Old Dec 05, 2002, 08:59 PM
ScotY's Avatar
Joined Feb 2001
Power supply for WES Charger?
Can someone recommend a good source for an AC/DC power supply for the WES Technik lithium charger? I want this to be easily transportable and I don't need it to power anything larger than the WES charger and I do need to charge 3 cells. I found a AC/DC wall wart at Radio Shack but it was capable of only 13.5 volts OR 30 volts. Is 13.5v enough so the charger can charge 3 Kokams at 1000ma?
ScotY is offline Find More Posts by ScotY
Old Dec 06, 2002, 07:34 AM
Former bpp dude
Joined Oct 2001
From what I understand the Wes Technik charger needs approx 15-16volts to charge a 3 cell pack. Laptop A/C adapters are perfect for this and are usually rated to 3-4amps. Check out Ebay for cheap A/C adapters. You should be able to pick one up for around 20 dollars. IBM & Toshiba units work very well and have a clean output. Double check the voltage & current ratings with the seller before buying. Hope this helps
-Troy
ls77 is offline Find More Posts by ls77
Old Dec 06, 2002, 08:01 AM
Bill Glover's Avatar
Bracknell, Berks, UK
Joined Nov 2000
FWIW I just use two 12V batteries in series (giving 24V) which works fine and allows me to charge without mains supply. IIRC it's rated for up to 26V input. The minimum input voltage needed for 3 cells is covered in the instructions, think it is 15V.
Bill Glover is online now Find More Posts by Bill Glover
Old Dec 06, 2002, 12:31 PM
ScotY's Avatar
Joined Feb 2001
Can anyone confirm this?
Thanks for the info, guys!
Old Dec 06, 2002, 01:14 PM
Professional idiot
Hampshire, UK
Joined Jun 2002
I can't answer your question yet, mine is in the post as we speak.
You could mail the man himself:
walter.scholl@wes-technik.de
He writes perfect English, much better than my German and has replied very promptly to my emails.
wildpalms is offline Find More Posts by wildpalms
Old Dec 06, 2002, 04:15 PM
Joined Nov 2000
OK, back home now so can confirm (from the instruction sheet) ..
"15V or higher" is required for 3 cells, and input is 11V to 26V.
Old Jan 03, 2003, 02:10 PM
Frequent Flyer
Nowell York's Avatar
Columbus, Ohio
Joined Nov 2001
flyifo.com will solder on a 19V converter to the WES 1-2-3 charger.
Nowell York is offline Find More Posts by Nowell York
AC Power Supply for DC Charger glider34 Batteries and Chargers 8 Nov 07, 2007 02:14 PM
what spec power supply for Triton charger? Astro30 Batteries and Chargers 21 Jun 13, 2003 09:39 AM
Power supply for triton charger help ehooper Batteries and Chargers 4 Apr 14, 2003 07:23 PM
Power supply for a Dymond charger? snowman610620 Beginner Training Area (Aircraft-Electric) 1 Feb 22, 2002 09:43 AM
Power Supply for Battery Charger AstroNut Power Systems 2 Oct 13, 2001 09:53 PM
