This thread is privately moderated by GWS CHEN, who may elect to delete unwanted replies.
Old Oct 29, 2008, 01:05 AM
earaoz is offline
Find More Posts by earaoz
Winnipeg, Canada
Joined Apr 2007
Motor for the A4?
Hi, I bought the GWS A4 and I'm looking to get a motor for it. Did anybody here use a motor from Hobbycity that can recommend?
Thanks in advance!
E
earaoz is offline Find More Posts by earaoz
Old Oct 29, 2008, 11:23 AM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
Hobby City (AKA Hobby King/United Hobbies) might have a lot of cheap motors, but nothing that I would recommend for the EDF75.
Ideally your motor should have the following specs:-
Kv: 3600~4000 for 3S Lipo, 2700~3000 for 4S
Power: 350W+
Weight: 70~100g (2.5~3.5oz)
Case Diameter: 28mm max.
Shaft Diameter: 3mm
AFAIK the only motors that meet all those requirements are the GWS BL28xx series. If the adapter can be drilled out to 1/8" (3.175mm) then you have more choices, including ARC, Medusa, HET and Mega.
Out of all the motors that Hobby City sell, the HXT/Turnigy B2835 was the only one I found that appeared to be suitable. I tested the 3900Kv version on 3S and it worked, but performance was lacklustre and I have doubts about its reliability at ~380W. It may also be tricky to install because its shaft diameter is 3.2mm - not 3.175mm! (this difference may not seem like much, but it will not fit an adapter which is drilled to 1/8").
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Oct 29, 2008, 02:57 PM
jjr2001 is offline
Find More Posts by jjr2001
Fly Low Fly Fast Fly Often
jjr2001's Avatar
Glendale, Arizona
Joined Jul 2007
Best Fan and Motor for GWS A4
Thanks in advance!
E
HC has a nice 75mm fan and motor but you will have quite a bit of modding to fit it in the GWS A4. The HET setup is much higher quality than either of the other options mentioned. With the HET setup you will have to add two wood mounts on either side of the fuse and then fill in the void with RTV rubber cement. I wrap my fan in saranawrap and then put in enough RTV to make a Gasket around the fan. Now you will have a fan that is held in with screws that you can remove instead of the lame doublesided tape that comes with the kit.
Try the HET 6904 fan and 2W20 motor from HET. This is a great setup for the GWS A4. You can find a bunch of info on the A4 on this thread:
http://www.rcgroups.com/forums/showthread.php?t=826052
Good luck in your quest, Mine has the HET 6904 and 2W20 motor and runs super on 4s1P Lipo at 4000mah. I have about 75 flights on her and I would never use the stock GWS fan or their red or white motor ever.....
If you want super fast then you can put in one of the "high power" modds with 1200 watts...Too hot for me....LOL...
jjr2001 is offline Find More Posts by jjr2001
Old Oct 29, 2008, 03:04 PM
FresnoJay is offline
Find More Posts by FresnoJay
To drive or to fly......BOTH!!
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
earaoz, Mine is now running a 1200W+ setup. It used to have a setup like jjr's. The thread he listed is the place to go to find out all the mods and goodies. GWS doesn't like us talking about aftermarket parts in thier threads.
Jason
FresnoJay is offline Find More Posts by FresnoJay
Old Oct 29, 2008, 03:11 PM
earaoz is offline
Winnipeg, Canada
Joined Apr 2007
Thanks for the information guys! And duly noted about the other thread. I didn’t know about GWS’ position on this…after all, they make the NPS version and it is up to the customer to decide what to put on it
E
Old Nov 13, 2008, 08:18 AM
GWS4CEO is offline
Find More Posts by GWS4CEO
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
http://flyclub.gws.com.tw/forum/atta...5&t=1226585696
A4 down load for FMS, free!
GWS4CEO is offline Find More Posts by GWS4CEO
Old Nov 13, 2008, 09:04 AM
dellavex is offline
Find More Posts by dellavex
Evansville Indiana
Joined Aug 2006
This link doesn't give you anything....can you please check it.
Originally Posted by GWS4CEO
dellavex is offline Find More Posts by dellavex
Old Nov 29, 2008, 06:18 AM
basha53 is offline
Find More Posts by basha53
basha53's Avatar
Bethlehem, Pa
Joined Jun 2004
Just Finished (pusher)
I just finished my TA-4 Yesterday, pusher version
Set up: LSSPJ
cc 45 esc
3 Eflite servos
APC 7X5
3s 2100
First attempt at a weathered finish, Have not maidened. I need to come up with something to protect the servo arms as I belly land on grass.
basha53 is offline Find More Posts by basha53
Old Nov 29, 2008, 08:51 AM
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
Basha, Nice looking scooter and pretty good weathering job for a first shot at it. Your doin better than me. None of my birds sport any weathering other than what comes normally over time from use . Good luck on your maiden.
Jason
P.S. I use some light ply glued into the wing that sticks out past the servo arm length to protect my servos. Acts as a grass break for them. Others have use scrap depron to make a ramp or spare small canopies to cover them.
Old Nov 29, 2008, 11:04 AM
basha53 is offline
basha53's Avatar
Bethlehem, Pa
Joined Jun 2004
Thanks, Jason
I have some srcap depron and ply laying around, I'll give it a shot. Where it's located it should almost look like a stores pylon
Old Nov 29, 2008, 11:09 AM
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
Basha, That is what mine looks kinda like. Matter of fact once mine gets her long over due retracts thats what they will be converted to. Same with my Center line Skid, Will become the center external drop tank pylon. (Got some cool plans for that too )
Jason
Old Dec 11, 2008, 09:32 AM
KiwiKid is offline
Find More Posts by KiwiKid
RCGroups - my happy place
KiwiKid's Avatar
Hamilton, New Zealand
Joined Jun 2005
This is my GWS TA-4J done up as a TA-4K in the colours of an RNZAF Scooter from the mid '70's. Some build pics are in a blog entry here: http://www.rcgroups.com/forums/showthread.php?t=966521
KiwiKid
KiwiKid is offline Find More Posts by KiwiKid
Old Dec 19, 2008, 06:46 PM
basha53 is offline
basha53's Avatar
Bethlehem, Pa
Joined Jun 2004
NICE!!!!!!!!! Great job on the A-4
Gary
Old Jan 31, 2009, 12:56 AM
ajreynolds is offline
Find More Posts by ajreynolds
I need a bigger garage...
ajreynolds's Avatar
USA, CA, San Diego
Joined Mar 2005
Mr. Lin,
Could you please post a different link to the FMS download or attach a ZIP file of the model directly in this thread? Clicking on the link you posted does not work.
Thank you,
Andy
ajreynolds is offline Find More Posts by ajreynolds
Old Jan 31, 2009, 02:30 PM
Pancake_1 is offline
Find More Posts by Pancake_1
Foam Flingin' Nitro Pilot
San Diego
Joined Mar 2008
Set up: LSSPJ
cc 45 esc
3 Eflite servos
APC 7X5
3s 2100
You know, I've been meaning to mention this....
If I ever set mine up for belly landing, I'm planning on simply cutting a slot in the top of the wing for the servo arm to stick out. This is a thick wing, so I would expect that you could make it so that it's barely noticeable. Of course, in the air it won't be noticeable anyway.... certainly wouldn't look any worse on the ground than the fact that there are no landing gear....
It also would make for a slick wing bottom (well, if you clean up all that "removeable wing" crap), which would be all the better for belly landing....
Look at a Park Zone Stryker, and you'll see that it's a no-brainer....
Pancake_1 is offline Find More Posts by Pancake_1
GWS EDF Jet Trainer flies! steve neill Parkflyers 19 Jul 09, 2010 01:04 PM
GWS EDF Jet Trainer flies! steve neill Electric Ducted Fan Jet Talk 61 Jul 02, 2010 01:39 AM
Discussion GWS 262 EDF Jet GWS4CEO Foamy EDFs 14 Aug 03, 2008 08:28 AM
Looking for picture of new GWS EDF Jet ipjodan GWS (Grand Wing Servo) 8 Sep 17, 2005 01:13 AM
For Sale FS A-6 A-10 F-4 B-2 EDF Jet Fighter Bomber ARF RTF shschon Aircraft - Electric - Airplanes (FS/W) 12 Aug 09, 2005 02:18 AM
