Old Oct 16, 2007, 07:17 AM
Island Toy is offline
Find More Posts by Island Toy
Island Toy
Hilton Head Island, SC
Joined Mar 2005
2-line fuel system with fuel dot, "T" on Saito 100
Hi Guys,
I searched but could only find references to YS pressurized system setups. I have a 2-line system with a Saito 100 and want to use a fuel dot. I have a tee but am unsure as to how the fuel delivery will go to the tank instead of the carb. Is it a "path of least resistance" thing or am I missing something here?
Mention was made on the engine forum to make it a 3-line system. I am trying to avoid that since I would have to remove much of my work to date and I cannot access the line to the carb under the cowling to "pinch" the line when fueling as was one suggestion. Any thoughts?
By the way, in the way of showing I'm even more of an idiot does anyone know how Hanger 9 plumbs their tanks. I forgot to reference it and have mounted my tank and sealed it in foam. Now I have a pink and blue line and no reference to which is which. Just trying to save a little repetitive time to take it apart to check.
Island Toy
Island Toy is offline Find More Posts by Island Toy
Old Oct 16, 2007, 08:08 AM
pettit is offline
Find More Posts by pettit
Durham, NC
Joined Jul 2002
Tee for Two
If you can close the throttle fully, (you should be able to do this because it is the safe way to stop a running engine) you may be able to get the fuel to go to the tank.
To find out which line is which, take the plane outside first.
Pump fuel into one line.
If it comes out the other, you're pumping fuel into the vent line.
If it doesn't, you're pumping fuel into the clunk line.
See why I said to take it outside?
Dick Pettit
Associate Editor
R/C REPORT Magazine
pettit is offline Find More Posts by pettit
Old Oct 16, 2007, 10:03 AM
ivanc is offline
Find More Posts by ivanc
S.A.D. member
ivanc's Avatar
United States, TX, Round Rock
Joined Dec 2004
Why do you have to cross post - http://www.rcgroups.com/forums/showthread.php?t=757632 ?
It creates confusion.
Ivan
ivanc is offline Find More Posts by ivanc
Old Oct 18, 2007, 02:35 AM
nitroshark is offline
Find More Posts by nitroshark
Permanently Banned
nitroshark's Avatar
Joined Jul 2007
why
worry about it?
nitroshark is offline Find More Posts by nitroshark
Old Oct 18, 2007, 09:28 AM
ivanc is offline
S.A.D. member
ivanc's Avatar
Joined Dec 2004
Originally Posted by nitroshark
why
worry about it?
Why quote partially when the rest of the post contains the answer?
Ivan
Rules:
Cross-posting
Posting the same content in multiple forums. Note that the moderators may choose to merge cross-posted threads or to send cross-posted threads to the Bit Bucket rather than issue a warning.
Ivan
Cline Fuel system on a Moki 2.1 Turbo442 Engines 14 Feb 20, 2008 05:19 PM
Discussion Saito 100 2-line fuel setup w/ fuel dot and "T" Island Toy Engines 12 Oct 16, 2007 02:45 PM
3 fuel line tank system chris8105 Fuel Plane Talk 6 Oct 07, 2005 10:27 AM
FS: RTF Wireless Video 1.2 GHZ 800mw system with CCD Camera and GP Antenna tradernfl Aircraft - Electric - Airplanes (FS/W) 14 Dec 31, 2004 01:21 PM
FS: RTF Wireless Video 1.2 GHZ 800mw system with CCD Camera and GP Antenna Nik-rc Aircraft - General - Radio Equipment (FS/W) 13 Jul 19, 2004 08:15 PM
