This one might help also, although I use Brantuas more,
http://www.adamone.rchomepage.com/calc_motor.htm Challenger413 |
Have a look at peakeff.com. It is probably the best site I have seen for comparing props for a given power setup.
Doug |
Cheers, Phil This program of Rod's does a pretty good job: http://www.badcock.net/cgi-bin/powertrain/propconst.cgi as does our simple one: http://www.gobrushless.com/testing/t...calculator.php |
Joined Aug 2005
I've been comparing some thrust values with different calculators and noticed that Rod Badcock's calculator follows Dr. Kiwi's charts, but their thrust values are much lower than those calculated by http://www.drivecalc.de/
For example, APC 7x5 at 7283 RPM, 50 meters altitude: thrust 222.07g with http://www.gobrushless.com/testing/t...calculator.php. thrust 228.5g with Rod Badcock's calculator http://www.badcock.net/cgi-bin/powertrain/propconst.cgi. thrust 243g with www.drivecalc.de calculator. Wonder which one is right…
Keep in mind that the variation in thrust you get from your model due to daily changes in temperature, humidity, state of battery charge, number of cycles on the battery, ESC timing advance, wear and tear on the prop, all add up to far more than 10%. -Flieslikeabeagle |
I think Rod used some of my early Tractor Stand data to generate his equations (as we did with the gobrushless calculator) - those thrust figures were perhaps 5% low for larger props, as much as 10% low with tiny props... that may be the answer! Morris M and Jay were working on an new version of the gobrushless, but I don't know what stage that is at.
Dr. Kiwi, as a man who's done a lot of prop testing, how much variation do you find between two supposedly identical props (same manufacturer and nominal prop size), say two APC 9x7.5 "E" props? -Flieslikeabeagle |
Joined Aug 2005
But I guess that the answer is on Dr Kiwi's post: Quote:
-Flieslikeabeagle |
| Thread Tools | |
| RPM Limits for HD props available? | hoppy | GWS (Grand Wing Servo) | 258 | Mar 24, 2013 03:56 PM |
| Discussion rpm/thrust figures for small props | stirlingnut | Power Systems | 4 | Dec 16, 2006 03:48 PM |
| Data Collecting data for GWS-props rpm/thrust chart | gws-rc-models.ch | GWS (Grand Wing Servo) | 2 | Aug 09, 2006 04:18 PM |
| rpm/thrust diagrams for GWS props | Jurgen Heilig | Power Systems | 5 | Oct 10, 2003 07:19 AM |
| Static thrust for stock AF 010 setup? | pullin-gs | Electric Plane Talk | 0 | Jun 06, 2001 09:02 AM |
