Old Oct 10, 2007, 12:44 PM
rgoodwin is offline
Find More Posts by rgoodwin
Joined Oct 2006
Does this sound right? (Blade CP Pro motor)
I'm starting to hear some weird sounds (or what I interpret to be weird) coming from my BCPP. (See attachment)
It almost sounds like something is grinding, but I'm not sure what. It has a new mainshaft/gear, which I lubed before I put on. The gear teeth seem to be mated tightly to the pinion (assuming that's the thing poking out of the motor ). Don't know if there is such a thing as "too tight" there.
The gear doesn't appear to be rubbing against anything else, including the canopy, plastic ties, frame, etc.
It may just be normal noise, but it seems to me it didn't sound like this before, and I'm also seeing what I perceive to be shorter flight times which could also suggest undue friction.
Thank in advance for any help!!
rgoodwin is offline Find More Posts by rgoodwin
Old Oct 10, 2007, 03:00 PM
zen@lanset.com is offline
Find More Posts by zen@lanset.com
unlicensed helicopter nut
zen@lanset.com's Avatar
Berkeley, California
Joined Jan 2007
The main gear should not push hard against the motor pinion. It should just touch it, with very little or no play at the 'high spots' on the main gear and a very slight amount of play at the 'low spots'.
zen@lanset.com is offline Find More Posts by zen@lanset.com
Does this sound right? Beeping ESC, rumbling motor QuazBotch Power Systems 6 Aug 05, 2005 01:03 PM
Question does this sound right? stirlingnut Power Systems 0 Mar 12, 2005 12:50 PM
Does this sound right? irate 850 iflych52 Batteries and Chargers 3 Mar 19, 2004 02:27 AM
GWS Spitfire - does this sound right? mattski Parkflyers 10 Sep 07, 2003 07:17 PM
Does This Sound Right? Scomis Parkflyers 4 Mar 01, 2002 10:46 AM
