Chrome/Metal Finishes - Chrome Spray Cans & Durability
Hi all... I've gotten myself into a frustrating situation! I'm currently assembling a Hangar9 Sopwith Camel and have gone through the process of de-glossing the film and airbrushing the film work and sealing with polyurethane. I didn't think much of the silver finish Hangar9 have tried to pass off as the metal work so I wanted to do something to make it look more like real metal.
My first thought was to try and use some .15 litho printing plates (I work for a printing company so easy to access) but it would take considerable work which I don't think I'm capable of to get all of the compound curves for the Camel. Next thought was to try chrome sprays. I brought a cheapy can from local hardware shop and tried that. After 4 days drying the finish is really nasty... looks perfect, but as soon as you touch it it leaves fingerprints and any chemical that hits it disolves it, i.e. metho, oil, nitro etc... I then brought a decent brand can of Chrome paint - VHT Chrome Plate Finish (http://www.vhtpaint.com/products/sfI.../productID/140) to try out. Being an epoxy resin with metallic flakes I figured it ought to do the job fine considering epoxy is glow fuel proof. After some test runs with this stuff and seems to behave the same as the cheap chrome spray. Albeit, it looks much better but doesn't hold up well, even touching it leaves smears and marks 3 days after spraying it. Glow fuel just disolves it right off. Has anyone had any experience with these sorts of products? Or perhaps someone could shed some light on different techniques of obtaining a metallic looking finish that's durable and glow fuel proof? Thanks for any help. Carl. |
Looks like I've found the method I'll use anyway... I tried running some 30 minute epoxy watered down with metho 50:50 through the airbrush onto a test sheet sprayed with the Plasti-Kote Brilliant Chrome and it didn't tarnish or damage chrome finish and put a nice even slight glossy coat over it. After letting it dry over night it hardened up nicely and has put a nice clear coating over it and seems to hold well and doesn't scratch or crack (yet). So with that result, I proceeded to airbrush some epoxy onto the cowl as a test, did a fairly heavy coating due to the abuse cowls are normally subject too and it looks nice. It's lost some of the initial lustre quality of the dull finish but it's still leagues better then the original H9 silver/grey finish. Original H9 silver: http://www.hangar-9.com/ProdInfo/Gal...t-and-guns.jpg Plasti-Kote Brillian Chrome finish (minus epoxy coating): http://aztec.riverland.net.au/boehm/...rbrushed01.jpg http://aztec.riverland.net.au/boehm/...rbrushed02.jpg http://aztec.riverland.net.au/boehm/...rbrushed03.jpg Thanks again for all your help Maggie. It has been much appreciated. Carl. |
That looks well good Carl, i like using airbrushes and have quite a few from paasche turbo's to badgers and old industrial types that were used in the ceramics trade as i am, in the bourgeois term, an 'artist'
I love fiddling with different carriers and solvents and paints as you get unique effects, i think your Camel has a realistic scale effect, as, if you viewed the full size from a distance it would grey out, which is why many models, even though the exact colour is used, look wrong. Now you have the base metal fixed, you can go to work on it with subtle stuff, like stone chips, tool scrapes and bird droppings Maggie. |
Joined Jul 2005
I tried Pactra and Testor's tries at chrome in a can.
The testor's black label came out best, but not perfect, but not as low as Good either. Both had a silver, layered look to them. I had to apply a dust, then a color coat, and then a third caked on coat. The last being most scary, for the paint tends to run a bit, even in our Palm Springs heat of the summer. I knew it to be subject to scratches, so oversprayed two days later on with some Urethane obtained from an auto paint store. Scary here too, for I feared it would dull, but no. Wm. |
| Thread Tools | |
| Question Spray cans foam safe paint? | redtail | Foamy EDFs | 8 | Aug 01, 2007 05:31 AM |
| Discussion Airbrush or Spray Cans | fly4fun | Electric Plane Talk | 26 | Oct 04, 2006 10:46 PM |
