Old Dec 31, 2007, 11:58 PM
thunder1 is offline
Find More Posts by thunder1
College Park, MD
Joined Sep 2002
Thanks. Having the detailed renderings makes it easy.
The pilot's weight is pretty insignificant in itself. But where it's located is pretty critical. If the model balances with the 8 ounce pilot then I can put a video camera system in it's place and take flight videos from the pilot's location. Then I'd need working gauges!
thunder1 is offline Find More Posts by thunder1
Old Jan 01, 2008, 05:06 PM
thunder1 is offline
College Park, MD
Joined Sep 2002
I worked on the control stick last night. Here are some pictures.
Old Jan 02, 2008, 01:21 PM
flmlm is offline
Find More Posts by flmlm
flmlm's Avatar
Holly Hill, Fl.
Joined Mar 2005
Thunder1,
Looks great! Thanks for sharing.
Regards
flmlm is offline Find More Posts by flmlm
Old Jan 02, 2008, 04:18 PM
thunder1 is offline
College Park, MD
Joined Sep 2002
Thanks, Mike. The more I get done on this model the more I realize that I've got a lot more to do! The motor will take quite a bit of detail work.
I'm working on the MG mounts right now. They are a little higher than scale to allow for clearing the motor intake and exhausts. The front mount pins on the MG slide backwards in the slots and then a pin is put in the back to secure the MG.
Old Jan 02, 2008, 09:39 PM
thunder1 is offline
College Park, MD
Joined Sep 2002
Here's a shot of the left MG mounted and the ammo belt in a scale location. I'm going to make scale ammo covers out of thin balsa.
Old Jan 02, 2008, 10:07 PM
Wolpertinger is offline
Find More Posts by Wolpertinger
Formerly "vonJaerschky"
Wolpertinger's Avatar
Canada, BC, Comox
Joined Nov 2003
Yeah, that is looking really sweet, thunder1. She'll be a beauty bird when you're done.
Wolpertinger is offline Find More Posts by Wolpertinger
Old Jan 03, 2008, 01:23 AM
thunder1 is offline
College Park, MD
Joined Sep 2002
Thanks, lots of fun detailling the WWI birds. MGs sticking out, exposed cables
I finished mounting the MGs and painted the mounting rails. The Rittmeister can't wait to fire these guns!
Old Jan 03, 2008, 08:33 PM
thunder1 is offline
College Park, MD
Joined Sep 2002
Here are the cabane struts mounted in place. I still have to cover them with something.
Old Jan 04, 2008, 12:39 AM
thunder1 is offline
College Park, MD
Joined Sep 2002
I worked on the tail skid tonight. The skid is attached to the lower fin with music wire bent into two U shaped pieces. The two wire pieces are connected together with brass tubing inserted into the fin and skid and glued in place. The two pieces of wire are held together with copper wire wrapped around the two sides and soldered in place.
A piece of music wire is also used as an attachment point for thin bungee cord which will act as a shock absorber.
Old Jan 09, 2008, 01:25 AM
thunder1 is offline
College Park, MD
Joined Sep 2002
I put the wings and tail parts on to measure the declage and incidence. The horizontal stab was not lined up with the lower wing so I had to sand a little wood from the stab saddle.
Old Jan 09, 2008, 01:30 AM
skippyflyboy is offline
Find More Posts by skippyflyboy
HEAVY METAL JUNKY
skippyflyboy's Avatar
seville ohio
Joined Apr 2007
The build looks great.
Have you decied on a scheme yet?
Chuck
skippyflyboy is offline Find More Posts by skippyflyboy
Old Jan 11, 2008, 01:39 AM
thunder1 is offline
College Park, MD
Joined Sep 2002
I'm doing this scheme.
Old Jan 11, 2008, 01:20 PM
floss is offline
Find More Posts by floss
floss's Avatar
Auckland, New Zealand
Joined Sep 2005
The plane wearing the scheme is a DV isn't it? I thought with the level of detail you've gone too you would want an original DIII scheme. It will look cool though.
Steve
floss is offline Find More Posts by floss
Old Jan 11, 2008, 05:05 PM
thunder1 is offline
College Park, MD
Joined Sep 2002
Yeah, I'm stuck on the paint job because it's my favorite of all time. I don't plan on entering any competitions with this one. MVR did have several all red D.IIIs and it certainly is possible that they didn't get painted red all at once. But I don't really care about that either way.
Old Jan 12, 2008, 10:18 AM
7car7 is offline
Find More Posts by 7car7
7car7's Avatar
Washington State
Joined Oct 2007
Good for you! Gotta build it the way you like it. I just completed an Albatros, and I took elements from a few different planes for the scheme...
7car7 is offline Find More Posts by 7car7
For Sale FUNAERO Albatros D.II **KIT ** wfortney99 Aircraft - Fuel - Airplanes (FS/W) 0 Apr 30, 2006 08:34 PM
anyone build the Albatros DIII from aerodromerc? jeff262 Scale Kit/Scratch Built 4 May 18, 2005 12:49 PM
Bengtson Albatros DIII LenBFP Scale Kit/Scratch Built 17 Mar 08, 2005 11:28 AM
Funaero Albatros D.III conversion questions Sehmel Scale Kit/Scratch Built 6 May 11, 2004 05:24 PM
