Old Oct 19, 2007, 11:27 PM
j'flyr is offline
Find More Posts by j'flyr
I fly by wire
Amish paradise - Lancaster, Pa
Joined Aug 2007
2.4 ghz camera with a DX7
Due to popular demand (of my children) I'm thinking of adding a wireless cam to my Trex 450. I use a Spektrum DX7 and was wondering if anyone has tried this combo. I wasn't sure of any issues.
This is the cam - cheap and generic to start out with but if all goes well I'll upgrade to something a little better:
http://cgi.ebay.com/SM-WIRELESS-CAME...QQcmdZViewItem
Feedback is appreciated!
j'flyr is offline Find More Posts by j'flyr
Old Oct 19, 2007, 11:33 PM
rcboosted is offline
Find More Posts by rcboosted
Joined Sep 2006
I don't see 2.4ghz mentioned in the auction.
rcboosted is offline Find More Posts by rcboosted
Old Oct 19, 2007, 11:40 PM
j'flyr is offline
I fly by wire
Joined Aug 2007
I didn't notice that but I'm pretty sure it is 2.4ghz. I've been through a dozen or so different models and all were.
Old Oct 20, 2007, 12:30 AM
Joined Sep 2006
Let us know if it's 2.4ghz and if it can co-exist with the DX7!
Old Oct 20, 2007, 01:09 AM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
I have the same camera its 2.4Ghz. Havent tried to use mine on the heli yet (just played with it). Ive heard it isnt an issue with the spektrum technology as long as you bind your receiver before turning on the camera. I doubt it is an issue if you didnt anyway, as there are a lot of frequencies in the 2.4Ghz band ( i have a 2.4Ghz joystick sitting right next to my 2.4Ghz phone.... and dont get an issue )
jackosmeister is online now Find More Posts by jackosmeister
Old Oct 20, 2007, 01:16 AM
Joined Sep 2006
I've read the opposite. The camera's signal overwhelms the Rx. I've also read the video receivers with a tuner will constantly go out of tune and you have to keep adjusting it. Since I don't have any wireless cam to try, I'm relying on everyone else' experience.
Old Oct 20, 2007, 01:22 AM
Auckland NZ
Joined Aug 2007
From playing with it the receivers tuner is pretty sensitive and you do have to keep adjusting it everytime you turn it on.
Old Oct 20, 2007, 08:57 AM
j'flyr is offline
I fly by wire
Joined Aug 2007
We need more feedback about this from users that have tried making it work.
(bump)
Old Oct 20, 2007, 09:19 AM
hihptsi is offline
Find More Posts by hihptsi
hihptsi's Avatar
Illinois
Joined Apr 2005
(bump)
i fly FPV and have done lots of research on the subject.
usually the power of the(2.4) video Tx will overwhelm the 2.4 ghz tx.
it will overload it and casue lockout.its happend MANY times.the rule of thumb when building a FPV ship is to use a standard aircract freq.with a 2.4 ghz video downlink.
or you Could use a 900mhz video downlink and get away with a 2.4 ghz Radio.
IMO going 900 mhz would be the best choice if you already have the 2.4 ghz radio.for one 900 mhz isnt subjets to multipath interference,like 2.4ghz microwaves are.900 mhz gets much longer range for a given transmit power.
hope it helps.
PS you dont want any video equip with a tuner.its GARBAGE and you will quickly get sick of it becasue of having to tune it all the time.
hihptsi is offline Find More Posts by hihptsi
Old Oct 20, 2007, 10:45 AM
j'flyr is offline
I fly by wire
Joined Aug 2007
Thanks...that does help. So there are kits like the link I posted that are 900mhz? I'll do a ebay search.
Thanks again for the insight!
Old Oct 20, 2007, 11:27 PM
hihptsi is offline
hihptsi's Avatar
Illinois
Joined Apr 2005
pick up a cheap kit from Wade at future hobbies.top notch service and great products.you will not be dissappointed.
Old Oct 20, 2007, 11:35 PM
beafraid8 is offline
Find More Posts by beafraid8
Mom says I'm special...
beafraid8's Avatar
Aurora, CO
Joined Apr 2003
Yeah, good luck with a 2.4ghz video transmitter on any aircraft. You'd better keep it further than 3 ft. from your receiver so you stand a CHANCE of maintaining control past 300 ft. I've tried it in perfect conditions with the video camera/transmitter about 15 inches from the receiver and it was ugly. The further I could get it from the receiver the better, but I was only on a 32-inch wingspan plane, so my options were limited.
Not to mention what it does to the video quality when the receiver is oriented between the camera/video transmitter and the video antenna on the ground...
Range was 300ft. maximum with an AR-6100 receiver. And there was a lot of glitching...so much so that it reminded me of my Hitec Feather receiver days!
I have video I can post, but it isn't good as you can imagine.
beafraid8 is offline Find More Posts by beafraid8
Old Oct 21, 2007, 02:13 PM
ShellDude is offline
Find More Posts by ShellDude
Only electrons, Martha
ShellDude's Avatar
Outside Philadelphia
Joined Nov 2002
If the pictured receiver is the one you get from that auction then you're not getting a 2.4ghz system. I have a couple 900mhz and 2.4ghz systems and the cheapest 900mhz system uses that receiver... you have to use the stereo knob on the end of it to "tune" in your camera reception and it's very tempermental.
The 2.4ghz setups typically allow you to select 1 of 4 predefined channels. Some of the better 900mhz setups have the same setup and I've yet to see a 2.4ghz receiver with a stereo knob for tuning reception.
ShellDude is offline Find More Posts by ShellDude
Old Oct 21, 2007, 06:57 PM
Auckland NZ
Joined Aug 2007
My receiver is identical to that (with the knob) and is 2.4GHz.
Old Oct 21, 2007, 09:25 PM
j'flyr is offline
I fly by wire
Joined Aug 2007
I just emailed the seller and asked what frequency this operates on. I'll post back his response. I've also priced some 900mhz cameras and their a good bit more expensive...$150 - 200.
So, if the receiver has a "tuning knob" the quality sucks and if it has a specific channel you can select that unit works?
2.4 ghz wireless camera from ebay Cyb Aerial Photography 3 Jul 29, 2008 12:35 PM
Discussion 2,4 Ghz spektrum with our EDF Jets ? ? ? bmaaa Electric Ducted Fan Jet Talk 74 Feb 27, 2007 11:33 AM
Discussion Experience with downlink not on 2.4 GHz? N8fromVA Aerial Photography 5 Sep 27, 2006 08:29 PM
2.4 GHz Video system with Audio Transmission $65 shipped Nik-rc Aircraft - Fuel - Airplanes (FS/W) 5 Jun 07, 2004 08:18 AM
2.4 ghz Complete Video System with mods, great for parkflyers! With Audio $70 shipped Nik-rc Aircraft - Electric - Airplanes (FS/W) 6 May 31, 2004 09:21 AM
