Old Oct 23, 2007, 09:02 PM
tommyt is offline
Find More Posts by tommyt
Born to be free
tommyt's Avatar
undefined
Joined Sep 2004
Question
How do you make sealed hollow molded Ailerons or Flaps?
How do you make those fancy sealed hollow molded ailerons or flaps?
See picture below.
Regards,
Tom
tommyt is offline Find More Posts by tommyt
Old Oct 23, 2007, 11:03 PM
flusterfly is offline
Find More Posts by flusterfly
None
Joined Sep 2005
Check out the build of Joe Manor's 160" Dynamic.
Check out this:http://www.rcgroups.com/forums/showt...480273&page=26 and the following page.
flusterfly is offline Find More Posts by flusterfly
Old Oct 24, 2007, 05:04 AM
MarkusN is offline
Find More Posts by MarkusN
Joined Jun 2007
That works, but for an aileron that does not need the hammer torsional stiffness for DS there are easier ways:
Stick on a strip of adhesive tape. Insert it in the gap so it bends in a rounded shape and forms an elastic lip. If you have used a thicker tape and don't intend to go fast, that may be all that is needed. On fast planes elastic lips can be sucked out however, blocking the flaps.
If you want to make a hard lip, smear resin-microbal mix behind that lip, insert it into the flap-gap, adjust the flap to an angle where the lip looks right (usually the position just befor the lip slips out of the gap) and let it set, then pull off the adhesive tape (this is easier if you have impregnated the free part of the adhesive tape with PVA release agent). You'll probably have to sand the gap a bit to get the flap to move freely. And make sure the wing lies the right way around during curing so you don't glue the hinge shut...
Here are some pictures of a similar technique. He works with the ailerons detached.
MarkusN is offline Find More Posts by MarkusN
Old Oct 25, 2007, 07:59 AM
tommyt is offline
Born to be free
tommyt's Avatar
undefined
Joined Sep 2004
Thanks Guys,
So is there is no way of doing it in the mold when laying up the hollow molded wing???
Tom
Old Oct 25, 2007, 08:16 AM
MarkusN is offline
Joined Jun 2007
Nope. You'd have to have separate molds for wing and flap to achieve that. Which wouldn't be axactly good for airfoil precision.
Old Oct 25, 2007, 01:16 PM
davidfee is offline
Find More Posts by davidfee
davidfee's Avatar
San Diego, CA, USA
Joined Mar 2001
Thanks Guys,
Tom
Well, I have seen some molds where the seal was included in the skin layup, but it is not common. Normally any seals are added after the fact.
If you want to do it, one way would be to bond in a preformed seal section when you glue in the ribs (etc.) before closing the molds. The other way would be to make the molds such that the ailerons are deflected and the seal area is exposed... so the seal can then be integral with the aileron skin.
HTH,
-David
davidfee is offline Find More Posts by davidfee
Hello, new to the forum. How do you make a coil actuator flap? FlipperSail Ornithopters 13 Aug 06, 2004 08:31 AM
How do you make decals with a computer? Andy W Scale Kit/Scratch Built 50 May 24, 2003 10:12 PM
how do you make a mold buckeyes1997 Electric Sailplanes 31 Mar 01, 2002 01:12 PM
how do you make Krylon glossy p471701 Electric Plane Talk 6 Oct 06, 2001 07:22 PM
How do you make channels in foam? Jim McPherson Foamies (Kits) 8 Sep 21, 2001 09:00 PM
