Old Oct 17, 2007, 08:43 AM
skiinxs is offline
Find More Posts by skiinxs
Joined Jan 2005
Question
Prop pitch vs diameter
Running a Graupner 13x7 folder and drawing approx 204Watts (19amps). Motor (Hacker A30-12L) is good to 25 amp continuous and my ESC is good for 36 amps continuous. Using a 3S 11.1V 2100mah (15Cdischarge) lipo. Plane (Cularis) weighs 3pounds 6ounces and I would like to get closer to the 25 amp draw. Should I go to a 13X8 or a 14X7 or even a 12X9 propeller? This is a glider so not looking for speed but rather the ability to climb better. I am not sure of the relationship between dia and pitch. I think one is related to plane speed and one is more for thrust? Appreciate any suggestions.
Pat
skiinxs is offline Find More Posts by skiinxs
Old Oct 17, 2007, 11:34 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
Better climb needs more thrust.
Roughly speaking -
more diameter = more thrust
more pitch = more speed
But if you're already at 19A a 14" prop might be too much. I'd fly it as it is.
Steve
slipstick is offline Find More Posts by slipstick
Question Prop pitch vs. size vs. more blades zippogeek Electric Plane Talk 43 May 03, 2016 08:27 AM
Discussion Prop Pitch vs the dreaded "stall, spin, crash" syndrome ken_keeler Electric Plane Talk 10 Jul 21, 2006 11:05 AM
prop rpm vs. static thrust/pitch speed opualuan Power Systems 2 Feb 19, 2002 07:48 AM
Prop Pitch and Diameter aucklajc Power Systems 3 Nov 24, 2001 03:04 PM
