Go Back   RC Groups > Aircraft - Sailplanes > Slope
Old Oct 06, 2007, 03:17 AM   #1
find me @samotage
samotage's Avatar
To make it nice :)
After getting Anton's Jart looking all purdy, I have to have a nice purdy one myself. So this is a quick how to on how I make it nice.
samotage is offline Find More Posts by samotage   Reply With Quote
Old Oct 06, 2007, 03:20 AM   #2
find me @samotage
samotage's Avatar
Start with a fresh set of carbon wings, straight out of the bag and trimmed of excess phat.
Take a deep breath. They are gunna get ugly before they get pretty. It is important that beauty is more than "skin deep"
  • Name: IMG_7216.jpg
Description: Some fresshies all set to go. Some fresshies all set to go. 57.7 KB · Views: 248
  • Name: IMG_7219.jpg
Description: With the usual bellicose wriggles and bumps With the usual bellicose wriggles and bumps 41.8 KB · Views: 293
  • Name: IMG_7220.jpg
Description: And a leading edge that could be "better" And a leading edge that could be "better" 45.5 KB · Views: 319
Old Oct 06, 2007, 03:23 AM   #3
find me @samotage
samotage's Avatar
It's time to do the "block". Just 120 grit paper on a bit of wood that will start to hone the surface down. Sand along the foil, and work methodically across the surface of the wing. Soon the high spots will "wear" down - it's starting to get there.
  • Name: IMG_7224.jpg
Description: Rub along the foil in a cross cross manner. Rub along the foil in a cross cross manner. 39.9 KB · Views: 193
  • Name: IMG_7228.jpg
Description: Whence done, hand sand any remaining shiny spots. Whence done, hand sand any remaining shiny spots. 33.1 KB · Views: 218
  • Name: IMG_7231.jpg
Description: And they are now ready for the next step! And they are now ready for the next step! 53.3 KB · Views: 214
Old Oct 06, 2007, 03:27 AM   #4
find me @samotage
samotage's Avatar
Tips and edges
The tips need to be made tuff, and the leading edges to be made proper. A high phat splooge mix is made, and piped into a funky little plastic baggy.
  • Name: IMG_7234.jpg
Description: Tips routed out with the dremel Tips routed out with the dremel 50.0 KB · Views: 237
  • Name: IMG_7236.jpg
  • Name: IMG_7238.jpg
  • Name: IMG_7239.jpg
Description: Splooge down the leading edges Splooge down the leading edges 35.9 KB · Views: 266
  • Name: IMG_7240.jpg
Description: Then smoosh it about with the gloved "finger" Then smoosh it about with the gloved "finger" 40.1 KB · Views: 295
Old Oct 06, 2007, 04:01 AM   #5
Unregistered User
Indarotor's Avatar
Sam, are you painting the Mylars with a Primer instead of a "Paint"?
I would think that that would make the sanding much easier.
Indarotor is offline Find More Posts by Indarotor   Reply With Quote
Old Oct 06, 2007, 04:50 AM   #6
find me @samotage
samotage's Avatar
The mylar is painted with 2 pack white as a 2 part strategy to kill pin holes and as a distinguishing layer for the next steps. It sands just fine and it takes about 20 minutes from freshies to knocked up nasties. Though it is helpful to have this layer a little harder to sand.
Old Oct 06, 2007, 11:28 AM   #7
that's gonna hurt...
Samo, thanks for posting this, timing is good for me, wings going in bags pretty soon. What kind of filler is in the "splooge" .... micro ballons? Bottom of the wings carbonmite? And will they get similar treatment? Should I be more patient?
Bruce
blewis01 is offline Find More Posts by blewis01   Reply With Quote
Old Oct 07, 2007, 04:03 AM   #8
find me @samotage
samotage's Avatar
Satisfaction starts with a good impression. The leading edge is the first foot in the door when making those air molecules squeal with deeelight.
  • Name: IMG_7242.jpg
Description: 120 grit on the block git's 'er' done real fast.  Make sure the block rotates freely around the edge, and monitor each  pass. 120 grit on the block git's 'er' done real fast. Make sure the block rotates freely around the edge, and monitor each pass. 42.9 KB · Views: 204
  • Name: IMG_7243.jpg
  • Name: IMG_7246.jpg
Description: Sand the tips to the desired shape. Sand the tips to the desired shape. 38.0 KB · Views: 254
  • Name: IMG_7253.jpg
Description: Check the leading edges Check the leading edges 50.0 KB · Views: 239
  • Name: IMG_7256.jpg
Old Oct 07, 2007, 04:05 AM   #9
find me @samotage
samotage's Avatar
Prefered materials
Samotage prefers the following materials in various mixes to alter the physical states of epoxy. Nothing sands smoother than q-cells. Quartz spheres filled with joy and delight. Cabosil makes it "tasty"
  • Name: IMG_7289.jpg
Description: Get a box-o-Qcells at your composites store for about $25! Get a box-o-Qcells at your composites store for about $25! 68.6 KB · Views: 185
Old Oct 07, 2007, 04:09 AM   #10
find me @samotage
samotage's Avatar
2 Pack Prime Time
The $10,000 primer. This stuff is the ducks guts. Builds high, dry's fine. It is king awesome.
  • Name: IMG_7259.jpg
  • Name: IMG_7265.jpg
  • Name: IMG_7269.jpg
  • Name: IMG_7271.jpg
Old Oct 07, 2007, 04:13 AM   #11
find me @samotage
samotage's Avatar
Bench Fly
The 45 mins cure time in the hot box is time to mark, cut and prep the fuzotage for the first bench fly.
For a full carbon Jart, the mass of all parts right now is 630 grams or 22.2 ounces.
  • Name: IMG_7277.jpg
  • Name: IMG_7278.jpg
  • Name: IMG_7285.jpg
Old Oct 07, 2007, 04:16 AM   #12
find me @samotage
samotage's Avatar
...remember this?
  • Name: IMG_3731.jpg
Old Oct 07, 2007, 04:17 AM   #13
find me @samotage
samotage's Avatar
some snot goes into the spots
  • Name: IMG_7272.JPG
  • Name: IMG_7291.JPG
Old Oct 07, 2007, 08:38 AM   #14
Double Coat TimTams
nasty air molecules
Nice one Samo,
Your techniques are much appreciated; I hate those molecules!
Chris
DrFragnasty is offline Find More Posts by DrFragnasty   Reply With Quote
Old Oct 07, 2007, 11:07 AM   #15
No fuse too fat
Gold Member
slopeiron's Avatar
Originally Posted by samotage
...remember this?
Bart: I bet it's worth a million bucks.
Comic Book Guy: It is, my lad, but I will let you have it for a hundred because you remind me of me.
slopeiron is offline Find More Posts by slopeiron   Reply With Quote
Anyone make a nice EDF U-2 kit? Yoyodyne Electric Ducted Fan Jet Talk 47 Aug 04, 2004 02:34 PM
Ariane MotorGlider, make a nice E-conversion wamdue Aircraft - Electric - Airplanes (FS/W) 0 Jul 15, 2004 01:35 PM
Question Anyone make a nice electric Extra 330S? ManWithNoName Electric Plane Talk 2 May 31, 2004 12:57 AM
Hobbico Quick Field Charger and Costco 12v Power Supply/Compressor Make a Nice Combo Vomit Micro Helis 0 Apr 14, 2004 08:20 PM
I can make a nice undercambered wing, but how do i add a dihedral to it? mortonj69 Foamies (Kits) 11 May 15, 2003 07:00 PM
Congratulations SimpleM!
