Old Oct 05, 2007, 12:12 AM
Thermalin is offline
Find More Posts by Thermalin
I'm a pilot, 100 yrs too late
Thermalin's Avatar
USA, FL, Palm Harbor
Joined Jan 2005
Question
No servo movement :o( - crystal is good
This is my last shot...
I have a hitec laser 4, 750mah battery, various hitec servos. Plugging the battery directly to the receiver (8 channel dual conversion no longer in production from hitec) gives a small movement to the servos as expected.. turning on xmitter gives me nothing when sticks move. Battery in xmitter and recvr batt are charged... .plugged in correctly ...
I know the crystal is good because plugging it into another hitec reciever and using the same xmitter works the servos.
I'm assuming I have a receiver issue but looking for any last ditch advice.. Anyway I can check it somehow. The recvr was never in a crash though hasn't been used in about a year.
Thermalin is offline Find More Posts by Thermalin
Old Oct 05, 2007, 03:06 AM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Originally Posted by Thermalin
This is my last shot... I have a hitec laser 4, 750mah battery, various hitec servos. Plugging the battery directly to the receiver (8 channel dual conversion no longer in production from hitec) gives a small movement to the servos as expected.. turning on xmitter gives me nothing when sticks move. Battery in xmitter and recvr batt are charged... .plugged in correctly ... I know the crystal is good because plugging it into another Hitec receiver and using the same xmitter works the servos. I'm assuming I have a receiver issue but looking for any last ditch advice.. Anyway I can check it somehow. The recvr was never in a crash though hasn't been used in about a year. Mike
1. Is the "faulty" receiver one you have used with the same Laser 4ch TX in the past or is it 2nd hand with perhaps positive in lieu of negative shift?
2. The crystal works in "another Hitec receiver", but is it a blue tipped dual conversion crystal or an incompatible green tipped single conversion crystal?
If above do not answer your question, suggest you refer to Hitec service and repair
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline Find More Posts by A.T.
Old Oct 06, 2007, 12:35 PM
pilotpete2 is offline
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
Mike,
A warning bell just went off in my head (Don't be alarmed, I'm harmless as long as I stay on my medication )
I believe that some of the older Hitec receivers were selectable shift, a jumper plug was used to switch from negative to positive shift.
Check and make sure it is set for negative shift as you're using it with a Hitec transmitter.
Good luck,
Pete
pilotpete2 is offline Find More Posts by pilotpete2
Old Oct 06, 2007, 03:28 PM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
Errr....is "another hitec reciever" actually another DUAL CONVERSION Hitec receiver ? If it's single conversion then you have your answer. It ain't gonna work because you have the wrong type of crystal.
Steve
slipstick is offline Find More Posts by slipstick
Old Oct 07, 2007, 10:42 AM
Rodney is offline
Find More Posts by Rodney
Florida
Joined Aug 2004
If it is a dual conversion receiver, there are two crystals involved, only one removeable. That second crystal could be defective.
Rodney is offline Find More Posts by Rodney
Eclipse problem, end of stick movement yet no servo travel DaveP Hitec/Multiplex USA 2 Jul 22, 2003 01:04 PM
ECO 8 no batteries no Rx B/O or trade 50feet Aircraft - Electric - Airplanes (FS/W) 0 Apr 28, 2003 11:38 AM
Crazy max flaps(choppy servo movement)question? alvinm Parkflyers 1 Feb 25, 2003 01:18 PM
Servo City (no servo) bipeflyer Vendor Talk 4 Nov 12, 2002 08:59 AM
