This thread is privately moderated by GWS CHEN, who may elect to delete unwanted replies.
Old Oct 30, 2007, 08:02 PM
UH-1H is offline
Find More Posts by UH-1H
Sky shepherd
UH-1H's Avatar
Singapore
Joined Dec 2005
Yeah any videos of the A-4 in action? Maybe some napalm drops?..
UH-1H is offline Find More Posts by UH-1H
Old Oct 30, 2007, 09:20 PM
GWS CHEN is offline
Find More Posts by GWS CHEN
Taipei, Taiwan
Joined Oct 2005
MidNiteCM,
I'm afraid that the nose retract would take more days, as my colleagues at GWS China are working more at GWS-A4.
Chen
GWS CHEN is offline Find More Posts by GWS CHEN
Old Oct 31, 2007, 02:52 AM
MidNiteCM is offline
Find More Posts by MidNiteCM
Private Pilot (Training)
Joined Oct 2007
OK, thank you GWS CHEN for the reply. Looking forward to your new products.
MidNiteCM is offline Find More Posts by MidNiteCM
Old Nov 01, 2007, 12:25 PM
GWS4CEO is offline
Find More Posts by GWS4CEO
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
The space of retract already served.
When the nose retrect has being done, you can get GWS retract landing gears set to add on!
This should not be too far, I am tracking GWS RD on this subject to be completed ASAP.
Since, we will need multi thousnads of this for GWS JETs!
GWS4CEO is offline Find More Posts by GWS4CEO
Old Nov 01, 2007, 12:43 PM
nsg is offline
nsg
Find More Posts by nsg
nsg
Yardley, PA
Joined Sep 2006
Mr. Lin - any intent to do rotate/fold back retracts (Corsair, A4..)?
nsg is offline Find More Posts by nsg
Old Nov 01, 2007, 12:55 PM
GWS4CEO is offline
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
Yes, but too many projects need to be finished...
Old Nov 01, 2007, 02:02 PM
The Bandit is offline
Find More Posts by The Bandit
The art of Crashing
Joined Dec 2006
Yes! Yes! Yes! Finally someone will fill in that void! Please make them sturdy enough to handle at least 2.5lbs. My corsair and P40 have been waiting for these.
The Bandit is offline Find More Posts by The Bandit
Old Nov 01, 2007, 07:09 PM
Draven is offline
Find More Posts by Draven
Infinite Zenith
Draven's Avatar
United States, TX, Arlington
Joined Sep 2006
Hi Mr.Lin, what other power system do you recommend to fly the A-4 at slower speeds? Probably a lighter Weight system?
Draven is offline Find More Posts by Draven
Old Nov 01, 2007, 07:27 PM
FresnoJay is offline
Find More Posts by FresnoJay
To drive or to fly......BOTH!!
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
Mr.Lin or Chen, When can the early birds start ordering? Now?
Jason
FresnoJay is offline Find More Posts by FresnoJay
Old Nov 01, 2007, 11:08 PM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
Watching the video reminds me of the sapac hawk in stock form. 600 grams thrust from a 75mm fan at 36 amps??
Hmm we get 600+ from the EDF64 right now at approx 18 amps with the GWS motors and 1300 4s1p packs.
An HET6904 fan with a 3W motor puts out almost a kilo of thrust at 35 amps on 4 cells and will run on 2200 4s1p 25c packs easily. This is the sort of setup I was expecting from the A4 considering is size.
Questions to GWS:
I would like to see the fan in this thread, someone from GWS should post up pictures of the fan, housing, motor etc.
Has the 4 blade rotor changed from the original EDF75 4 blade rotor??
Is the only change the 3mm shaft adapter??
Extreme_RC is offline Find More Posts by Extreme_RC
Old Nov 02, 2007, 02:29 AM
GWS CHEN is offline
Taipei, Taiwan
Joined Oct 2005
The video one was with the original 4-blade rotor of EDF75, I've been told that there'll be newly reinforced rotor coming with "D cut" inside of its hub. The 3mm adapter will certainly be with "D cut" at its end.
Chen
Old Nov 02, 2007, 04:32 AM
Extreme_RC's Avatar
Australia
Joined Mar 2006
Thanks Chen, so basically an original EDF75 4 blade with a bigger shaft adapter. 36 amps is very high dont you think? and 600g sounds low for this size fan running at almost 400 watts. What was the AUW of the model Tommy was flying?
Old Nov 02, 2007, 06:50 AM
GWS CHEN is offline
Taipei, Taiwan
Joined Oct 2005
AUW was 950 grams, there'd be the same air intake issue found on A-4. The thrust of 600 grams was measured when the EDF was on board. The EDF75 certainly works better in open space.
Enlarging both front ends of intake, and making the wing thinner
could make it faster. Tommy did not apply any cheat holes on it.
He said this GWS A-4 was stable in the air. I think that a thinner wing would add more airspeed, but the landing speed would be faster, and not stable any more.
Chen
Old Nov 02, 2007, 07:03 AM
UH-1H is offline
Sky shepherd
UH-1H's Avatar
Singapore
Joined Dec 2005
Any news on the decals?
Old Nov 02, 2007, 12:36 PM
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
Extreme, I was thinking of using the HET or similair Wemo fan unit if the 75's performance didn't work out to my liking. I looked at the thrust to weight numbers and wasn't impressed. I figured that I would give it a shot stock and then go from there. I fly another jet I have on a 12oz of thrust to 20oz AUW and it flies good but not really fast. The A-4 with the stock setup would fly in a pretty similair fashion power wise. The other jet by the way is getting a hotter setup in it now for more speed .
Jason
GWS EDF Jet Trainer flies! steve neill Parkflyers 19 Jul 09, 2010 01:04 PM
GWS EDF Jet Trainer flies! steve neill Electric Ducted Fan Jet Talk 61 Jul 02, 2010 01:39 AM
Discussion GWS 262 EDF Jet GWS4CEO Foamy EDFs 14 Aug 03, 2008 08:28 AM
Looking for picture of new GWS EDF Jet ipjodan GWS (Grand Wing Servo) 8 Sep 17, 2005 01:13 AM
For Sale FS A-6 A-10 F-4 B-2 EDF Jet Fighter Bomber ARF RTF shschon Aircraft - Electric - Airplanes (FS/W) 12 Aug 09, 2005 02:18 AM
