Joined Oct 2007
So if you are facing forward and the heli starts to go left and backwards right? And the nose is going left. When you use rudder, think of controlling the nose. NOT the tail. It will only confuse you. Because that way, right rudder makes the tail go left and the NOSE RIGHT. So...
If your nose is going left and your helis is falling the same way, in my opinion. I would actually KEEP going left with the nose and then that way you can get the heli going forward in the direction you are falling and you then pull back on the elv. and it will level you out. You will be like 145 degrees from where you started, but it works. Just remember the nose vs. rudder though. |
Nose left and right is the preferred method of describing YAW. Left and right YAW is always in reference to the HELI's left and right. So ... no matter which way you are "seeing" the heli (tail in, tail out, inverted tail out, from the left side or right) ... a right rudder stick will always turn the nose of the heli to the helis right. "... tail is rotating counter clock wise (seen from above) ... is much simpler when said ... " if the heli is YAWing left ... " |
US and Costa Rica
Joined Dec 2004
That's what I meant. As far as "right rudder stick will always turn the heli's nose to right" let me correct you there, but I read in few places that some people setup the heli to fly the tail (so right rudder stick would turn the tail to the right). That's the reason why I tried to make it clear when I said "if your heli is setup like the big majority" Fernando |
My statement of "... right rudder stick will always turn the heli's nose to right ... " was qualified to be correct with your previous statement of " ... if your heli is setup like the big majority ...". So my statement is correct ... as long as your statement is correct. Why was the "correction" needed??? |
US and Costa Rica
Joined Dec 2004
As far as the English, I didn't mean it in a bad way
![]() I just tried to stick with the way the description was exposed, I don't fixate on the tail. Sorry I didn't get that part (the rudder stick part)My apologies, let's continue with the original subject otherwise we will end up drifting away... Fernando |
| Thread Tools | |
| Discussion Still need more practice!!! | quailbird | Aerial Photography | 11 | Oct 01, 2006 09:23 PM |
| Yippee! Eco8 Video! - some more practice | Chachin | Electric Heli Talk | 7 | Nov 29, 2003 03:34 PM |
| F5B practice Sunday June 17 San Diego!! | speedster | Electric Sailplanes | 0 | Jun 12, 2001 08:15 PM |
| F5B practice in San Diego | sneu | Electric Sailplanes | 3 | May 26, 2001 12:29 AM |
