Valley Springs, CA
Joined Jun 2006
Our club gets a discount on 15% from the LHS, so we all run 15% in our LA's and don't have any problems. As someone mentioned, you tune your engine to the fuel you're running. There could be a difference in the type of glow plug that works best with one fuel over another, but I don't have enough experience to be able to know that for sure.
Stan |
Joined Sep 2007
The person that was with me the day that i tried the fuel did some adjustments on it. He adjusted the screw with the spring on it from the carb and tried to tune it. I was running 15% in it before...and it ran perfect. He tinkered with my 10% omega for awhile and couldnt get it right. It wanted to act like it was starving for fuel. So we put 15% back in it and he tuned it perfectly in a matter of secs.
You may have either some bad fuel or a plug that can just handle 15% nitro but isn't quite hot enough for 10%. The fuel is the more likely thing though because a plug can usually handle a fair range of fuels before causing a problem. If a new plug (something like an OS 8) doesn't cure it then do what simhatus suggested and try the fuel in another engine.
Joined Sep 2007
Update...Well i went flying today, a guy had some Cool Power all synthetic fuel 10% also. We put a tank in my plane and tuned it alittle and it runs perfect. So the Casor/Synthetic 10% omega fuel is a bad bottle. We tried it several more times. I guess this is one of those rare things to watch out for. What can cause fuels to go bad? Could it be the heat from setting in the car? Could it even be the oil mixture? Anyway i bought me a bottle of the Cool Power fuel now so its all good.
| Thread Tools | |
| Dumas Hot Shot 3.5 fuel problems | rcbirk21 | Dock Talk | 3 | Aug 16, 2004 04:57 PM |
