Old Oct 12, 2007, 12:41 PM
wiredconcepts is offline
Find More Posts by wiredconcepts
Joined Dec 2004
Foam Boat Plans?????
I keep seeing people every once and a while post pics of a foam boat they built. Do plans exist for these or are people just making them up as they go? I want to build something out of depron or similar and glass it. Where can I find plans if they do exist? Thanks in advance for the help!
Kyle
wiredconcepts is offline Find More Posts by wiredconcepts
Old Oct 12, 2007, 01:10 PM
Umi_Ryuzuki is offline
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
Pretty much any plan will do, it is just a matter of the materials you use to assemble the parts.
Scroll down and look for theos "pesky free plans...."
http://www.rcgroups.com/forums/showthread.php?t=457330
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old Oct 12, 2007, 01:13 PM
CG Bob is offline
Find More Posts by CG Bob
KC8WPF
CG Bob's Avatar
Euclid, Ohio, United States
Joined Sep 2004
Some are made up as they go; others are built from plans purchased from a vendor. Some of the vendores are:
Radio Control Boat Modeler
Taubman Plans is part of Loyalhanna Dockyard, and might have plans that could be used.
The Maxam fast electric is made with cardboard folded to shape and covered in fiberglass; might be a good one to start with. The Stepped Hydro Pool Racer uses thicker insulating foam for the hull.
CG Bob is offline Find More Posts by CG Bob
Old Oct 13, 2007, 01:30 PM
towboatjoe is offline
Find More Posts by towboatjoe
River Rat
towboatjoe's Avatar
Flatwoods, KY
Joined Feb 2006
On this link http://www.towboatjoe.com/hulls.htm about half way down the page is River Bill's technique of using foam.
Regardless of what technique you use remember to use a barrier between the foam and fiberglass resin for the resin will desove the foam. most modelers use a decopage type covering using newspaper and mixture of water and white glue.
Extruded foam used in insulating homes is great and scraps can usually be picked up at construction sites for free. Stay away from the beaded type of foam. It doesn't sand well and just likes to flake off in little beads.
towboatjoe is offline Find More Posts by towboatjoe
Old Oct 13, 2007, 02:07 PM
der kapitan is offline
Find More Posts by der kapitan
"day ain't over yet-"
der kapitan's Avatar
Western N.Y. winemaking country
Joined Jun 2005
I use urethane foam, available at places dealing in refrigeration insulation. It's totally impervious to most solvents, and can be fiberglassed over without any barrier.
---and it sands nicely.
der kapitan is offline Find More Posts by der kapitan
Old Oct 16, 2007, 05:59 PM
Shaun Hendricks is offline
Find More Posts by Shaun Hendricks
3 Blades to the Wind
Shaun Hendricks's Avatar
Atascadero, California, United States
Surf board blanks...
made for fiberglassing and can be sanded to near perfection. Abundant on the web.
Shaun Hendricks is offline Find More Posts by Shaun Hendricks
Old Oct 20, 2007, 11:57 AM
ScottOram is offline
Find More Posts by ScottOram
AME2(AW) Scott D. Oram, USN
San Diego, California
Joined Aug 2005
I used Insulation Foam in a can. Rough shaped it as I sprayed, then carved and sanded it to shape. Laid the fiberglass resin and matte right on it.
See pictures here: http://s18.photobucket.com/albums/b1...t=000_0883.jpg
ScottOram is offline Find More Posts by ScottOram
Old Nov 14, 2015, 05:43 PM
circuitfxr is offline
Find More Posts by circuitfxr
Resistance is futile
circuitfxr's Avatar
United States, FL, Wildwood
Joined Jul 2005
I used standard plans made for a wood boat.
circuitfxr is offline Find More Posts by circuitfxr
Latest blog entry: Got the AM radio blues...
Old Nov 16, 2015, 03:51 AM
mfr02 is online now
Find More Posts by mfr02
Blackpool, Lancs
Joined Feb 2006
The plans, whatever their originally intended build material, tell you what shape the outside of the boat should be. What you build it from is up to you. The only bit that will be seen in use is the paint on the outside, the structure of the boat just keeps the paint the right shape.
mfr02 is online now Find More Posts by mfr02
Idea Foam Profile Plans Eplane65 Foamies (Kits) 0 Oct 12, 2003 03:26 PM
CNC Foam Cutting Plans/Etched circuit board TNR Sales Aircraft - Electric - Airplanes (FS/W) 2 Jan 07, 2003 09:45 PM
Any Interest in Foam Mooney Plans? zagisrule! Aircraft - Electric - Airplanes (FS/W) 0 Sep 16, 2002 09:25 PM
