWS EDF Jet Trainer flies! steve neill Electric Ducted Fan Jet Talk 61 Jul 02, 2010 01:39 AM
Discussion GWS 262 EDF Jet GWS4CEO Foamy EDFs 14 Aug 03, 2008 08:28 AM
Looking for picture of new GWS EDF Jet ipjodan GWS (Grand Wing Servo) 8 Sep 17, 2005 01:13 AM
For Sale FS A-6 A-10 F-4 B-2 EDF Jet Fighter Bomber ARF RTF shschon Aircraft - Electric - Airplanes (FS/W) 12 Aug 09, 2005 02:18 AM
