Old Oct 22, 2007, 08:19 PM
ducatirdr is offline
Find More Posts by ducatirdr
ducatirdr's Avatar
United States, MA, Sutton
Joined Aug 2006
Phase 3 - Hobbypeople F16 UPGRADES
I know it's all listed somewhere on the net right now but can we collect the upgrade info to this great plane and put it in one place. I want to build my next one up right. (FAST!!!)
Please list your upgrade info. Even if you only changed the lipo to a 4s and used the stock motor/EDF I'd like to know your results (life span)
Motor
EDF fan
EDF Housing
ESC
Battery
Required mod's to make it fit
Short success or failure report (run times and life span)
Speed if you have it
ducatirdr is offline Find More Posts by ducatirdr
Old Oct 23, 2007, 01:54 PM
rvincent is online now
Find More Posts by rvincent
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
Ok here we go!
I used an Alfa fan with 5 blade rotor. I also used a Jet Screamer motor and a CC-35 ESC. An Impulse 4S 2500 battery.
I mounted the motor back 2 1/2" from stock position so it would CG correctly with the larger battery. I also added a rudder because I LOVE doing knife edge passes. I used Krylon H2O primer and sanded between 3 coats to make it smooth. I used Tamiya "TS" series paint for the White, Red, and finnally clear coats. I t had 3 HS-55 servos and a Mikro Designs reciever. I also added a "How Fast" speed measuring device so I can know for sure how fast it is really going. I made the bottom removable so I have access to the fan unit and ESC. I currently have 27 flights on it and its parked in the hangar until the Superfly event in Vegas in 2 weeks. I also made my own decals from Testors clear waterslide decal paper then clear coated them so they wouldn't run when they got wet. They were applied after the paint was done and then clear coated over the top of them so they will never peel off My current best level pass is 118.6 mph level flight and 126 mph out of a dive. Here is a video of the plane as well
http://media.putfile.com/Hobby-Peopl...m-Scream-Style
rvincent is online now Find More Posts by rvincent
Old Oct 23, 2007, 02:30 PM
kahloq is offline
Find More Posts by kahloq
kahloq's Avatar
Fort Collins, Colorado, USA
Joined Dec 2005
I have an LSJS motor rcvincent. Which Alfa 60/25 fan am I supposed to get? The one for the Mega @ 44.90 or the other one which is 39.90? Both come with the 5blade rotor, but the mega version accepts a larger diameter motor where the normal alfa 5blade fan takes a 25.mm motor. Which one to buy? I also have to get the 3mm rotor plug right?
kahloq is offline Find More Posts by kahloq
Old Oct 23, 2007, 02:40 PM
rvincent's Avatar
Joined Jul 2004
The regular fan not the Mega one. Also get your 3mm adapter from Wilson Co. His run absolutely true
Old Oct 23, 2007, 03:20 PM
rcboosted is offline
Find More Posts by rcboosted
Joined Sep 2006
Let's see some knife edge videos!
rcboosted is offline Find More Posts by rcboosted
Old Oct 23, 2007, 04:14 PM
kahloq is offline
kahloq's Avatar
Joined Dec 2005
Link if you have one pls?
Old Oct 23, 2007, 04:41 PM
Joined Sep 2006
PM "Wilson Co" to order the adapter.
Old Oct 23, 2007, 05:04 PM
The Don is offline
Find More Posts by The Don
Park Pilot Mag. Jets Columnist
Willoughby, Ohio
Joined Jan 2002
Bob,
Have any posted video of those passes?
Don
The Don is offline Find More Posts by The Don
Old Oct 23, 2007, 05:58 PM
rvincent's Avatar
Joined Jul 2004
Hi Don,
The only video I have is of the maiden, the same one already posted. I'll get more for sure while in Vegas I will also show the "How Fast" reader with it's speeds too. With all the wind damage I have, and the fact I still need to finish 2 planes before Vegas (Nov 9,10,11) I might not get the chance to fly again before then.
Old Oct 23, 2007, 06:09 PM
ducatirdr's Avatar
Joined Aug 2006
Great rvincent thanks for the reply.
Just to clarify... There seems to always be confusion on the actual parts required to duplicate this beast.
ALF5103 Alfa EDF 60/25 Electric Ducted Fan ..... $ 39.90
MMC5156 LittleScreamers "JetScreamer" Ducted Fan OUTRUNNER with 21mm Adapter ..... $ 74.70
And Wilson Co adapter instead of the LSJS/Hobbylobby adapter?
and 4s batt with 35-40 amp 3-4cell lipo capable ESC
Anyone else or is everyone using this setup? (seems like it)
Old Oct 23, 2007, 07:40 PM
Turn n Burn is offline
Find More Posts by Turn n Burn
Turn n Burn's Avatar
Joined Aug 2007
Looks like a winning shopping list. The Wilson Co adapter runs smoother than Alfas .
Turn n Burn is offline Find More Posts by Turn n Burn
Old Oct 23, 2007, 09:32 PM
ducatirdr's Avatar
Joined Aug 2006
Shopping list>> I wish there was a sticky for this plane just for this reason. You fly the stock one and then immediately think "I MUST HAVE MORE SPEED" Not because the stock system isn't great. No it's due to the good old lust for more of a good thing.
I must admit that's my plan. My first foray into EDF was with the stock F16. I was really impressed with the kit. The build is fast and easy, the hand launching is easy and the stock speed is addictive. I've been spending most of my time flying my heli's and only pull out my planes when I'm looking to relax. This has changed my view of flying planes.
I think I like knee knock!
Old Oct 23, 2007, 09:36 PM
Joined Aug 2007
Old Oct 24, 2007, 06:49 AM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Hi Don,
Sounds good. So to clarify the 118mph was on a stock LSJS? or one of the "hot winds" you guys have been testing?
Don
Old Oct 24, 2007, 09:34 AM
rvincent's Avatar
Joined Jul 2004
Yes its a stock JS. Been playing with the rotor though I thinned down the trailing edges of the 5 blade (about 1/32"). It started out as an accident I had a chip out of one of the blades on the trailing edge. I kinda shaped it by leaving the root alone and tapering it down at the tip. Now when I check my efflux I get 134-136. All this was done after that video. I'm reading 50K now for rpm's. Sometimes we just get lucky And all because I'm too cheap to plunk down another $12 for a new rotor I don't know why the efflux is bouncing between 134-136? I can't hear any motor fluxuation. Maybe just my fat fingers holding the tubes moving ever so slightly?
New Product Phase 3 planes from hobby people?? Ben McCoy 3D Flying 42 Mar 30, 2007 05:35 PM
Phase 3? IwantaJet 3D Flying 11 Feb 13, 2006 09:51 AM
Phase 3 J3 club trainer StOcKerRaCeR Beginner Training Area (Aircraft-Electric) 1 Sep 15, 2005 04:28 PM
Top 3 Corona Performance Upgrades? OctoberGlory Electric Heli Talk 24 Dec 24, 2004 03:05 PM
J-3 Cub motor upgrades R/C Willy Parkflyers 11 Aug 10, 2004 07:55 PM
