Old Oct 20, 2007, 12:30 AM
Heliman420 is online now
Find More Posts by Heliman420
Like a Boss
Heliman420's Avatar
Canada, BC, Celista
Joined Jun 2006
Build Log
My first attempt at 1/72 scale planes (build log with video)
Hi everyone, i have been browsing through the (micro/indoor) forum for the last few weeks,aside from the helicopter forums i usually frequent,
and was amazed to see such small beautiful scale models, made from rolled foam!! and powered by a picco z tail rotor!!
after reading micromads thread. i was inspired to atempt to build my own 1/72 scale spitfire.
for my radio gear im going to use,
plantraco 2ch rx
fr 20mah lipo
3mm actuator from indoorflyer
picco tail motor and prop.
while i wait for all my radio gear to arrive. I started building my airframe,
i decided to use 2mm foam plates, just because i had a bag of 150 sitting in my closet that i bought for model making awhile ago
i used the templates posted by rguillot in micromads thread,
i sanded the plates to a thickness of 0.8, mm. the first fuses were rolled from 1mm, but this was too heavy.
0.8 was perfect and the fuse was rolled with relative ease.
the wing was cut from 1mm (for strength) and given a slight airfoil, and sanded with very fine sandpaper to profile the LE and TE. a thin strip (0.5mm) was added to the LE of the wing, and also sanded to flow with the rest of the airfoil,
the finished wing came out quite strong, with little flex.
i made my nose from, regular packaging foam(another material i just happen to have plenty off) and sanded to fit.
the finished bare airframe (no canopy/motor/rx gear) came out heavier than i expected 0.8.7 grms guess i have to get some durobatics, and try again.....
but i decided to finish this one and see if it will fly.
i decided to paint it the standard camo theme(i have never painted camo like this before) so it was hit and miss, i tried some different colors on some of my first fuses to try and get the color right.. for paint i used acrilyc witch i got from an artist friend, i mixed up the color, and diluted it with water, till it was quite thin. i painted the bottom, sky blue first, then the rest of the plane.
i then weighed the finished airframe, and was shocked to see a weight increase of 0.2 grms giving it a total weight of 1.05 this is really heavy compared to the other models ive seen on here. i guess i painted on too thick.
i did some glide tests with the motor installed, and it glides really well, (better than some of my previous large models) so i will continue with it. my next one will be made from durobatics. and that should solve the weight problem.
i still have to make a lightweight canopy to finish the airframe,
now i have to wait till all my gear come in to see if it will fly or not.
here are some pics of the build so far.....
Heliman420 is online now Find More Posts by Heliman420
Old Oct 20, 2007, 12:53 AM
reylf_gnijieB is offline
Find More Posts by reylf_gnijieB
Beijing, China
Joined Nov 2006
Looks good! Good luck with the flying.
reylf_gnijieB is offline Find More Posts by reylf_gnijieB
Old Oct 20, 2007, 02:21 AM
CubbyMan is offline
Find More Posts by CubbyMan
CubbyMan's Avatar
Vancouver, B.C.
Joined Jun 2004
my first attempt at a 1/72 scale plane
Hi heliman 420,
I am happy to hear that a fellow Vancouver modeler has decided to go and build 1/72 scale models.Keep up with your work cause i know good things come to people who have patience . Maybe we could meet where you fly in here in Vancouver Beautiful camo finish on the spit
CubbyMan
CubbyMan is offline Find More Posts by CubbyMan
Old Oct 20, 2007, 03:04 PM
Like a Boss
Heliman420's Avatar
Canada, BC, Celista
Joined Jun 2006
thanks guys,
cubbyman, i usually fly my helis at burnaby lake (hoodsupflyers club) but havent had a chance to fly lately due to the weather, i also fly at local parks/fields, in the kitsilano area,
im going to try and make a lightweight canopy today for the spitfire, to complete the airframe. im also thinking of making some decals, but i think that might put it over the edge. as it might be too heavy already.......
Old Oct 20, 2007, 04:05 PM
CubbyMan is offline
CubbyMan's Avatar
Vancouver, B.C.
Joined Jun 2004
Hi,
Just try to find very thin packaging material,maybe you'll find one. I've used that material for my Kingfisher. One of the people i fly with is a member of the Burnaby Lake Hoodsupfyers, we fly at park not far from where i live(Falaise park,a few blocks from Rupert and Grandview H-way) every Wednesday at 9 am as long as it's weather permitting.Let me know when you maiden your Spitfire,i might have the chance to meet you
cubbyman
Old Oct 22, 2007, 06:54 PM
Like a Boss
Heliman420's Avatar
Canada, BC, Celista
Joined Jun 2006
i have decided to make another airframe due to the fact that i think this one is too heavy to fly with the picco z motor and prop combo,i estimate my flying weight will be 3.5 grams with the plantraco rx battery and 3mmact, (too heavy imo)
my new airframe weighs in unpainted at 0.6 grams, i have sanded the plates to paper thickness, but the airframe seems really flimsy compared to the first one...... and the wing will have to be reinforced to stand a chance of flying. i think i will have to order some durobatics tonight..... and try again...
Old Oct 22, 2007, 08:12 PM
Citabria86614 is offline
Find More Posts by Citabria86614
Joined Apr 2007
Wow how do you make theses things I am inpresed. I love scale. I have a top flite p-40 and other than the takeoff it is a doll to fly. I might just have to try a plane little bigger than yours using the U-Build-it plane electronics. Maybe a f6f, hellcat or wildcat.
Citabria86614 is offline Find More Posts by Citabria86614
Old Oct 22, 2007, 09:04 PM
Like a Boss
Heliman420's Avatar
Canada, BC, Celista
Joined Jun 2006
the AH U build It gear might work nicely, althou im not too familiar with the plane, whats the weight of the components?
as for the plane itself, rolled foam is quite easy to do and produces good results,
i only have one template the "spitfire" posted by rguillot, im sure others can be made the same way.
Old Oct 23, 2007, 11:45 AM
Uwe Steller is offline
Find More Posts by Uwe Steller
Uwe Steller's Avatar
Karlsruhe, Germany
Joined Jan 2004
I would give this a try, if Cubbymans Hellcat flies fine at 5g, why should your spit be too heavy at 3,5g ? It looks so nice, and what looks nice, flies nice, mostly ...
Uwe
Uwe Steller is offline Find More Posts by Uwe Steller
Old Oct 23, 2007, 12:10 PM
micromad is offline
Find More Posts by micromad
The ceiling is the limit!
micromad's Avatar
South of England
Joined Aug 2004
It should fly easily at 3.5 grams. All my Spitfires usually come in at 3- 3.4 grams.
Alex
micromad is offline Find More Posts by micromad
Old Oct 23, 2007, 02:20 PM
Like a Boss
Heliman420's Avatar
Canada, BC, Celista
Joined Jun 2006
thanks alex, i was worried about the weight, i didnt think it would fly over 3.4 grams,
i tried to keep the weight down as much as possible, but the paint put on more weight than i expected, and i thinned the acrilycs quite a bit with water. I estimate my second airframe will be 0.8 painted, and around 3 grams flying weight.
im havig a bit of difficulty making the canopy, im familiar with the heat shrink method,
but dont have any currently,(might have to get some) so ive been working with thin clear plastics instead, but havent had any luck producing a decent looking canopy......
Old Oct 23, 2007, 02:36 PM
epilot is offline
Find More Posts by epilot
Remote island inhabitant
Joined Nov 2000
The 14ohm 4x11mm pager produces almost 2 grams of thrust with a stock PicooZ prop so I think it will fly a 4-5 gram model if the airframe is not too draggy.
Michael
epilot is offline Find More Posts by epilot
Old Oct 23, 2007, 03:19 PM
micromad is offline
micromad's Avatar
South of England
Joined Aug 2004
Just find some really thin plastic and heat it up then push the mould through. I did this all the time until people pointed out I was adding unnecesary weight to the airframe and could make them so much lighter using heat shrink.
Michael,
Do you think the piccoz motor and prop could pull a 3.8 gram hellcat around? I was wondering this because I know they produce a lot of thrust but then its got an enormous cowl on the front which produces a lot of drag. Have you had any experience with dd hellcat's?
many thanks
Alex
Old Oct 23, 2007, 03:39 PM
epilot is offline
Joined Nov 2000
I haven't flown a 1/72 Hellcat but as you say it has a lot of drag and you should probably use a geared motor.
Michael
Old Oct 23, 2007, 04:28 PM
micromad is offline
micromad's Avatar
South of England
Joined Aug 2004
Yes you are probably right. I have gone right off geared motors these days. Personally I dont think you can beat dd especially on these Spits, the performance is amazing.
Btw when do you expect the pz motors in stock?
Alex
My first attempt at building and converting a Guillows to a RC plane gwong Scale Kit/Scratch Built 40 Nov 01, 2006 03:39 AM
My first attempt at my own plane JPA2002 Foamies (Kits) 14 Mar 07, 2004 08:33 PM
My first attempt at a fan-fold plane... EMFB Foamies (Kits) 8 Jun 05, 2003 11:30 PM
My first attempt at weathering a plane flipnidaho Scale Kit/Scratch Built 8 Jan 18, 2003 12:51 PM
