Old Oct 15, 2007, 03:18 PM
hayabusa is offline
Find More Posts by hayabusa
hayabusa's Avatar
Joined Mar 2005
Dollar tree foamboard?
Anyone else building with this? if so, how do you make up for the size difference compared to FFF? Fan-fold is 6mm right? my sturdyboard foam is 4.5mm. I guess the main question is do you add more spars, double up for wings?
hayabusa is offline Find More Posts by hayabusa
Old Oct 15, 2007, 04:25 PM
rockin' roller is offline
Find More Posts by rockin' roller
United States, TX, Dallas
The foamboard that we get from dollartree looks to be approximately the same thickness as FFF. If you leave the thin paper layer on it is about as strong too. The paper is not nearly as heavy as the other brands of paper covered foam.
rockin' roller is offline Find More Posts by rockin' roller
Old Oct 15, 2007, 06:48 PM
hayabusa is offline
hayabusa's Avatar
Joined Mar 2005
What happens if it gets wet?(dew in the morning)
Old Oct 15, 2007, 07:10 PM
mrodgers is offline
Find More Posts by mrodgers
United States, PA, Butler
Joined Jun 2006
You cut out a new airframe from a new sheet of $1 foamboard .
mrodgers is offline Find More Posts by mrodgers
Old Oct 15, 2007, 08:24 PM
hayabusa is offline
hayabusa's Avatar
Joined Mar 2005
Old Oct 15, 2007, 08:59 PM
Foamenator is offline
Find More Posts by Foamenator
AMA 8614
Foamenator's Avatar
Northern Nevada
Joined Mar 2007
I use a lot of Readiboard from Dollartree. My experience is that you need more reinforcements at places of stress but I would definitely take the paper off. It practically doubles the weight of the piece your making. If you leave the paper on one side only, the part will curl. I also use a lot of Elmers foam board which is a more expensive but stronger. I like to trace the parts on the foam with the paper on it, cut out the piece then put a heavy coat of white glue cheapest you can find. Let it dry completely and you can peal the paper right off. You can also soak the foam in water and the paper will peal off, it's just way more messy. Experiment a little and you will get the hang of it. You can't beat the price. Bob
Foamenator is offline Find More Posts by Foamenator
Old Oct 15, 2007, 09:12 PM
Crash Hancock is offline
Find More Posts by Crash Hancock
Caster Of Pods
Crash Hancock's Avatar
Waco, Texas USA
Joined Feb 2005
Now there's an idea I would have never thought about (cheap white glue to take paper off foamboard)! I had three sheets that had been sitting in my garage for the last year and the paper pulled right off without any difficulty or harm to the foam beneath.
So if you don't wanna buy cheap white glue, you can always move to central Texas (where your garage can easily get to 120 degrees for 3-4 months a year) and then stock up on foam to store!
Great idea, Foamenator!
Crash Hancock is offline Find More Posts by Crash Hancock
Latest blog entry: TheCrashCast.com - Episode 355
Old Oct 16, 2007, 02:22 PM
I don't think the new stuff that we are getting from Dollar Tree is called "readiboard". It seems to have a very thin layer of craft paper on both sides, not the thick posterboard laminate that I have usually seen. If you leave the paper on, it is only slightly heavier than the old bluecor FFF and is quite strong for profile foamies. I have seen a couple of planes made with this stuff (paper skin left on) flying in light drizzle, and it didn't seem to harm the planes. They are still in use today. I was quite surprised.
Old Oct 16, 2007, 02:54 PM
AMA 8614
Foamenator's Avatar
Northern Nevada
Joined Mar 2007
That sounds interesting I'll keep my eye out for it. I'd love to be able to leave the paper on for some purposes. Thanks Bob
Old Oct 16, 2007, 03:48 PM
AMA 8614
Foamenator's Avatar
Northern Nevada
Joined Mar 2007
Put the glue on really heavy (heavier the better). Wipe excess off the edges because if it dries in lumps (drips) it will notch out the foam on the edges where you peel the lumps off. Bob
Old Oct 16, 2007, 05:57 PM
rLu is offline
rLu
Find More Posts by rLu
rLu
Los Angeles
Get the green color board, they are easier to peel off, at least the ones I bought anyway. I use a 2" pcv pipe to assist the peel off process.
rLu is offline Find More Posts by rLu
Old Oct 17, 2007, 10:39 AM
After looking at the label on the foamboard that I have, it does say readiboard.com,
Label Says-
FOAMBOARD - WHITE
(BAR CODE)
0 82665 30525 6
ADAMS
R.L.ADAMS Plastics, Inc.
Wyoming, Michigan 49519
www.readiboard.com
This is the stuff that seems to have a thinner and lighter paper covering which is not too heavy to leave on.
Old Oct 17, 2007, 11:11 AM
callmeishmael is offline
Find More Posts by callmeishmael
AMA 42867
callmeishmael's Avatar
Joined Nov 2003
Thanks for the tips, all. Turns out there's a Dollar Tree store four miles from me in this corner of Southern California. FFF is very hard to obtain here and Elmer's foamboard is a bit pricey. Headin' out for Dollar Tree. Maybe they'll even have some cheap white glue!
callmeishmael is offline Find More Posts by callmeishmael
Old Oct 17, 2007, 11:38 AM
segraves is online now
Find More Posts by segraves
Joined Jan 2007
Ish, FYI, Hobby Lobby has 20"x30" foamboard on sale this week for 50% off regular price.
Cheers,
Bill Segraves
segraves is online now Find More Posts by segraves
Old Oct 17, 2007, 12:46 PM
JWilliams2 is offline
Find More Posts by JWilliams2
JWilliams2's Avatar
NY State
Joined Jan 2007
Your local lowes really doesn't sell protection board III FFF and your local Home depot doesn't sell the pink FFF, for example...? Rest assured, builders are getting the stuff from somewhere!
JWilliams2 is offline Find More Posts by JWilliams2
Dollar Tree Foamies dstout Foamies (Kits) 2 Aug 22, 2005 11:18 AM
