Old Oct 17, 2007, 05:03 PM
MrMel is offline
Find More Posts by MrMel
Electric Helis is my game
MrMel's Avatar
Lidingo, Sweden
Joined Feb 2005
Crashed with Spektrum, Unknown cause.
Was tuning my engine in my Stratus today.
Setup is:
14MZ with Spektrum Module
AR7000
Arizona regulator with 5200mah battery.
I actually did a range check today (usually never does anymore hmm..)
Everthing checked out fine.
Tuned the engine during first tank, was about 400-500 feet from me as maximum without any issues.
Second tank, Battery checker read 7.35v under 1.5amp load (8-ball checker)
Mid tank was hovering about 60 feet out, did a punchout at normal mode, and engine & receiver went to failsafe, heli tilted and dropped out of the sky, I had no control.
It went in sideways, landed fairly close to me.
I went directly to it and checked radio, everything responded perfectly right away, didnt reset or anything.
Checked all cables, everthing is inplace as it should.
I benchtested the regulator by stalling the servo and putting up to 9 amp load on the regulator, it still supplied good voltage.
Back home I doublechecked the RX battery, it was 75% full.
Checked the antenna, module & trainer cable, everything is perfectly secure.
So, RX went in to failsafe, but why!?
Bad RX?
Bad reg/battery?
Ideas are welcome
Should add that I have hundres of success flights with this heli before it went down.
- Fredrik
MrMel is offline Find More Posts by MrMel
Old Oct 18, 2007, 12:57 AM
ozace is offline
Find More Posts by ozace
Renewed interest
ozace's Avatar
Melbourne , Australia
Joined Jun 2002
Sorry to hear Fredrik, i had issues with one of my machines. It turned out to be the Arizona not up to the task. The Arizona is rated to 17 watts only, something my heli could do sitting on the bench. It would work for a while then heat up and voltage would dump causing resets or dancing servos. shortly after stopping the motor it would cool enough to look as thou it was working fine.
I do hope you get ot the bottom of this , there is nothing more annoying that an undiagnosed issue.
ozace is offline Find More Posts by ozace
Old Oct 18, 2007, 01:32 AM
MrMel is offline
MrMel's Avatar
Lidingo, Sweden
Joined Feb 2005
Still thats 2.3amps, plus when this was happening it was 10C outside, I was flying with canopy off so airflow was supergreat, it was pretty high winds.
Old Oct 18, 2007, 09:48 AM
IFO FLYER is offline
Find More Posts by IFO FLYER
IFO FLYER's Avatar
Joined Mar 2004
A friend was flying with a Futaba on frequency 32 yesterday and for no apparent reason it went out of control and crashed. We checked the radio after the crash and everything worked. So any make radio can have unexplained crashes not just the Spektrum radios.
IFO FLYER is offline Find More Posts by IFO FLYER
Old Oct 18, 2007, 12:10 PM
no stick is offline
Find More Posts by no stick
Ohio
Joined May 2003
I consider myself very good at soldering, but my last two "crashes" were due to "cold" solder joints on my battery connectors. Seems like I'm in a hurry and am too concerned about getting a short even though one pin is covered with shrink wrap. I discovered this by wiggling the battery connector when it was connected to the ESC and/or Rx. The servos would jump and if long enough the system would go to fail-safe as in loss of signal. I pulled the heat shrink off and the wire could be pulled apart from the connector pin. Now when I solder the connector pins to the battery wire I make sure they cannot be pulled apart prior to heat shrink.
There are many reasons for crashes but few are ever fully explained.
Hope you solve it.
Ed
no stick is offline Find More Posts by no stick
Old Oct 18, 2007, 12:25 PM
ekotil is offline
Find More Posts by ekotil
ekotil's Avatar
Athens, Texas, United States
Joined Jul 2004
I am flying 33 planes and 2 heli's on 2 DX7's and have had ZERO problems!
ekotil is offline Find More Posts by ekotil
Old Oct 18, 2007, 12:32 PM
MrMel is offline
MrMel's Avatar
Lidingo, Sweden
Joined Feb 2005
and Ive flown thousands of flights with DX7, 14MZ/Spektrum without problem.
Until now.
I gonna check and re-check all connectors
Old Oct 18, 2007, 03:33 PM
mongo is offline
Find More Posts by mongo
mongo's Avatar
midland, REPUBLIC of TEXAS
Joined Mar 2002
mongo is offline Find More Posts by mongo
Old Oct 18, 2007, 03:42 PM
MrMel is offline
MrMel's Avatar
Lidingo, Sweden
Joined Feb 2005
Yep, hundreds upon hundred of flights.
Nope
Nope
Nope
Nope
Nope
Old Oct 18, 2007, 04:32 PM
canavanbob is offline
Find More Posts by canavanbob
canavanbob's Avatar
CA
Joined Feb 2004
Where is Paul? Why are Spektrum units causing so many crashes?
canavanbob is offline Find More Posts by canavanbob
Careful! First glitch with Spektrum DX6 system thanhTran Micro Helis 29 Mar 21, 2007 03:34 AM
Question Anyone familiar with the Spektrum DX3 2.4GHz radio? SlowDriver Car Talk 3 Jan 27, 2006 09:37 AM
Sold corona 120 rtf never crashed with upgrades 007 Aircraft - Electric - Helis (FS/W) 0 Jan 11, 2006 04:09 PM
futaba gyros with hs 55 cause interferance!!!! Philpops Micro Helis 17 Mar 03, 2005 01:06 AM
Skycat crashed with Video, and Vermont Belle 1300 wing broken. A bad day.... Patrick Plawner Electric Plane Talk 13 Mar 13, 2003 03:25 PM
