| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#46 | |
Also, im going to terminate in delta since i dont have the skills to terminate wye. Am i still going to get the 17oz performance, or do i have to learn wye? Did you do DLRK or LRK? Last edited by annihil8ted; Apr 10, 2009 at 01:19 AM. |
#47 |
Also, i can't seem to find the difference between DLRK and LRK.
To me, for DLRK, you do 2 poles and 2 adjacent to that. Then you do one each on the outside of the 2 pairs forming a "x". After that, you just finish the third phase. LRK is the same except you do 2 poles and its adjacent pole, then you move on to the next and do 2 poles and its adjacent pole and then you finish up doing the exact same thing. Did i miss anything? |
#48 |
Former North Coast Flyer
An extra turn will lower kV, increase kT (torque per amp) and enable a slightly more demanding propeller.
Also, termination will very much affect performance. Delta is 1.7 times faster than a WYE. It also produces 1.7 times less torque per Amp. If you're winding this motor for torque or to spin a larger prop, Delta will not work for you. |
#49 |
Thanks IBCrazy. I'm going to go with MiseryQ's wind but i need his imput.
#50 |
Like said the extra turn will slow the motor.
dLRK has all the tooth wound the wire comes out throught the teeth after the two are finished, I'll have to find timochris' tutorial when I get off my phone. LRK is good for larger motors not the 2805 from what I was told. I started a ton of threads about this when I started preparing. I also terminted Wye. Delta would require more turns plus some say Wye "tracks" better. Since your wanting to use a 6x5.5 I'm assuming your wanting speed(?). |
#51 |
I will go with 11 turns of 24 gauge and learn how to terminate wye.
MiseryQ, im assuming you did dLRK and not the regular ABCABC or LRK? Yeah i want fast and powerful motor using either a 6x4 or a 6x5.5. |
#52 |
With the tooth and magnet count you can only go dLRK or LRK.
for Wye you simply take every other wireand join them. The three left over are you leads. I forgot to look for the link and I'm back on the phone now. Search for threads started by timochris he has a lot of good tutorials. |
#53 |
thanks MiseryQ, yeah i just reread all of the threads posted on here but i guess they are a little difficult for me to follow. I'm going to use dLRK and for your motor, did you have any parallels?
I still don't get the difference between dLRK and LRK through. I've read through the posts in here about them and I still can't determine the difference. |
#54 | |
I don't know the performance difference between dLRK and LRK. I just did some searching and it appears: 1) Some places use LRK and dLRK interchangeably. 2) dLRK may offer and increase in efficiency. |
#55 |
Thanks. What i meant was did you use a single wire or did you use 2-3 in parallel?
OK finally, i got enough info to start winding. |
#56 |
Single strand 24awg, 11turns on the 2805.
#57 |
Thank you for being patient with me. Ill report back when i finish winding and give periodic reports in between.
#58 |
correct me but are there 2 types of FC2805?
from what i have gathered, there is CF2805 and 2 types of FC2805 both the CF2805 and the FC2805 have 2800kv but the other FC2805 has a kv of 1600. Are my eyes deceiving me?http://www.hobbycity.com/hobbycity/s...3&v=&sortlist= is it possible the motor isn't defective but i have the other one? |
#59 |
that makes no difference to your rewind.
theory is one is a delta while the other is a wye. They both have 15turns of the 3 strand of 30awg. |
#60 |
I have bought 4 of the 2805's at different times. None have a Kv of either 2800 or 2850 that they claim.I have counted 13T of wire on these and the newer motors are very questionable if used as is. This is due to the use of the black adhesive that is used for the magnets is now being used to secure the stator. They are also pressing wound stators onto the shaft.My wires were pinched on one lead.
Please check carefully before attaching an esc for this problem. As for my own testing these motors are closer to 2500kv.My 11T dlrk is 2900kv. This may explain why some are able to swing a 6x4apc on 3s. The amperage would be to high for 2800kv. Jeremy |
| Thread Tools | |
| Discussion Finally got one!!!!!!! | heligrom | Micro Helis | 21 | Apr 06, 2006 09:30 PM |
| Rave Finally got one ! | jfm18517 | Motorcycles | 3 | Dec 19, 2004 07:43 PM |
| Finally got one running (cdrom conversion) | mgdon | Power Systems | 0 | May 07, 2004 01:27 AM |
| Logo 10 I finally got one! | Allex | Electric Heli Talk | 26 | Mar 18, 2003 01:40 PM |
| I finally got one TM | Buku Gaidin | Parkflyers | 14 | Aug 14, 2002 11:32 AM |
