Old Oct 16, 2007, 10:18 AM
Jim K. is offline
Find More Posts by Jim K.
Jim K.'s Avatar
Chicago, IL
Joined Aug 2006
Large Snow Skis
As you can see from my avatar, I have DuBro snow skis on my 54" EZ.
I surfed around for some larger snow skis for a Rascal 110, and cannot find anything.
Surely there are guys on this forum that have seen snow skis on a large plane, so if you are one of them, please offer your input.
Jim
Jim K. is offline Find More Posts by Jim K.
Old Oct 16, 2007, 11:46 AM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
These are great: http://hometown.aol.com/maidenusammp.../business.html !
Have several pair.
jrb is offline Find More Posts by jrb
Old Oct 16, 2007, 01:27 PM
JWilliams2 is offline
Find More Posts by JWilliams2
JWilliams2's Avatar
NY State
Joined Jan 2007
Have you tried making your own out of foam or super-thin ply? I need some, too, but geeze they are expensive for what they are. I wonder if a kid's toy could be turned into them or something.
JWilliams2 is offline Find More Posts by JWilliams2
Old Oct 16, 2007, 02:17 PM
diver don is offline
Find More Posts by diver don
"Each Day Is A Lesson"
diver don's Avatar
Goldsboro, NC
Joined May 2004
I always walk thru the toy department looking for cheap items to cannibalize for this hobby.
And it works sometimes.
DD
diver don is offline Find More Posts by diver don
Old Oct 16, 2007, 02:20 PM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Foam & lite ply work well for park flyers; but not to good for a 60mph, 110" wingspan model that's over 12#.
Old Oct 17, 2007, 09:55 AM
Jim K. is offline
Jim K.'s Avatar
Chicago, IL
Joined Aug 2006
More ideas/links please.
Jim
Old Oct 17, 2007, 11:18 AM
GrrrAmps is offline
Find More Posts by GrrrAmps
Toothpick Maker
GrrrAmps's Avatar
NJ - Exit 6
Joined May 2005
I think I remember, back in the day, people using pieces of formica to make skis. It may be formable where if you heat it you can curl up the front end. Epoxy on brackets that mount to the axles, and a spring to pull the front of the ski up. In fact, there was an articl on making your own skis in RCM magazine a bunch of years ago that someone may have laying around.
GrrrAmps is offline Find More Posts by GrrrAmps
Old Oct 17, 2007, 09:23 PM
Jim K. is offline
Jim K.'s Avatar
Chicago, IL
Joined Aug 2006
I guess it wouldn't be all that hard to make a set. It's just that I love the DuBro's, and would like to spend my time building planes, not engineering skis.
I wish DuBro made a bigger version of their black plastic skis.
There has got to be other manufacturers out there that make em.
Old Oct 17, 2007, 11:35 PM
Digiflier is offline
Find More Posts by Digiflier
Digiflier's Avatar
Vancouver
Joined Sep 2003
I cut some skis out of a scrap piece of 4 mm coroplast. Each ski was cut as a single piece, folded and glued. A piece of thin plywood and balsa was inserted to reinforce the axle area. The first 6 flights on my 60" Great Planes ElectriCub were done with them this January. I attached an elastic band to the front to provide tension against a thin piece of nylon fishing line that was attached to the back. It works, its light, its basically free and probably is available in a variety of colours, whats not to like about that?
Digiflier is offline Find More Posts by Digiflier
Old Oct 18, 2007, 07:57 AM
JWilliams2's Avatar
NY State
Joined Jan 2007
I like it. I came upon a piece of very thin aluminum scrap at a build site (thin enough to cut with scissors), which I think could work well as a base--how well does wood slide on snow? Anyway, what you've done seems like it would work well and I may go that route instead of paying a lot for skiis. The fold at the end though--it seems low--have you had problems with the skiis digging into little mounds of snow?
I wonder if 1/8" ply, if soaked in water for a while, would bend without falling apart and keep its shape into that of a ski...
Old Oct 18, 2007, 09:47 AM
8kasl is offline
Find More Posts by 8kasl
3 mi.south of mt Blanca,CO. 2 mi. out of the town of Blanca.
Joined Mar 2006
Skies-materials,how to build and set-up on plane any size
Here's a link worth looking at.http://www.stenulson.net/rcflight/skikits.htm
8kasl is offline Find More Posts by 8kasl
Old Oct 18, 2007, 06:48 PM
Digiflier's Avatar
Vancouver
Joined Sep 2003
Yes JWilliams2, I didn't put enough up twist to the ski tips. The glue was dry by the time I noticed it. The plane has flipped on an attempted takeoff due to the skis digging into a drift. I built a set out of thinner coroplast for a smaller, parkflyer and had more curve to the ski tips. They had no problem in powdered snow.
Old Oct 20, 2007, 12:53 PM
Cary Reeves is offline
Find More Posts by Cary Reeves
On patrol.
Cary Reeves's Avatar
United States, UT, North Logan
Joined Jun 2004
8kasl: nice link, nice ski design. Any rule of thumb for sizing say for a 38" span Cub with 27" prop to back of rudder. Just eyeballing it I would say 1-1.5" wide by 6-7" long?
Cary Reeves is offline Find More Posts by Cary Reeves
Old Nov 22, 2007, 11:55 AM
Jim K. is offline
Jim K.'s Avatar
Chicago, IL
Joined Aug 2006
My new Rascal 110 is more than 9ft across.
I'm still looking for big enough snow skis.
Old Nov 22, 2007, 12:02 PM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Did you go to the site I linked above?
We use the largest size on our "9ft across" 1/4th scale Cubs!
Dubro Snow Skis Have Arrived Todd Long Parkflyers 16 Dec 23, 2009 03:42 PM
Need ome of them snow skis Burtsc Parkflyers 14 Jan 23, 2003 04:31 PM
Dubro Snow Skis Greg Covey Foamies (Kits) 12 Jan 05, 2003 08:34 AM
It's getting cold, I'm starting to think 'snow skis' William A Electric Plane Talk 16 Nov 22, 2002 02:17 PM
Snow Skis for my Rascal! Robert Hoffman Sport Planes 9 Oct 06, 2002 09:14 PM
