Old Feb 18, 2008, 12:51 AM
Rudderman98 is offline
Find More Posts by Rudderman98
AMA 670207
Rudderman98's Avatar
United States, WA, Sumner
Joined Oct 2000
Wiring for motors are SERIES/PARALLEL.
Had to edit the first pic for when I tried it, it didn't work!
Here is the new pic. Can you tell the difference? I had to get the plan for the Mars to refresh my memory on how everything gets wired. That's a lot of wires to arrange!
Rudderman98 is offline Find More Posts by Rudderman98
Old Feb 18, 2008, 01:02 AM
scratchnhover is offline
Find More Posts by scratchnhover
Fly2Build.com
scratchnhover's Avatar
Redding,California
Joined Dec 2003
Perry,
Your progress is inspiring and your work is top notch. Thanks for all of the pics. Our flaps look almost identical in design and I may opt to do a similar Robart solution like you've posted.
Glad you're obviously gaining mobility back in your wrist/hand and its great to follow your progress
Is that 14 g wire for the motors?? My wiring schematic will be the same as yours just add another of those diagrams to the mix What size battery will you be using?
scratchnhover is offline Find More Posts by scratchnhover
Sluf7 is offline
Find More Posts by Sluf7
Sluf7's Avatar
New Zealand, Taranaki, Midhirst
Joined Feb 1999
Superb mate Superb.
Sluf7 is offline Find More Posts by Sluf7
Old Feb 18, 2008, 01:06 AM
AMA 670207
Joined Oct 2000
Originally Posted by scratchnhover
Perry,
Hey Mike,
Thanks. Yes. It is 14g from SR Batteries. Nice stuff. Battery size....um....probably a 6s. Don't know yet but I'll post it when I figure it out.
Sluf,
Glad you like it!
Thanks mate.
Perry
Old Feb 18, 2008, 07:36 AM
steve1814 is offline
Find More Posts by steve1814
One cell short of a Pack
steve1814's Avatar
Good ole Smithsburg, MD
Joined Mar 2007
Perry,
Those softbores are nice. I have a set myself - well worth the money.
The beverly is coming along quite nicely, despite your handicap!
Cheers,
Steve
steve1814 is offline Find More Posts by steve1814
Old Feb 18, 2008, 08:50 AM
mountainman2442 is offline
Find More Posts by mountainman2442
Student of Ivan
mountainman2442's Avatar
El Paso, Illinois
Joined Apr 2006
Perry,
Glad your arm is getting better. Wonderful progress! I'll be sure to keep your tips about mount alignment fresh in my memory...
Since there's 4 deg "down" in relationship to the wing and the wing is set with 4 deg incidence "up", that would make the thrust line at 0 deg. Just a notation...
I had noticed the wonderfully nice lightening holes you're adding and kinda wondered how you did them. Mine would have come out somewhat like the old "die-crushed" Comet kits of the 70's. Where can one obtain a set of these softbores?
John
mountainman2442 is offline Find More Posts by mountainman2442
Old Feb 18, 2008, 09:38 AM
steve1814's Avatar
Joined Mar 2007
John
John,
I got my set from here. Enjoy (and your build is looking great too!)
Cheers,
Steve
Old Feb 18, 2008, 03:10 PM
AMA 670207
Joined Oct 2000
Originally Posted by steve1814
John,
Cheers,
Steve
That's the place!
Thanks John for the info regarding the incidence.
Old Feb 18, 2008, 03:49 PM
Sluf7 is offline
Sluf7's Avatar
Joined Feb 1999
Me had Softbores for a while now coulpe years plus well worth the folding stuff.
What ya gonna cover her with Perry just as a matter interest.
Old Feb 18, 2008, 05:42 PM
AMA 670207
Joined Oct 2000
I have lots of Doculam so I thought I would use this along with latex house paint.
Old Feb 19, 2008, 12:08 AM
AMA 670207
Joined Oct 2000
Motors up and running!
I'll fit the gearboxes and run all servos, then close her up.
Fuselage next!
Perry
Old Feb 19, 2008, 11:34 AM
Student of Ivan
El Paso, Illinois
Joined Apr 2006
Looking good Perry. Are you using the same method on the Bev's nacelles as you did on the Mars, that is, shaped foam?
John
Edit - Oh and I feel a bit like "Mr. Obvious" after looking at my plans where it says 0 deg on the thrust line....
Old Feb 19, 2008, 01:10 PM
AMA 670207
Joined Oct 2000
John
John,
No. I think I'll go back to old school and go with the plank on frame. The foam was easy to form and work with, but it has some shortcomings that make it a bad choice.
How you coming along??
Perry
Old Feb 19, 2008, 02:30 PM
Student of Ivan
El Paso, Illinois
Joined Apr 2006
What are the shortcomings of using foam? I was hoping to avoid the planking marathon...
Update should happen on my thread shortly btw.
John
Old Feb 19, 2008, 06:23 PM
AMA 670207
Joined Oct 2000
John
Well John,
First of all it dents easily. Then when you fiberglass it and paint it, be very careful which paints to use for if you even have the tiniest of pin holes in the fiberglass, it will leach into the foam and melt it away leaving a nice void under the fiberglass which will bubble if the model is left in the hot sun for a very short period of time.
Don't ask me how I know. IMO, it's not worth the aggrivation.
Perry
