Old Dec 04, 2002, 04:05 PM
j8m8l is offline
Find More Posts by j8m8l
Thats NOT indestructible
j8m8l's Avatar
London UK
Joined Apr 2002
Cool
RC-Cams Nav-Lights
Hi
I am planning on building this, http://rc-cam.com/navlight.htm to keep me busy during the winter holidays, but would like to make a PCB for it
This is my first time designing PCB's and was wondering if ne one out there could give me a hand
The problem i see is that there are LOADS of intercrossing wires, which would be hard/impossable to rearange into tracks
Attached is the schematic
Josh
j8m8l is offline Find More Posts by j8m8l
Old Dec 04, 2002, 05:29 PM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Ah, Well that is the PCB designers art...and believe me it took me well over a couple of years to get neat and good...
Get a sheet of paper, a rubber and a pencil, and the components you are to use, and measure each one.
Then just get going. And scrap, rub out and try again. Eventually you will come up with a layout that just has one or two bits you CAN'T link up except by using a bit of wire.
Then use a bit of wire. Or often we used to use very low value (4 ohm) resistors as links, because they were cheaper than making wire links, since they fit on the machines with all the other resistors :-)
However, you are not designing for mass production
Old Dec 05, 2002, 02:57 PM
Mr.RC-CAM is offline
Find More Posts by Mr.RC-CAM
Mr.RC-CAM's Avatar
USA
Joined Oct 2001
Hmm, you got me curious about how many circuit jumper wires would occur on a small single sided NavLight PCB. With a little bit of effort, I ended up with only two jumps. With more effort, it could probably be done with none.
Below you will see what the final board looks like. It is 1.0 inch x 1.3 inch. The A & B green traces are the two jumper wires. The S1 green traces go to the On/Off switch. Cap C2 was omitted since in this tight layout it is not needed (C1 is sufficient).
All resistors are 1/8W and will fit in the given areas without a fuss. If you find that your series LED resistor requires more than 1/8W, then use a 1/4W and stand it a bit vertical (it wont fit if it is layed flat). Note: RC-CAM's LED Calculator will tell you what size wattage is needed on your chosen LED resistor.
The board would be half the size if you went with SMT parts and double sided construction. But for "kitchen sink" etched boards, single sided is the way to go.
Regards,
MR. RC-CAM
www.rc-cam.com
Mr.RC-CAM is offline Find More Posts by Mr.RC-CAM
Old Dec 06, 2002, 01:29 AM
Mr.RC-CAM's Avatar
USA
Joined Oct 2001
I just added the PCB layout to the NavLights web page. You can download either 1X "camera ready" art (PDF file format) or industry standard Gerber CAD data.
RC-CAM
Old Dec 06, 2002, 03:06 AM
j8m8l is offline
j8m8l's Avatar
London UK
Joined Apr 2002
WOW
Mr RC, you offer quite a service
Some people would be selfish and not release the code, but not only have you given the code to the public, you have put in LOADS of extra effort
I appreciate it
So....What program did you use, and how??
Josh L
Old Dec 06, 2002, 11:46 AM
Mr.RC-CAM's Avatar
USA
Joined Oct 2001
Protel 99 SE. Expensive, but works well.
RC-CAM
Old Dec 06, 2002, 02:41 PM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Regards,
MR. RC-CAM
www.rc-cam.com
Well if you use R4 as a jumper you can get rid of the B-B link for sure..and R8 can be turned around as well to jump three tracks and eliminate A-A. In fact if you move the associated LED1 all the way round the board to near R7 its all near A anyway.
So topologically, no links are needed at all. Its just a question of careful rearrangement, and a bit of neatening up...
Old Dec 07, 2002, 02:28 AM
RMihara is offline
Find More Posts by RMihara
Aerial Shutterbug
RMihara's Avatar
San Mateo, California, United States
Joined Nov 2001
I think it's safe to say that vintage1 has, um...'vision'
-Roger
RMihara is offline Find More Posts by RMihara
Old Dec 07, 2002, 05:40 AM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
-Roger
Er - did I say something funny? Did I miss something spectacularly obvious?
When I used to do this for a living, 'no-links' was a matter of professional pride...
Confused of Cambridge...;(
Old Dec 19, 2002, 05:10 PM
Norman Adlam is offline
Find More Posts by Norman Adlam
Official Old Git!
Hampshire, UK
Joined Sep 2000
Ok, Here's my version of Rc-Cam's Navlight board and schematic.
I've included a zip file of the board and schematic files in Eagle format.
Norman Adlam is offline Find More Posts by Norman Adlam
Old Dec 19, 2002, 05:16 PM
Official Old Git!
Hampshire, UK
Joined Sep 2000
Here is a piccy of the completed board!
Old Dec 19, 2002, 05:25 PM
Official Old Git!
Hampshire, UK
Joined Sep 2000
Also here is a piccy of the completed board track layout. I have made the the board slight larger (and the tracks somewhat wider) to make it easier for home manufacture.
Hope these come out all right!
Old Dec 19, 2002, 06:10 PM
Mr.RC-CAM's Avatar
USA
Joined Oct 2001
Good work -- came out nice. What are the PCB dimensions?
Regards,
Mr. RC-CAM
Old Dec 20, 2002, 07:54 AM
Official Old Git!
Hampshire, UK
Joined Sep 2000
Hi,
My PCB is 1.25" x 1.75", but obviously could be significantly shrunk by re-doing the layout to have vertical standing resistors, and to shrink the space between the components.
Thought I'd do it the current size to help the home user.
Thanks for all your effort on providing the base for this project! Great work!
RC-Cams Nav-Lights j8m8l Parkflyers 12 Dec 08, 2002 03:54 PM
Just received my Curtek Nav. lights....... Dale Case Electric Plane Talk 78 Oct 31, 2002 11:01 PM
Just received my Curtek Nav. lights....... Dale Case Parkflyers 74 Oct 24, 2002 05:07 PM
Nav Lights on Lite Stick? camrich Parkflyers 2 Jul 14, 2001 01:47 AM
