Old Oct 03, 2007, 02:29 PM
boyntonstu is offline
Find More Posts by boyntonstu
Joined Apr 2007
Beep - beep - beep - beep - beep?
A United Hobbies Mag 8 25 Amp that controlled a 2409-12 brushless at 6 volts.
It is beeping and not turning.
TX is a VEX on 89 and the ESC is on RX channel 2 for a boat.
Can someone tell me what the beeps mean?
Dah dit dah dit Da da dit dah.
BoyntonStu
W3GSQ
boyntonstu is offline Find More Posts by boyntonstu
Old Oct 03, 2007, 02:47 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
I wonder what the LVC is set at - if it is set at higher than 6v the ESC won't be able to run the system at only 6v.
Are you sure the ESC is meant to be plugged into Ch 2 on the Rx - normally Ch 3 is the throttle channel.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Oct 03, 2007, 03:08 PM
bluesky123 is online now
Find More Posts by bluesky123
Crash=change of flying medium
bluesky123's Avatar
Boulder, CO
Joined May 2002
A couple more possibilities:
1) Because the throttle channel is reversed, low throttle stick generates high channel level, which switches the ESC into the programming mode.
Try reversing the throttle channel in your TX.
2) The ESC either doesn't have a BEC or the BEC is damaged, so, the receiver doesn't get power from the ESC and the ESC can't sense valid channel pulses (because the RX isn't powered!).
Try powering the RX with a small battery or try driving the ESC with a servo tester.
Good luck!
Boris
bluesky123 is online now Find More Posts by bluesky123
Old Oct 03, 2007, 03:31 PM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
It's a boat, Doc. (hey...that was a funny!)
Ennyways ( ) ch 2 would be the esc with channel one for the steering servo.
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Oct 03, 2007, 05:22 PM
Unterhausen is offline
Find More Posts by Unterhausen
5 miles from the geographical center of Pennsylvania
Joined Aug 2005
I have a stupid question, does the steering servo respond?
Unterhausen is offline Find More Posts by Unterhausen
Old Oct 03, 2007, 05:39 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
The only boats I know anything about are Maine skiffs, ocean kayaks (see my avatar - the mahogany one I built some years ago), sail boats (though my Kiwis lost the Americas Cup) and Boston Whalers. I've never seen an RC boat.
Old Oct 03, 2007, 08:28 PM
Joined Apr 2007
Here's the video boat:
Steering is achieved by rotating the prop tower with a modded TS-80 high torque continuous servo.
I designed a simple clutch to prevent burnout.
There is a pair of 6 Volt 5 AH SLA batteries.
The receiver goes directly to 6 Volts.
I can run the motor on either 6 or 12.
Today the servo works fine. A little jitter but I can adjust the TX limit, etc to get it fairly still. I tried caps and a few other ideas but I could not eliminate jitter.
The motor only ticks only a fraction of a second.
Suggestions?
BoyntonStu
Hacker Master ESC beep beep beep..... pocket rocket Power Systems 5 May 01, 2003 02:53 AM
Are all Griffin 55's supposed to beep ? Al P Power Systems 1 Apr 20, 2003 04:55 PM
Jeti ESC constant beep Red Baron 47 Electric Plane Talk 6 Jul 18, 2001 11:06 PM
My new Easy 3000 esc doesn't beep Al P Electric Plane Talk 3 Jun 15, 2001 09:27 AM
What makes motor "beep"? Steph280 Power Systems 13 May 19, 2001 11:35 AM
