This thread is privately moderated by GWS CHEN, who may elect to delete unwanted replies.
Old Oct 03, 2008, 11:56 PM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
Jason-
I'm sure you've got it listed somewhere, but I'm just curious as to what your power setup is in your Skyhawk?
Jeff
www.CommonSenseRC.com
Tram is offline Find More Posts by Tram
Latest blog entry: Wow.. 3 years..
Old Oct 04, 2008, 02:35 AM
FresnoJay is offline
Find More Posts by FresnoJay
To drive or to fly......BOTH!!
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
Tram, I will be happy to answer your question in my build thread. At the request of Mr.Lin I do not bring it up in the the GWS forum as its not GWS equipment.
http://www.rcgroups.com/forums/showt...9#post10675165
Jason
FresnoJay is offline Find More Posts by FresnoJay
Old Oct 12, 2008, 11:49 AM
jamesdr is offline
Find More Posts by jamesdr
Unrepentant Carnivore
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
After a summer off - I finally got the chance to fly the "Scooter" again. Stock motor and fan - still going strong. I like to roll the throttle on for scale takeoffs - but today on takeoff - I hit a bump that launched me into the air prematurely. Fire walled it and she took it in stride! Love the way she turns and burns!
Now - where is my F-4?
Jim
jamesdr is offline Find More Posts by jamesdr
Old Oct 12, 2008, 12:11 PM
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
Final colors.
I meant to post these in here as this is where I originated with my A-4 in the early days. These are pics of what my A-4 looks like now and the plane I used as a subject. Came out very well I think.
Jason
Old Oct 13, 2008, 04:27 AM
gws shaqchang is offline
Find More Posts by gws shaqchang
FAA Commercial Pilot
Taiwan
Joined Sep 2008
Jason
it's awesome.....good looking
what's the total weight with battery?
how did u land the A4 smoothly? with power , little power or power off?
people said landing with power on will be stable....
gws shaqchang is offline Find More Posts by gws shaqchang
Old Oct 13, 2008, 06:57 AM
jamesdr is offline
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
You should be in the habit of landing all planes power on, especially EDFs. I land at about 1/5 to 1/4 stick.
Jim
Old Oct 13, 2008, 07:11 AM
R/C Dallas is offline
Find More Posts by R/C Dallas
R/C Dallas's Avatar
Italy, Friuli-Venezia Giulia, Fontanafredda
Joined Apr 2005
I have been landing my A4 power off and greasing every landing. I just raise the nose a little and let it settle in. I'll only use power to adjust the sink rate if I'm coming in short. The lower AUW/wing loading of these foamys lessen approach speeds and stall tendancies and make them pussycats to land.
R/C Dallas is offline Find More Posts by R/C Dallas
Old Oct 13, 2008, 12:27 PM
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
gws shaqchang, My RTF weight is 52oz.. I am not using a stock power system so I must run 2 4S 2250mah packs in parallel. I can fly for about 7 minute of full throttle but rarely fly that way.
You cant see them in the pictures but I have 3 1/16 ply skids that hang down in the scale weapon hard point locations that protect the Belly and servo's. The reason for doing them this way is so when I do retracts in the next few months, those skids will become ordinance pilons and carry Feul tanks and missles .
When Landing I come in at about 1/4 throttle and cut to 0% power just before touchdown to avoid sucking up and FOD.
Jason
Old Oct 13, 2008, 08:52 PM
Taiwan
Joined Sep 2008
Jason
cool...dude...
extra few oz. for the retracts....
is it too heavy for flight???????
Old Oct 14, 2008, 03:14 AM
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
Nope, it actually flies at around 100mph. It is currently bungee launched but could be hand launched. The bungee just works well for me. She will lose some weight when I get some bigger single LiPo packs. She flies very well indeed. Handles wind very well too.
Jason
Old Oct 16, 2008, 10:17 PM
hot glue is offline
Find More Posts by hot glue
Minnesota
Joined Jun 2007
I am thinking about getting this plane. I have a E-go HiSpeed B-20412L 4700rpm/volt inrunner.
These are the specs:
E-Go HiSpeed brushless Motor
Modello B-20412L 4700rpm/Volt :
Rpm(Kv): 4700Rpm/V
current: 1,10 mA
Resistance: 0,041
Weight: 66g
Length: 40mm
Diameter:20mm
Shaft Diameter: 2.3mm
ESC Rating: 20A
Would this work in this plane? From Towerhobbies.com, they have the NPS non-painted plane. Does that include the EDF, without the motor?
hot glue is offline Find More Posts by hot glue
Old Oct 16, 2008, 10:26 PM
jamesdr is offline
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
Per GWS - The A4 EDF NPS (white) kit includes EDF75 outer case, new impeller and 3mm adapter. I don't know that motor - the 75mm fan needs a fairly big motor to spin it up.
Jim
Old Oct 16, 2008, 10:27 PM
hot glue is offline
Minnesota
Joined Jun 2007
Ok thanks. What would you give this plane on a scale of 1-10. 10 being the best flying.
Old Oct 16, 2008, 10:40 PM
jamesdr is offline
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
OK - lots of folks have slammed it - mostly for problems with the stock motor. I'm running mine bone stock - and have a great time with it. It's a hot rod - a solid 7, maybe an 8. For me, the weak points are 1) main landing gear were too stiff (replaced with some castoff GWS P-38's with coils) and 2) short (but intense!) flight time with a 2250 3 cell. Don't go cheap with the battery - the EDF will push the battery hard. Some folks have put much bigger batteries in for longer flights - the fuse is pretty big to accommodate.
It's a good model - much better than the J10 - and performs really well for me.
Jim
Old Oct 16, 2008, 10:41 PM
Taiwan
Joined Sep 2008
Rpm(Kv): 4700Rpm/V
current: 1,10 mA
Resistance: 0,041
Weight: 66g
Length: 40mm
Diameter:20mm
ESC Rating: 20A
GWS-A4 , good performance with......
GWS 55A
GWS EDF75-BL2815(3700kv)
11.1 V 25C 2200mAH
total weight app.950g
GWS EDF Jet Trainer flies! steve neill Parkflyers 19 Jul 09, 2010 01:04 PM
GWS EDF Jet Trainer flies! steve neill Electric Ducted Fan Jet Talk 61 Jul 02, 2010 01:39 AM
Discussion GWS 262 EDF Jet GWS4CEO Foamy EDFs 14 Aug 03, 2008 08:28 AM
Looking for picture of new GWS EDF Jet ipjodan GWS (Grand Wing Servo) 8 Sep 17, 2005 01:13 AM
For Sale FS A-6 A-10 F-4 B-2 EDF Jet Fighter Bomber ARF RTF shschon Aircraft - Electric - Airplanes (FS/W) 12 Aug 09, 2005 02:18 AM
