Old Oct 17, 2007, 07:47 PM
Backwing is offline
Find More Posts by Backwing
Tri-City park flyer
Backwing's Avatar
Kennewick, WA.
Joined May 2004
Servo torque conversion kg/cm to oz.
Anyone know of a calculator online, or way to calculate converting servo torque ratings?
Some companies rate them like 1.5 kg/cm. This means nothing to me .
Backwing is offline Find More Posts by Backwing
Old Oct 17, 2007, 08:01 PM
rmteo is offline
Find More Posts by rmteo
User
Colorado
Multiply the torque (in kg/cm) by 13.88 and the result will be the equivalent in oz/in. So for your example, the torque will be about 21 oz/in. (1.5x13.88).
rmteo is offline Find More Posts by rmteo
Old Oct 17, 2007, 08:07 PM
village_idiot is offline
Find More Posts by village_idiot
Inciting Riots
village_idiot's Avatar
Joined Dec 2006
Try google, I did find one a couple months ago.
village_idiot is offline Find More Posts by village_idiot
Old Oct 17, 2007, 09:06 PM
GBR2 is offline
Find More Posts by GBR2
Stress Be Gone
GBR2's Avatar
Snohomish, WA
Joined May 2000
Try Convert 4.1 at
xxx.joshmadison.com/software
freeware, excellent convertor program for LOTs of stuff.
GBR2 is offline Find More Posts by GBR2
Old Oct 17, 2007, 09:11 PM
GBR2 is offline
Stress Be Gone
GBR2's Avatar
Snohomish, WA
Joined May 2000
Try Convert 4.1
Found at
freeware & very good, see photo
Old Oct 17, 2007, 09:44 PM
Miami Mike is offline
Find More Posts by Miami Mike
Pompano Hill Flyers
Miami Mike's Avatar
Miami Lakes, Florida, USA
Joined Mar 2003
It helps in figuring out how to do the conversion if you write the units correctly. Units written as kg/cm and oz/in imply that torque is force divided by distance, but it's not. Since torque is actually multiplied by distance (you get more leverage with a longer arm), the correct units are kg-cm and ounce-inches.
Since there are about 35.2734 ounces in a kilogram and 2.54 centimeters in an inch, the correct conversion factor is 35.2734 / 2.54 = 13.88 ounce-inches/kg-cm, as rmteo said.
Miami Mike is offline Find More Posts by Miami Mike
Old Oct 17, 2007, 10:14 PM
fhhuber506771 is offline
Find More Posts by fhhuber506771
Deletedfor proving Nauga wrong
Joined Mar 2005
you could also just look at the ratings of Hitec servos on their website... They list In-oz and kg-cm.
fhhuber506771 is offline Find More Posts by fhhuber506771
Old Oct 18, 2007, 04:23 AM
MarkusN is offline
Find More Posts by MarkusN
Joined Jun 2007
Or the US could finally go metric... *ducks*
(Not that kgcm for torque is very metric...)
MarkusN is offline Find More Posts by MarkusN
Old Oct 18, 2007, 06:21 AM
Pompano Hill Flyers
Miami Mike's Avatar
Joined Mar 2003
Why is it not very metric?
Old Oct 18, 2007, 07:15 AM
MarkusN is offline
Joined Jun 2007
It is metric, but it's not the correct unit for torque. kg is mass, not force. Force would be N.
I probably should have said that it's not very "SI".
Old Oct 18, 2007, 07:22 AM
Ralph Weaver is offline
Find More Posts by Ralph Weaver
Ralph Weaver's Avatar
Indianapolis, IN USA
Joined Nov 2000
Just type "2 kg/cm to oz/in" in the Google search box and you'll get the answer.
Ralph Weaver is offline Find More Posts by Ralph Weaver
Old Oct 18, 2007, 07:30 AM
MarkusN is offline
Joined Jun 2007
Nifty! But then, definitely use the correct units, i.e. kg cm and oz in!
Old Oct 18, 2007, 05:52 PM
Backwing is offline
Tri-City park flyer
Backwing's Avatar
Kennewick, WA.
Joined May 2004
Thanks for the info.
Looking at the Hitec servo numbers would help... if I was looking to get Hitec servos.
Old Oct 18, 2007, 06:15 PM
Pompano Hill Flyers
Miami Mike's Avatar
Joined Mar 2003
Right, Markus. If you use Ralph's method you'll get the answer "2 (kg / cm) = 179.191727 oz / in", which is technically correct but has nothing to do with torque. I'm not sure what sort of quantity is represented by force divided by distance, but Google doesn't seem to care.
The correct answer for torque, which Google gives for your expression, is "2 (kg cm) = 27.7747732 oz in"
If you substitute Backwing's value of 1.5, you get "1.5 (kg cm) = 20.8310799 oz in"
Help! Convert kg/cm to oz/in yukondog Radios 7 Apr 02, 2006 04:24 AM
Force on Control Surfaces, Servo Torque Reqmts green66 Electric Sailplanes 2 Mar 10, 2002 05:29 PM
Where is servo torque calculated from? Jim McPherson Power Systems 2 Oct 17, 2001 10:54 AM
Formula for figuring out servo torque? Foxtrot Electric Plane Talk 2 Jun 15, 2001 04:19 PM
Servo torque calculator? jrb Electric Plane Talk 3 Jun 07, 2001 10:28 AM
