Old Oct 14, 2007, 11:36 PM
tomhe is offline
Find More Posts by tomhe
tomhe's Avatar
Linköping, Sweden
Joined Jan 2007
Idea
6mmFlyRC Profile MiG-29 with Simple Thrust Vectoring (with plans)
Here are plans for a profile MiG-29 Fulcrum with a simple form of thrust-vectoring.
The design uses much of the same ideas as my F-22 Raptor. This construction features an openable hatch for easy access to the battery and electronics, as seen in this picture of my F-22.
This plane can be built with only tailerons, but I have drawn out markings for ailerons and rudders too. If using both ailerons and tailerons they can be coupled together for easy servo installation.
Data
Wing span: 72 cm (28.3 in)
Length: 101 cm (39.7 in)
The dimensions for the slots and notches are made for 6 mm depron. You'll have to modify those if you build in other materials.
Plans
Plans for this model in PDF, Google Sketchup, and AutoCad formats, can be downloaded from http://rc.tomhe.net/mig-29. The tiled plans should be printed centered at 100 %.
UPDATE: This model is now available as a kit from 6mmFlyRC. If you want to save some time you should order a kit from them.
UPDATE: 6mmFlyRC has put together an instruction guide with lots of pictures that guides you through the build process.
UPDATE: This plane is now also available as a kit with a power combo (motor, ESC, and propeller) from Grayson Hobby.
tomhe is offline Find More Posts by tomhe
Last edited by tomhe; May 30, 2008 at 05:48 AM. Reason: Grayson Hobby kit availability
Old Oct 15, 2007, 12:25 AM
Shadegrown is offline
Find More Posts by Shadegrown
Tampere, Finland
Joined Sep 2007
I was so happy with your F-22 design that I'm going to build this one too. Unfortunately I don't have time in near future, but maybe in next month.
Shadegrown is offline Find More Posts by Shadegrown
Old Oct 15, 2007, 06:09 AM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Tom , Great idea on simple TV...Nice drawings too...
gpw is offline Find More Posts by gpw
Old Oct 15, 2007, 01:13 PM
Frank Rys is offline
Find More Posts by Frank Rys
Frank Rys's Avatar
Monson,MA
Joined Mar 2000
I will give it a try,I will cut foam later, I will send pic's as I go, very nice plans and good size. Maybe down the road I might try a 40" WS if this is as good as the SU-27...
Frank Rys is offline Find More Posts by Frank Rys
Old Oct 15, 2007, 05:34 PM
brian94066 is offline
Find More Posts by brian94066
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
isn't all tractor style or mid mount style thrust vectoring?
i mean, think about it =P
brian94066 is offline Find More Posts by brian94066
Old Oct 15, 2007, 08:39 PM
Frank Rys's Avatar
Monson,MA
Joined Mar 2000
Well it's cut from blue foam and all the parts fit very well...now to decide what stuff to put in it and add rudders..(maybe).
Old Oct 16, 2007, 12:19 AM
tomhe is offline
tomhe's Avatar
Linköping, Sweden
Joined Jan 2007
Wow, you're fast! I've just sent my plans to a shop for laser cutting. I'm hoping that they are ready on Friday.
Old Oct 16, 2007, 12:22 AM
tomhe is offline
tomhe's Avatar
Linköping, Sweden
Joined Jan 2007
They are as long as there are control surfaces in the prop wash. Not all mid-mounted models have that.
Old Oct 16, 2007, 08:26 AM
SGTalon is offline
Find More Posts by SGTalon
SG Talon... Super Genius.
Lenox, Michigan
Joined Nov 2005
Or you could just buy this one ready to go!
http://cgi.ebay.com/ebaymotors/SU-27...QQcmdZViewItem
Holy crap! $1.5mil for a 2 seaT SU-27!!!!!!!
SGTalon is offline Find More Posts by SGTalon
Old Oct 16, 2007, 12:57 PM
Tampere, Finland
Joined Sep 2007
I've decided to make a 1/2 scale version since I have a spare 3mm depron sheet and I want to try a pocket size fighter I'm planning to use aileron/taileron linking.
I ordered following setup from UH today:
AX 1806N 2500kv motor (19g) This motor should give 30-40W
two EM 4.3g servos
Pulsar 6amp esc (6g)
Corona Synthesized Receiver 4Ch (4g)
That's 37.6g without batteries and I already have 2s 1000mAh (53g) and 750mAh (39g) LiPos
I'm aiming to 120-150g AUW. That's 4.25-5.30 oz.
Old Oct 16, 2007, 01:01 PM
tomhe is offline
tomhe's Avatar
Linköping, Sweden
Joined Jan 2007
This will be very interesting. I've also considered making a smaller plane, maybe suitable for indoor flight.
Old Oct 16, 2007, 03:23 PM
birdofplay is online now
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
SGT sounds like a bargain at $1.5M
compared to $2B for a B2 !!!
Sorry tomhe, I could'nt help myself.
Besides I'm waiting for thing to dry/setup on the F22, soooo
here is the Mig29 dxf files arrainged on 2 sheets of std sized depron.
I wont get to this one for quite sometime but ...
It's ready to cut :-)
Good luck with this design.
birdofplay is online now Find More Posts by birdofplay
Old Oct 18, 2007, 12:53 AM
Jeeper is offline
Find More Posts by Jeeper
Joined Mar 2004
I also bulded f22 and it was so great that now im building mig too
My F-22 is 50% sized version and powered with medusa 4000kv motor, 3x2 prop and 3s300mah lipo.. flying weight around 100g
But now i wan to test make mig around 70g useing 2s300mah lipo and 9g purple motor from unitedhobbies.. im also wondering to "modificate" mig 29 to su-30,33 etc.. so it means that im going to put moveing canard wing to it
So if F-22 was great doing some sick aerobatics, i can only imagine what this going to be..
Jeeper is offline Find More Posts by Jeeper
Old Oct 18, 2007, 12:56 AM
Rampage is online now
Find More Posts by Rampage
DFS#000178
Rampage's Avatar
United States, CA, Twentynine Palms
Joined Aug 2005
"Item location: Ukraine, United States"
That made me laugh.
Rampage is online now Find More Posts by Rampage
Old Oct 18, 2007, 11:01 AM
Frank Rys's Avatar
Monson,MA
Joined Mar 2000
I hope to fly it this weekend, I will need to figure out the c/g first, 4.5 oz before any R/C stuff installed, again great plans..
Build Log 6mmFlyRC Profile F-22 with Simple Thrust Vectoring tomhe Pusher Prop Jet Models 3507 Jul 21, 2016 10:29 AM
Build Log Profile F-22 with Simple Thrust Vectoring berserker Foamies (Scratchbuilt) 3 Sep 11, 2007 01:14 PM
Video Mig-29 with 2-Dimension Thrust-Vector-Control system bryan.chen Electric Plane Talk 0 Jun 25, 2006 08:21 AM
OT: Fullscale MiG-29 with thrust vectoring Kevin Cox Electric Ducted Fan Jet Talk 4 Aug 17, 2005 07:17 AM
Whoops! What Engine For Rbc Mig 29 With Mini Fan 480 MAIZOR Electric Ducted Fan Jet Talk 14 Nov 25, 2004 11:41 PM
