| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#31 |
Advanced Learner
My guess would be that it just reads it inside the logger with the hall ring sensor. I doubt they would build it so you need to rig something else up just to read the current...
#32 |
I hope not.
#33 |
Hi All,
The hall sensor is integrated inside the logger, just like with the eLogger V2. Regards, Bill for Eagle Tree |
#34 |
Hey Bill,
I noticed you have a 100 amp and 150 amp version. Will the 100 amp only handle 100 amps or does it only read up to 100 amps. The reason I ask is because my combo may pull around 100 to 105 amps. Justin |
#35 |
Hi Yellowsierra,
The 150 amp version has much heavier wire leads. I can't really recommend running more than 100 amps through the 100 amp version, so this would be at your own risk. As always, you'd want to do a bench test similar to an actual flight to verify everything. Regards, Bill, for Eagle Tree |
#36 |
Have a nice day! Kristjan
Hi!
Still no Mini USB port on logger? I have V2 logger, that I have to send back to HC, because of malfunction. At beginning all worked great, then it got mad, voltage was too hight, current 0A, everything else works ok. Will be still V2 possible to get and will old sensors work with new V3 version, because I have multi expander and two temperature sensors at home? Thank you and have a nice day! Kristjan |
#37 | |
rebel without a glue
#38 |
Hi eajohnson,
Other loggers/wattmeters on the market use a resistance shunt to measure current, which does indeed add resistance. We use a hall effects sensor to measure current, so there is essentially no resistance. The hall sensor costs us a lot more, but is worth it in my opinion. The resistance of our hall sensor is 0.00013 ohms, regardless of amperage. Regards, Bill, for Eagle Tree |
#39 | |
#40 |
Advanced Learner
What's the resistance like for the V2, then?
#41 |
Exactly the same. :-)
#42 |
Advanced Learner
I thought you said it uses a shunt resistor?
#43 |
I did not cancel my order of the V2 and received it a few days back as I needed the logger urgently. It is quite cute, the soldering work was a little shabby on the current sensor and other than a bit of recalibrating on the voltage and current measurements it seems to be working well.
Bill, is a different hall sensor chip being used on the V3 or will it be the same one that is on the V2? I recognized the chip as I have a couple of them lying in my toolbox from a past project. If a new sensor is being used would it be possible to say which chip as the datasheets would offer some useful info on expected accuracy of the hall sensor, I might still be considering buying the V3. Thank you, Bob |
#44 | |
Advanced Learner
#45 |
Hi All,
Yes, all our products use a hall sensor of one form or another. The V3's Hall sensor has somewhat improved specs, but in reality the tolerances of individual components are factored out by our per-unit calibration procedure. The increased resolution of the V3 will be more "impactful" than the sensor hardware change. Regards, Bill, for Eagle Tree |
| Thread Tools | |
| Announcing the MicroPower e-flight recorder from Eagle Tree - ONLY $69.99 | billpa | Product Announcements | 112 | Feb 06, 2007 12:07 PM |
