Old Dec 07, 2002, 12:57 AM
robw is offline
Find More Posts by robw
robw's Avatar
Detroit, Michigan
Joined Nov 2002
how do you cut carbon rods?
how do you cut carbon rods, without making them frey?
robw is offline Find More Posts by robw
Old Dec 07, 2002, 01:34 AM
Quacker is offline
Find More Posts by Quacker
ClearView Rocks!
Quacker's Avatar
United States, CO, Longmont
Joined Jul 2001
Hi. I use an Exacto blade. I roll the blade over the rod on a hard, smooth surface. I don't press too hard--just get it straight. A few rocks back and forth cuts a deep groove all the way around the rod. Then I can easily snap it. This old method also works on brass and aluminum tubing and wooden dowels.
Regards,
Q
Quacker is offline Find More Posts by Quacker
Old Dec 07, 2002, 01:47 AM
RMihara is offline
Find More Posts by RMihara
Aerial Shutterbug
RMihara's Avatar
San Mateo, California, United States
Joined Nov 2001
The 'score and snap' method works well provided you have a blade with no nicks in it (meaning a fresh blade). You do get some localized delamination of the inner fibers when you use this method but you can go back and apply some thin CA to re-bond those loose fibers.
If you need an absolutely 'clean' cut with no 'brooming' then I recommend you get a diamond cut-off wheel (Orchard Supply has them) for your Dremel tool. Apply two turns of masking tape at the area to be cut, mark and cut (slowly) with the cut-off wheel.
Of course this will generate CF dust, you could 'wet' cut it to lower the dust generation but you will end up with the cleanest cut with little or no fiber-matrix separation.
Regards,
Roger
RMihara is offline Find More Posts by RMihara
Old Dec 07, 2002, 02:36 AM
notoatmeal is offline
Find More Posts by notoatmeal
vancouver, bc
Joined Feb 2002
a dremel... but do it outside. I hear that CF dust is really bad for you.
or use one of those cutoff pliers that electricians use. They have holes that line up when the plier is open, and then slice through whatever is in the holes when you close them.
if you do fray a CF rod, just dab a tiny bit of CA on the end, that will prevent fraying also. I put some CA on scrap paper, then touch the CF rod to the glue.
notoatmeal is offline Find More Posts by notoatmeal
Old Dec 07, 2002, 03:14 AM
Mike Seale is offline
Find More Posts by Mike Seale
f5b-uk
Mike Seale's Avatar
United Kingdom, Dorset
Joined May 2002
I just use a hand saw with a fine blade, a junior hacksaw usually. CF won't fray.
Mike Seale is offline Find More Posts by Mike Seale
Old Dec 07, 2002, 06:15 AM
Kevin Graehl is offline
Find More Posts by Kevin Graehl
Kevin Graehl's Avatar
myspace.com/graehl
Joined Mar 2001
stick in a drill -
rotate and cut with a dremel cuttof wheel while blowing the dust away from you
this is the best way possible-
no fraying
no masking tape
just a clean non-flayed cut
you can cut on top of a wet sponge or cloth to get rid of all toxic dust(while using a dremel)
Kevin Graehl is offline Find More Posts by Kevin Graehl
Old Dec 08, 2002, 02:34 AM
RMihara is offline
Aerial Shutterbug
RMihara's Avatar
Joined Nov 2001
Originally posted by Kevin Graehl
stick in a drill -
no fraying
no masking tape
That would be fine for cutting short sections of CF rod Kevin, but you will find it rather dangerous with long lengths of > 6".
I simply use my bare hands, take a deep breath and blow while spinning the rod with my fingers while slicing through with the cut-off wheel. The masking tape is so that you can keep track of where the blade is so it doesn't 'wander' about, has nothing to do with keeping the CF from delaminating while cutting.
Regards,
Roger
Old Dec 10, 2002, 11:54 PM
myspace.com/graehl
Joined Mar 2001
mabye you didn't understand right..
any length is possible
put CF in drill
set on top of knees
rest palm on to of CF
angle dremel to cut
blow dust away
this method is the only way i have found it usefull to cut larger CF tubes (hollow) with square ends
for the smaller rods and exacto knife will work fine as will the drill dremel method
Old Dec 11, 2002, 02:19 AM
RMihara is offline
Aerial Shutterbug
RMihara's Avatar
Joined Nov 2001
Kevin,
I am not looking for any argument here, and I did understand what you were communicating.
I'm simply bringing up the point that with the CF tube supported in this fashion, cutting long lengths of material will be very difficult to hold steady.
Ever watch a machinest 'parting off' a finished component on a lathe? The cut-off tool is always located close to the lathe chuck, never at a distance. This minimizes errors caused by flexing of the material being cut. And CF tubing does flex, it's this flexing which can cause the cutting tool to gouge and catch ahold of the material being cut resulting in injury.
But each of us has our own technique, one that works for us and this forum provides a means of disseminating that information.
Believe me, I've seen my share of 'industrial' accidents to warrant my position here.
I'd recommend that instead of holding the drill in your hand that you lock it up in a bench vise. That way you can guide the end of the CF rod adjacent to the cutting area. No chance of it whipping about.
Regards,
Roger
Old Dec 11, 2002, 08:00 PM
myspace.com/graehl
Joined Mar 2001
no argument i thought you didn't understand
i have seen one to many accident -broken bits, ripped shirts,
splinters, larger red chips---(high school regional occupation program - Machine Shop) i learned alot from that class and am hoping for a sherline multilathe to apperar under the christmas tree this year---
yeah right
Old Dec 11, 2002, 08:35 PM
RMihara is offline
Aerial Shutterbug
RMihara's Avatar
Joined Nov 2001
No worries there Kevin...
And in the spirit of xmas, here you go...
Old Dec 11, 2002, 08:39 PM
Bandikoi is offline
Find More Posts by Bandikoi
Bandikoi's Avatar
United States, FL, West Palm Beach
Joined Jul 2002
Cutting carbon rods
I use the cutters from these folks and they work very well with clean cuts.
Of course, it only works on smaller stuff.
Click on the link and then select carbon cutter.
Chuck
http://www.airdyn.com/index.htm
Bandikoi is offline Find More Posts by Bandikoi
Old Dec 12, 2002, 02:36 AM
myspace.com/graehl
Joined Mar 2001
ya crazy
are the tolarances on that as close(or loose) as they advertise?
how much did you pay
you can Instant Message me or leave it here
i am hopping that my mom gives me christmas money this year
she did last year but hasent said anything yet
but now i am 21 years old and too afraid to ask
crossing my fingers
Old Dec 12, 2002, 04:02 AM
PierreVC is offline
Find More Posts by PierreVC
PierreVC's Avatar
Brussels, Belgium
Joined Feb 2002
Before flying helis I flew/builded kites.
Put some tape on the carbon rod were you need to cut it.
Pierre
PierreVC is offline Find More Posts by PierreVC
Old Dec 30, 2002, 07:10 AM
jdowdle is offline
Find More Posts by jdowdle
United States, NC, Franklin
Joined Dec 2002
Re: Cutting carbon rods
Chuck
Hi
do you know if any of these tubes at this site will replace the tail boom?
thanks, Jim (thehornetsmasher)
jdowdle is offline Find More Posts by jdowdle
How do you cut holes in EPP? TopDog Foamies (Kits) 8 Feb 05, 2010 10:06 PM
How do you cut Carbon fiber plate? soholingo Composites Fabrication 15 Jun 21, 2005 05:39 PM
How do you cut long straigt lines in foam? slowflyer Foamies (Kits) 10 Jan 24, 2002 08:53 PM
How do you cut carbon fiber rod? JamesD Beginner Training Area (Aircraft-Electric) 6 Oct 17, 2001 10:15 AM
