Old Oct 05, 2007, 04:57 AM
nator_au is offline
Find More Posts by nator_au
RC recluse
nator_au's Avatar
Australia, NSW, Fletcher
Joined Dec 2004
Help!
brushless motor repair?
Guys,
Problem #1
Ive got a brushless outrunner motor that had a gentle impact last weekend, and pushed the shaft back through a little.
Easy fix me thinks, and loosens the grub screw, slides the shaft forward again until the surclip is flush against the the rear of the motor, and does the grub screw back up.
Problem is that the stator now seems loose.
Im thinking that the stator should be glued to the mounting plate of the motor?
Is that correct?
Ive got some permanant loctite here that would do the job. Is that OK?
Problem #2
I also have another brushless motor that smoked, is it worth trying to rewind it, or is it better to just bin it and get a new one?
Cheers.
Brett
nator_au is offline Find More Posts by nator_au
Old Oct 05, 2007, 05:38 AM
Kentucky is offline
Find More Posts by Kentucky
Registered Abuser
Kentucky's Avatar
Melbourne, Australia
Joined Apr 2004
Originally Posted by nator_au
Guys,
Problem #1
Is that correct?
Pushing the shaft back through will be made easier if you have a drill press.
The stator should be glued to the mounting plate, locite should be ok, just be aware that some glues eg. CA will eat the enamel coating on the windings.
Problem #2
It depends I suppose on what the motor is worth and if you have the time and patients to rewind. It will help if you know the number of turns and size of the orig. wire and the winding pattern. LRK or cdrom.
How many magnets and stator poles does it have?
Another thing to consider is the condition of the stator. The fried windings could have destroyed the insulation on the stator.
Cheers
Ken
Kentucky is offline Find More Posts by Kentucky
Old Oct 05, 2007, 02:58 PM
Gluggy is offline
Find More Posts by Gluggy
Leaning doesn't help
Gluggy's Avatar
Sydney
Joined Sep 2005
Hey nator, sounds like another job you just don't need. Recommendation from me...file the motor in the big round filing cabinet on the floor and lets go on line with your credit card
Gluggy is offline Find More Posts by Gluggy
Old Oct 05, 2007, 06:31 PM
nator_au is offline
RC recluse
nator_au's Avatar
Joined Dec 2004
Kentucky,
Thanks.
I glued the stator with Loctite, and its all good now. I was very careful not to get any glue on anything that shouldnt have glue on it. I guess a test run this afternoon will tell me if it was a successful repair.
And it sounds very much like too much effort to rewind the other motor.
Ill keep it for the shaft and grub screws, and order another one from UH.
Thanks again.
Gluggy,
Monday = brushless motor order day!
Alert Brushless Motor Repair Service ScubaSteve Electric Motor Design and Construction 14 Sep 04, 2007 08:53 AM
Link Brushless Motor Repair Service ScubaSteve Power Systems 1 Aug 28, 2007 06:55 PM
Discussion Hacker Brushless USA Motor Repair Form JAS Vendor Talk 5 May 24, 2004 06:30 PM
Brushless Motor Repair jeff2215 Parkflyers 4 May 15, 2003 01:58 AM
Brushless Motor Repair tizken Electric Plane Talk 4 Sep 01, 2002 09:49 AM
