Old Oct 21, 2007, 04:53 PM
birdofplay is online now
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
Buccaneer Old Timer foamy
Some time ago I thought it would be fun to do an Old Timer in foam.
The 1937 Bill Effinger Buccaneer design has always been a favorite.
I liked flying my big 88" span Buc with a 4-sroker on the nose.
Even more fun on floats at the lake.
For the foamy version I choose a 48" span to insure it being a Floater too.
The Blue RCFoam 1/8" thick and the UC foils ideas presented elsewhere in this
forum also sounded like they'd be good to incorporate.
I used CAD to "pretty up" the fuse and make it appear to be built up.
It's just a bunch of lightening holes.
With the short nose I decided that a double stator motor would be best.
plus a spot to put the battery in the nose helps to make the Cg just right.
The LG is simple CF rod crossed and the axel bound between them with
Kevlar thread and CA. It's taken serious beatings this summer with no
complaints or breakage.
The fuse is lined with some small strips of 1/32 ply on each side at the
front and rear wing hold down areas. Plus I later added some more to
reinforce the wing saddle area, since the foam was getting beat up from use.
I made EPP wheels from scraps left over from my Unicorn wing blanks.
All up wo battery it's 13.5 oz. I use either 1650ma or 1300ma 3s1p lipos.
I've flown ~60 T&Gs with the 1300's in one flight.
It's done lots of nice slow Loops, powering OFF at the top and keeping
a wary eye on that foam wing
Using only Rudder, Elevator an 18amp Esc and a small CC RX
I've had nothing but good times with this bird all summer long.
I take it to large scale Aero Tow meets here in the NW and fly it
before and after the big birds are up.
This fall I hit on the idea of using TWO sheets of 3mm depron and
sandwitching the "Covering" between them. Using 3m77 or similar to
bond the sheets into a 6mm thick piece with the monocote trapped
between them before assembly. I even used clear for the side windows.
I also used White and Black ( outside/inside) colors for pleasing contrast.
Then I had some Built Up wings from a Porter project that never got
completed, so I used them on this new Buc. These wings have Hot Bent LE
and then ribs glued inside.
It's RCFoam with the shiny skin on the outside.
Each wing half holds at least a small metal VISE up without
too much complaining. NO SPAR ! OK there is a CF tube to join them
for flight, but, the strength test was done without the spar !
I cut Ailerons and FLAPS into this wing and used four servos.
Besure to mechanicly arrainge yours so that both the flaps and
ailerons can be Y'd into a single channel.
This plane was flown TODAY for the first time in the mist no less .
I was worried about the power as this plane came out lots heavier at 20 oz
I used a green CC mamba inrunner motor and gearing. 8.5x8 prop
Surprise !!! it rolled out nicely but I had to add lots of down trim.
I guess the decelage, set for the flat UC wing, is off a tad.
I'll jack up the TE a smidge and let you know after the next flights.
This wing also seems to like the use of Rudder coordinated turns.
It has NO dihedral so that makes some sense.
Experienced builders should have few problems with this design.
Fee free to experiment and enhance your version.
If you do need some clarifications just let me know.
Have fun
Bob Neitzke
AMA42857
birdofplay is online now Find More Posts by birdofplay
Old Oct 21, 2007, 05:12 PM
soar-ne is offline
Find More Posts by soar-ne
soar-ne
omaha ne
Joined May 2005
Now thats one fine looking plane I dont care what yah say!!!! Like the laminateing of the covering and the foam. Is on my build list for this winter. I have 2 1/2 rolls of Red Trans. Monocote in the bin that I will try to use.
How many blades did you use cutting all those circles, ovals and tri-angles out? Sure is a novel idea. I will use a undercamber wing with a KF bottom step on mine, have found it to be a great airfoil for slow parkies and has a great glide plus is a simple build.
Many thanks for the plans to you and Bill S
Happy Flying
Bob
soar-ne is offline Find More Posts by soar-ne
Old Oct 21, 2007, 05:24 PM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
Your'e welcome, Bill.
And the KF experiment will be a good one for this bird.
Looking forward to that effort.
I have to appologize for all the holes, but you see, I have a CNC cutter :-) not a laser
I dont think it would harm much to NOT cut them all out, ya know.
I'm going to be be adding some more pix soon.
Old Oct 21, 2007, 05:33 PM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
Well here is a few more pix for your approval.
I found some spare plastic "Drawer Dividers" and cut em into Horns.
Just another cost saving tip :-)
I used a piece of Liteply for the motor mount on both Bucs.
Also a strip of 3M Velcro to hold the battery in place.
Larger wheels and LG for better prop clearance on the New Buc
Old Oct 21, 2007, 06:02 PM
Rusty-Gunn is offline
Find More Posts by Rusty-Gunn
My plans are in my blog
Rusty-Gunn's Avatar
Kotzebue, Alaska
Joined May 2006
This is a fine looking build you got there.
Rusty-Gunn is offline Find More Posts by Rusty-Gunn
Old Oct 21, 2007, 08:06 PM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
I finally REdiscovered where my wing build photos were.
Old Oct 22, 2007, 07:33 AM
chaosMurphy is offline
Find More Posts by chaosMurphy
Registered HotGlue Addict
chaosMurphy's Avatar
Joined Dec 2006
Bob,
WOW! Nice build.
And, what an excellent example how technology changed from sticks, tissue and dope, the ‘A and B’ battery to foam and lipo.
I built a couple of these in the early/mid 1950s. Gas free flight, a bunch of dihedral and remember jacking the back of the wing up with a matchbox to decrease the incidence.
Then a one channel RC. The servo (called escapement back then) was rubber band powered and only turned in one direction. The model flew like and was nick named the galloping ghost.
Thanks for the walk back through time.
chaosMurphy is offline Find More Posts by chaosMurphy
Old Oct 22, 2007, 07:36 AM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Birdo , NICE!!!! ... and no hundreds of little sticks to fit either.... COOL !!!! Just a rash of Old Timers out there to "foamize"...
gpw is offline Find More Posts by gpw
Old Oct 22, 2007, 10:28 AM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
Thanks, G ramps ! yup yup yup I actually HAVE some escapments preserved
somewhere around here !
GPW: happy B'day and Thanks also :-)
I always like the way the Buc handled as opposed to oh say the Quaker.
PLus I liked the NORTHRUP style Tail "look" . it was a 30's thang :-)
NOTE:
I'll going for an airplane ride back to Indiana t'morrow
so I WONT be able to answer questions for a while.
But Y'all can start cuttin HOLES out in the meantime :-)
Old Oct 22, 2007, 11:31 AM
segraves is online now
Find More Posts by segraves
Joined Jan 2007
Originally Posted by Gramps:>)
...Then a one channel RC. The servo (called escapement back then) was rubber band powered and only turned in one direction. The model flew like and was nick named the galloping ghost.
Yes. IIRC, Babcock was the maker of the escapement. I still have mine in a box of about 40+ year old and slightly newer RC goodies.
Adding to the historical perspective, the term "galloping ghost" was later applied to single channel propotional control, in which the elevator and rudder were interconnected via a scotch-yoke like linkage, driven by a Mighty-Midget motor, the direction of which was usually switched via a single-pole double-throw relay. The rate of pulsing of the transmitter controlled the elevator, while the pulse width controlled the rudder. John Worth was one of the first, IIRC, to offer plans, via an MAN article, and kits, via Ace R/C, for a pulser that could be plugged into the transmitter (in place of the transmitter keying cable. Back then, giant 27 MHz CB transmitter boxes, e.g., Gyro made one, were the norm, replete with 1/4 wave antenna and a remote cable for keying. I lost my Gyro transmitter in a move back in 1971, but I still have my first "hand-held" Galloping Ghost transmitter, with built-in pulser, control stick, and transmitter board. Batteries were too heavy then, so a cable from the TX to a large Nicad battery pack, ground or waist(belt)-mounted, was used.
Cheers,
Bill Segraves
segraves is online now Find More Posts by segraves
Old Oct 22, 2007, 03:04 PM
FirstShirt is offline
Find More Posts by FirstShirt
You deserve my opinion
FirstShirt's Avatar
Collierville, TN
Joined Apr 2005
BOP, Man, that's a beauty! Thanks for the thread. I rarely see a old timer that doesn't catch my eye. Nothing like a floater for a relaxed, "lawn chair potato" evening of flying. Pat
FirstShirt is offline Find More Posts by FirstShirt
Old Oct 22, 2007, 05:08 PM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
You're welcome Firstshirt :-) enjoy
yup yup yup perfect for those calm late evening
relaxing flights around the patch ;-)
I have an OS Minitron Escapment s-2s and as-4s
plus
two Futaa ML-2a escapments
All NIB wiht instructions and packaging .
Oror should that be Old In Box :-)))
C U in a few weeks - I'm oughta here !
Old Oct 23, 2007, 06:53 AM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
Gosh , remember that old stuff ... push the button once for left , twice for right ...I think the planes flew better than we did...hahahahaha
Old Oct 23, 2007, 07:15 AM
Joined Jan 2007
Egads! You are as old as dirt, after all. ;-)
I didn't write the pulse sequence in my narrative because I couldn't remember it. Thanks for reconnecting the wires.
Buccaneer old timer jerico Vintage & Old-Timer Designs 7 Apr 03, 2005 03:31 PM
Old Timer's Forum? realglow Site Chat 0 Nov 13, 2001 09:21 PM
54 Inch Old Timer Quaker ArtJ Aircraft - Electric - Airplanes (FS/W) 3 Nov 05, 2001 07:58 AM
Old timer, kit suggestions please slowflyer Parkflyers 12 Jul 15, 2001 10:55 AM
"Old Timer" kit suggestions please slowflyer Sport Planes 13 Jul 15, 2001 08:26 AM
