Old Oct 19, 2007, 01:10 PM
Mike Palko is offline
Find More Posts by Mike Palko
Mike Palko's Avatar
Telford Pa
Joined Aug 2002
Question
anti spark
I am questioning the use of a anti spark connector in combination with a Phoenix-45HV ESC. What does the CC staff have to say? Good bad indifferent? I would like to save my $5 connectors, but if I am putting my $xxx.xx CC ESC at risk I will gladly sacrifice the connectors.
Thanks, Mike
Mike Palko is offline Find More Posts by Mike Palko
Old Oct 19, 2007, 01:30 PM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
I use a 4 ohm resistor to eliminate the spark. I use bullet connectors and have the resistor soldered to the female end so that it makes contact first. This will charge the capacitor and eliminate the spark.
I have heard that anything up to a 100 ohm resistor will work. The higher ohm ones just takes longer to charge the capacitor.
I will try to post a photo later today.
RC
RC Man is offline Find More Posts by RC Man
Old Oct 19, 2007, 01:54 PM
RC Man is offline
United States
Joined Feb 2001
Anti spark resistor Ė itís as easy as 1-2-3.
Hear are some photos.
Old Oct 19, 2007, 04:43 PM
Mike Palko's Avatar
Telford Pa
Joined Aug 2002
Thanks for the replies, but my question was in reguards to possible damage or problems created by using a anti spark connector, not how to make one (sorry for the confusion).
I realize the spark lets you know the capacitor(s) are working, and some say certain ESC's measure the voltage when plugged in. Is there any other possible complications? Am I putting my ESC at risk of being damaged or not operating properly? I see many people use the anti spark connector, but that doesn't mean it's right.
Thanks again, Mike
Old Oct 19, 2007, 05:36 PM
davecee is online now
Find More Posts by davecee
I'd rather be Flying
davecee's Avatar
Nashville, NC, USA
Joined Mar 1999
Simple solutions are the best. I love the way you've accomplished this.
Dave
davecee is online now Find More Posts by davecee
Old Oct 19, 2007, 06:20 PM
RC Man is offline
United States
Joined Feb 2001
Thanks again, Mike
I really donít like to see a spark Ė Iím always afraid it will scramble the ESCís brain. I use an anit-spark on all ESCís with more than 3s LiPo voltage.
I donít think the spark is good for the capacitors either Ė it probably shortens the life.
Patrick, any comments?
RC
Old Oct 20, 2007, 12:06 PM
Paul X is offline
Find More Posts by Paul X
Moscow, Russia
Joined May 2007
My solution works very good on 4 helis more then year.
Paul X is offline Find More Posts by Paul X
Old Oct 20, 2007, 07:27 PM
Mike Palko's Avatar
Telford Pa
Joined Aug 2002
Thanks Mike
Old Oct 22, 2007, 05:17 PM
Mike Palko's Avatar
Telford Pa
Joined Aug 2002
Well, with no response and only more examples of how it is done, I have to assume they cause zero problems. Thanks for the examples, some are very good!
Old Oct 22, 2007, 06:01 PM
Jan_B is offline
Find More Posts by Jan_B
Therwil, BL, Switzerland
Joined Nov 2006
One potential problem I saw mentioned is that the Auto-Lipo mode won't work with a resistor but I guess most users who worry about sparks set the cutoff voltage themselves. There might be other problems so an official explanation would be welcome.
(I don't use any anti spark method so far as the spark is small at 3s and there is a lot of metal to vaporize on 4 mm plugs before it will affect conductance.)
Jan_B is offline Find More Posts by Jan_B
Old Oct 22, 2007, 06:26 PM
RC Man is offline
United States
Joined Feb 2001
Auto LiPo mode works great with my setup. You probably have too much resistance. Like I said I use a 4 ohm resistor Ė what resistor do you use?
RC
Old Oct 22, 2007, 07:42 PM
Mike Palko's Avatar
Telford Pa
Joined Aug 2002
Agreed, Mike
Old Oct 23, 2007, 10:02 AM
Patrick del Castillo is offline
Find More Posts by Patrick del Castillo
Patrick del Castillo's Avatar
Olathe,KS,USA
Joined Oct 2000
We've found that a 1 ohm resistor works quite well, and allows Auto-Lipo to work correctly.
Patrick
Patrick del Castillo is offline Find More Posts by Patrick del Castillo
Old Oct 23, 2007, 12:59 PM
Tim Wolff is online now
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
While we are on the subject, does anyone have an elegant and compact anti-spark setup using Deans Ultra connectors?
Tim Wolff is online now Find More Posts by Tim Wolff
Old Oct 23, 2007, 04:48 PM
Mike Palko's Avatar
Telford Pa
Joined Aug 2002
Patrick
Thank you Patrick!
Discussion Anti Spark plug ALEX HEWSON Giant Electric Planes 10 Feb 05, 2008 08:15 AM
Discussion Resistor spec for anti spark -12S lithium desert_flyer Giant Electric Planes 4 Jun 14, 2007 11:42 AM
