Old Oct 07, 2007, 03:01 PM
txcarbon is offline
Find More Posts by txcarbon
Joined Oct 2007
mixing epoxy resins
I'm building a part using a Styrofoam core and I plan to wrap it in fiberglass to strengthen it for compression before I wrap it with carbon fiber. The kit i bought for the fiber glass uses a polyester resin. Is there any issue with this bonding to the epoxy (MGS) or the metal parts attached to it?
txcarbon is offline Find More Posts by txcarbon
Old Oct 07, 2007, 04:23 PM
sporter is offline
Find More Posts by sporter
Come out swinging
sporter's Avatar
San Diego
Joined Mar 2005
I'd stay away from the polyester. If you plan on using epoxy, why not use epoxy for the entire layup?
Sean
sporter is offline Find More Posts by sporter
Old Oct 07, 2007, 04:53 PM
MarkusN is offline
Find More Posts by MarkusN
Joined Jun 2007
That, and the polyester is going to eat the EPS. (UP is thinned with styrene monomer.)
And why glass first and not CF directly? The styrofoam will be as delicate when you glass it as when you CF it.
MarkusN is offline Find More Posts by MarkusN
Old Oct 07, 2007, 05:09 PM
samotage is offline
Find More Posts by samotage
find me @samotage
samotage's Avatar
Melbourne Australia
Joined Jul 2005
...also epoxy and polyester won't stick together well + carbon won't bond with polyester.
Remember, the glass won't take any load until the carbon breaks... It's is just a "passenger" along for the ride.
samotage is offline Find More Posts by samotage
Discussion mixing epoxy ouluckydogu Beginner Training Area (Aircraft-Electric) 6 Jan 04, 2006 12:30 PM
The Perfect Free Material For Mixing Epoxy On !!! *Hurricane039* The Builders Workshop 23 Feb 14, 2005 04:12 PM
mixing epoxy with water citabria Foamies (Kits) 9 May 20, 2003 10:07 PM
Mixing Epoxy aginzu Beginner Training Area (Aircraft-Electric) 11 Sep 18, 2001 11:56 PM
