| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#31 |
"plane don't hurt"
i just rewound an emax cf2822 yesterday which i think is the same as the fc28-22. It was defective when i got it.. and this is my second wind.. my first was a bluewonder 1300kv. I wound it with 18 turns of 26awg wire dlrk. I have no idea what the kv on this is. How do you figure that out? i dont understand the drill test. I put the motor into my MiniMag which about 24 ounces AUW. I have not gotten a chance to fly it yet.. I hooked it up to my homemade shunt multimeter and it only registers 6-7 amps at full throttle.. that doesnt seem right. The stock motor with this gws 8040 prop should be around 12 amps. I ran it on full throttle for about a minute and does not even seem warm.
#32 |
Put the shaft of the motor in to drill with a known RPM and hold the stator stationary.
Connect a multimeter set on volts AC to two of the legs, they'll be 3 combos, Divide the RPM by the measured vol/tage and you'll get close to the kv. |
#33 | |
Sterling |
#34 | |
"plane don't hurt"
Is the RPM listed on some drills? i have no idea what rpm my drill is.
Motor lead 1 Motor lead 2 Motor lead 3 meter lead A meter lead B you would match 1A and 2B then 2A 3B then 3A 1B |
#35 |
Some drills have the RPM listed on a sticker.
I have 3 and one doesn't have a speed. Lets say the motor has the "normal" Red, Black and White wires. You'd measure across: Red - Black Red - White Black - White The leads on the multimeter makes no difference since it's AC. |
#36 |
Thanks for the quick responses. Wasn't sure how to hook this up and I didn't want to fry something.
Sterling |
#37 |
Here's the numbers I just measured with the clamp-on meter. BTW, Is badcock.net totally wrong?
No Load Current was 2.7amps at 11.80v With the APC 6x4e 23.7amps at 10.23v Apparently my Li-Po isn't holding too good(?) Badcock.net Results |
#38 |
homo ludens modellisticus
Four methods for determining Kv (Christo van der Merwe = RCG user 'Skylar')
http://www.bavaria-direct.co.za/ -> Motor building Info -> How to determine the Kv of a motor Ken Myers' article and spreadsheet: http://homepage.mac.com/kmyersefo/M1...runners.htm#KV http://homepage.mac.com/kmyersefo/Kv-Worksheet.xls Measuring Kv quick'n dirty: http://www.rcgroups.com/forums/showthread.php?t=1009271 http://www.rcgroups.com/forums/showthread.php?t=1009491 http://www.rcgroups.com/forums/showthread.php?t=983725 Vriendelijke groeten Ron
#39 |
Thanks Ron. Another of your links saved in my favorites!
Sterling |
#40 | |
That first link has a fomula I don't understand.
#41 |
I've done a little searching on this subject (not to question anyone, but because I didn't understand it also) and what I found was " The 1.41 comes from converting Volts DC (using a battery at full voltage to power a motor)and the .95 accounts for losses on the wire from the source to the motor." Apparently when using this method you initially get a higher KV figure than what the motor actually is, and the 2 divisions will give you a more realistic figure. I have no idea if this is correct or not, but I will check some of my motors (with known kv's)tomorrow after work and see what they come out as.
Sterling |
#42 |
1200/.44=2727kv
((1200/.44)/1.41)/.95=2036kv That's a big difference. It doesn't seem to add up. |
#43 |
hello, im rewinding my 2805 tonight after the poor performanc it showed. Even with a 6x5.5 on 3s, the thing was enot even pushing 10oz.
I was hoping if anyone can tell me what was the original wind. Like what gauge and how many winds and how many wires in each wind. Much appreciated. |
#44 |
IIRC the stock wind of the 2805 and the 2822 was the same: 15 turns, 3 strands of 30AWG.
i don't think it has enough ass to turn a 6x5.5. I think you'd be happy with the 11turns of 24. It spind a Graupner 5.5x4.3 with authority. Lots of thrust and good speed. I'm thinking my 2822 might not turn a 6x5.5 too good without amps getting reall high. |
#45 |
Sorry, please be patient with me, being in highschool and just starting physics this is all new to me.
If the motor can't handle the prop, wouldnt it burn up? Well i just did a test and not only was it cold, the Watt's Up meter showed that even with 5x5 APC on 3s 1500mah, amp was only 6.5. Im starting to think i got a faulty motor. |
| Thread Tools | |
| Discussion Finally got one!!!!!!! | heligrom | Micro Helis | 21 | Apr 06, 2006 09:30 PM |
| Rave Finally got one ! | jfm18517 | Motorcycles | 3 | Dec 19, 2004 07:43 PM |
| Finally got one running (cdrom conversion) | mgdon | Power Systems | 0 | May 07, 2004 01:27 AM |
| Logo 10 I finally got one! | Allex | Electric Heli Talk | 26 | Mar 18, 2003 01:40 PM |
| I finally got one TM | Buku Gaidin | Parkflyers | 14 | Aug 14, 2002 11:32 AM |
