This thread is privately moderated by GWS CHEN, who may elect to delete unwanted replies.
Old Jul 04, 2009, 10:50 AM
JohnAsaPrice is offline
Find More Posts by JohnAsaPrice
JohnAsaPrice's Avatar
Joined Sep 2006
maiden launch - dead-stick landing - dead motor!
I purchased my A-4 from EPYAYA with the new red (version 2) motor.
I built with a large ESC and flew with good battery (4400 mah 3S)
Right in the middle of my first flight, the motor froze up!!!!
I was flying at 3/4 throttle at the time. About 3 mins into the flight.
Thankfully, GWS made a good airframe, and I was able to dead-stick it in for a safe landing. (okay, maybe I am a pretty good pilot too )
The motor with the kit came with no heat-sink, and none was shown in the instructions.
Was I supposed to put a heat-sink on the motor? Is this my fault?
Any suggestions for the motor replacement?
John Asa
JohnAsaPrice is offline Find More Posts by JohnAsaPrice
Old Jul 04, 2009, 11:06 AM
Joined Sep 2006
this is the Sierra Hotel pilot!
Here is the pilot that made the dead-stick landing!
My hand-carved pilots and RIO:
here is my all-american paint scheme (for the 4th of July maiden flight)
Old Jul 04, 2009, 01:20 PM
Joined Sep 2006
I did some searching online and can't find the GWS RED motor anywhere for a replacement. I would like to continue using the GWS fan.
So, can anyone recommend a drop-in replacement for the motor with 3mm shaft? I'm using 3S batteries.
I would really like to stay under $75.00 if possible.
thanks
John Asa
Old Jul 04, 2009, 09:04 PM
jamesdr is offline
Find More Posts by jamesdr
Unrepentant Carnivore
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
John
Congrats on the recovery! The airfame is a winner - the motor and fan - well, it's a crap shoot. I've not had any issues with mine BUT I seem to be in the minority . Don't know of drop in replacement BUT if you check the foamy EDF forums, you will find something there.
Jim
jamesdr is offline Find More Posts by jamesdr
Old Jul 04, 2009, 09:54 PM
FresnoJay is offline
Find More Posts by FresnoJay
To drive or to fly......BOTH!!
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
Everything you have ever wanted to see or do to a GWS A-4 is probably covered in this thread. They are not GWS approved so they are not covered in tis thread . There is even a 2Kw setup that is currently in my Scooter, But again not GWS approved.
link: http://www.rcgroups.com/forums/showthread.php?t=826052
Jason
FresnoJay is offline Find More Posts by FresnoJay
Old Jul 05, 2009, 06:47 AM
GWS CHEN is offline
Find More Posts by GWS CHEN
Taipei, Taiwan
Joined Oct 2005
thanks
John Asa
Hi John,
Sorry to know the problem you met. Using a heat sink on the motor could be better. My colleagues in GWS Taiwan applied 2200mAh 3S 25C Lipo with the same motor. Probably this motor drew far more Amps from this 4400 mAh 3S Lipo then got burnt.
Would you visit www.caliberhobby.com for the motor, GWBLM009A, or contact service@gwsus.com of GWS USA seeking help.
Chen
GWS CHEN is offline Find More Posts by GWS CHEN
Old Jul 24, 2009, 05:19 PM
Joined Sep 2006
Heat Sink for 2815 ?
GWS very quickly replaced my seized 2815 motor through Caliber hobbies. I was very impressed with the speed of the replacement process!
Now, I need to purchase a heat sink in hopes of reducing the probability of a repeat performance.
The only place I see the 28mm heat sink is at caliber hobbies, but I really hate to pay $9.00 shipping on a $3.00 part.
Can anyone suggest somewhere where I might find this part (or similar) and avoid the high total cost?
Also, do I need to add any sort of grease to ensure good heat transfer?
thanks,
JohnAsa
Old Sep 06, 2009, 01:50 AM
manuel v is offline
Find More Posts by manuel v
manuel v's Avatar
Mexico, BC, Mexicali
Joined Aug 2004
I have an A4. that with an EDF 75 / 4, gives 15V, 32A, 36,200 rpm. (Motor ARC 28-47-1.5-2800kv.)
That push will have?
I feel it is too little. 600gramos around.
Very poor to 490watts.
Manuel V.
manuel v is offline Find More Posts by manuel v
Old Sep 06, 2009, 05:06 AM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
Manuel V.
600g thrust will be enough. My A4 is running on 3S with an ARC 28-37-2 producing 625g static thrust (at 30,500rpm), and it has good performance.
However, I think at least one of your measurements must be wrong. According to my calculations, at 36,200rpm the EDF75x4 should produce about 850g in the GWS A4.
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Sep 06, 2009, 01:20 PM
manuel v is offline
manuel v's Avatar
Joined Aug 2004
Thank you very much Bruce.
I have not measured the thrust. only the RPM.
850gramos then with the A4 should fly well.
Manuel V.
Old Sep 14, 2009, 07:13 PM
manuel v is offline
manuel v's Avatar
Joined Aug 2004
A4 Video.
GWS A4 (4 min 42 sec)
Old Sep 16, 2009, 11:32 AM
basha53 is offline
Find More Posts by basha53
basha53's Avatar
Bethlehem, Pa
Joined Jun 2004
A-4
Manuel, Nice flight with the A-4. Looks good in the air.
Gary
basha53 is offline Find More Posts by basha53
Old Dec 15, 2009, 07:23 PM
GWS4CEO is offline
Find More Posts by GWS4CEO
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
I need to try more motor design to let EDF75 pump out more thrust!
GWS EDF50 can give up to 910g thrust!
If we put a right motor, I am sure EDF75 can get 1000+g easy like pc of cake!
GWS4CEO is offline Find More Posts by GWS4CEO
Old Dec 28, 2009, 10:31 AM
Tamiya10 is offline
Find More Posts by Tamiya10
Tamiya10's Avatar
Canada
Joined Jun 2009
I just bought a GWS A4 plain white and I am adding my own BL motor, ductfan and gear. Here's the colours I am doing.........
Tamiya10 is offline Find More Posts by Tamiya10
Old Dec 29, 2009, 06:42 PM
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
Its a good looking scheme. She will look killer sporting it.
Jason
GWS EDF Jet Trainer flies! steve neill Parkflyers 19 Jul 09, 2010 01:04 PM
GWS EDF Jet Trainer flies! steve neill Electric Ducted Fan Jet Talk 61 Jul 02, 2010 01:39 AM
Discussion GWS 262 EDF Jet GWS4CEO Foamy EDFs 14 Aug 03, 2008 08:28 AM
Looking for picture of new GWS EDF Jet ipjodan GWS (Grand Wing Servo) 8 Sep 17, 2005 01:13 AM
For Sale FS A-6 A-10 F-4 B-2 EDF Jet Fighter Bomber ARF RTF shschon Aircraft - Electric - Airplanes (FS/W) 12 Aug 09, 2005 02:18 AM
