Old Oct 21, 2007, 09:07 PM
Rocketman209 is offline
Find More Posts by Rocketman209
Arlington, TX
Joined Dec 2002
EZ Bubble Dancer
Hi
I am starting a build of a Bubble dancer. I have a kit on order from Polecat aero, but it is yet to arive. I have downloaded the plans for the tail surfaces, and am building them for starters. It has been a long time since I have built a full size sail plane. I have noticed that there are no build threads on this bird... How can this be? My research would lead me to beleive that Dr. Drela designed one of the finest RES birds on the planet!
Would you like to see a build thread?
Ok, here is another question. I plan on transparent covering. Typical, but what I would like advice on, is the best brand of covering. I am o=looking for ease of use, and durability in the hot Texas sun.
Walte
Rocketman209 is offline Find More Posts by Rocketman209
Old Oct 22, 2007, 05:10 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
I would (like to see a build thread)..
Could it be, there hasn't been a kit since this forum took off?
..a
Old Oct 22, 2007, 07:08 AM
bobby legue is offline
Find More Posts by bobby legue
Prescott Arizona
Joined Mar 2005
I would reccomend Oracover for ease of use as well as strength. There has been quite some trouble with monocote transparent in recent times.
Bob
bobby legue is offline Find More Posts by bobby legue
Old Oct 22, 2007, 08:57 AM
markdrela is offline
Find More Posts by markdrela
Cambridge, MA USA
Joined May 2001
Oracover and especially Monokote are much too heavy for the BD tails -- it will cause serious balance problems and possibly warps from excessive shrinking.
I very strongly recommend Ultracote Lite, for the wing as well as the tails. I got my UL from Horizon Hobby.
markdrela is offline Find More Posts by markdrela
Old Oct 22, 2007, 09:19 AM
Tim Wolff is offline
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
Originally Posted by Rocketman209
Hi
Walte
I downloaded and read through the EZ-BD instructions....and bought an AvA.
The EZ does look easier than a scratch build, but it dosen't look easy.
Tim Wolff is offline Find More Posts by Tim Wolff
Old Oct 22, 2007, 12:06 PM
dion9146 is offline
Find More Posts by dion9146
dion9146's Avatar
United States, KY, La Grange
Joined Feb 2006
Hi
Walte
Walte,
If you haven't found this site yet, it would be worth visiting:
http://groups.yahoo.com/group/allegro-lite/
It covers many of Dr. Drela's sailplanes including the Allegro Lite, Bubble Dancer, etc. I scratched an Allegro Lite this year with the help of the short kit from Mountain Models/Laser Arts:
http://www.mountainmodels.com
They also have a short kit for the Bubble Dancer.
Good luck, and I'm looking forward to the 'EZ' version build thread.
Dion
dion9146 is offline Find More Posts by dion9146
Old Oct 22, 2007, 07:01 PM
Arlington, TX
Joined Dec 2002
Thank you for all of the intrest. I hope the kit comes through from Polecat Aero, However, I will build away in hopes that the kit comes in. I realy like their Kit. The Fuse and spar are very nice. I will attempt to host a nice build thread.
I think I will order the Oracover Lite for the tail surfaces. I have kitted up the tail surfaces from 5.5LB "B" grain balsa. It should make for a nice light tail. I will try to have some pics shortly.
Walter
Old Oct 22, 2007, 07:31 PM
Cambridge, MA USA
Joined May 2001
Don't use Oracover Lite. It gradually loses tension, and also its adhesive creeps in the sun which makes the loosening worse.
Ultracote Lite stays tight forever and doesn't creep. It's a much superior material.
Old Oct 22, 2007, 08:41 PM
soholingo is offline
Find More Posts by soholingo
BANNED!!!
soholingo's Avatar
Laurel, MD
Joined May 2001
I used ultracoat Light in my windancer and its been sitting for weeks and no changes to the original covering. I like the stuff... besides of the Doc says use Ultracote, well I use Ultracote...
soholingo is offline Find More Posts by soholingo
Old Oct 22, 2007, 11:07 PM
Arlington, TX
Joined Dec 2002
Ok! Thanks Ultracoat Lite it is. This is exactly why I asked. I will be putting in a lot of work, I don't want it all spoiled by a bad covering job.
Thanks.
Walter
Old Oct 23, 2007, 07:01 AM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Good tip!
..a
Old Oct 23, 2007, 10:41 PM
Arlington, TX
Joined Dec 2002
OK, we need some pics!
Some pics of the stab before sanding. It weighs 36gm now, but I bet I lose 10 gm sanding...
Check out my $20 Ebay jewlery scale.
Also, some pics of my Apogee sport. What a great flying model.
Walter
Old Oct 27, 2007, 08:54 AM
Arlington, TX
Joined Dec 2002
Why, did the soaring guys forget about lifting stabs? I have been fiddling with some older models, and I have noticed that many of the old towline gliders use lifting (airfoiled) horizontal stabilizers. This allows flying with a more rearward CG. With this configuration, it is posible to have good stability with a CG around 60%. Seems like a way to lose the lead in the nose...
I would like to hear your comments
walter
Old Oct 27, 2007, 09:24 AM
ejett is offline
Find More Posts by ejett
TLAR Black Belt
ejett's Avatar
Athens, LA, United States
Joined Apr 2002
I think the ultimate lifting stab was on the Civy Boy. CG was on the trailing edge of the wing. The stab is huge, you could make a pretty good size RC trainer using that stab as a wing.
I don't believe the designers of RC sailplanes "forgot" about lifting stabs, but rather moved away from them for some reason.
EJ
ejett is offline Find More Posts by ejett
Old Oct 27, 2007, 09:56 AM
mlachow is offline
Find More Posts by mlachow
Joined Oct 2005
Most of the free flight stuff is designed to fly at just two flight conditions. Launch and glide. With an R/C sailplane and good construction with a light tail you don't need any more than the battery at the front for balance.
mlachow is offline Find More Posts by mlachow
Discussion EZ Bubble Dancer Configuration Left Hand Slicer Electric Sailplanes 7 Jun 18, 2007 08:15 PM
Wanted EZ Bubble Dancer VABeachflyer Aircraft - Sailplanes (FS/W) 1 May 26, 2006 02:12 AM
Bubble Dancer, sort of, for 7-cell LMR pocket rocket Electric Sailplanes 3 Jan 22, 2003 05:37 PM
Rave Any thoughts on Mark Drela's Allegro/Aegea/Bubble Dancer...? Raymund Reyes Thermal 3 Jan 05, 2003 02:38 AM
Bubble Dancer reviews/info cold boy Thermal 2 Dec 11, 2002 08:04 AM
