This thread is privately moderated by target, who may elect to delete unwanted replies.
Old Jan 01, 2008, 02:04 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Woody-
elevator 7.5mm high rate
6mm low rate
Ailerons(at Flaps)25mm up, 11mm down (high rate)
22mm up, 9mm down low rate
Snapflap(at fuse)11mm down elevator high rate
8mm down elevator low rate
Landing Flaps- 70-75 degrees
Landing elevator- 6mm down at full flap.
I have a very small bit of rudder coupled to aileron on a switch...
I usually fly on low rates aileron and elevator. I have just added flaperon mixing to the ailerons, but have not flown the plane since, so will likely be turning down the aileron throw bit.
My CG is at 107mm.
T
target is offline Find More Posts by target
Old Feb 02, 2008, 05:49 PM
jorgenws is offline
Find More Posts by jorgenws
jorgenws
Bodo, Norway
Joined Sep 2006
what is the wingspan on your Ceres? My Ceres is a prototype bought at Viking Race 2006 and has a wingspan of about 286cm.
do you run ailerons down together with the snapflap?
how much settings do you use in launch, speed and thermal?
Jørgen
Norway
jorgenws is offline Find More Posts by jorgenws
Old Feb 02, 2008, 06:53 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
My F3F production CERES is 3050 mm in span.
I run the ailerons down with the flap on snapflap, but just a little less snapflap in the ailerons, maybe 2mm less where they are next to the flaps.
For launching camber (hand launching in F3F only) I use about 3mm of flaps down, and match that with the ailerons. Also there is just a tiny bit of down elevator at the same time.
On that same launch mode, I have maxed throws on rudder, and aileron/rudder mixing on. I run more aileron differential in this launch mode, also.
Hope that helps,
Target
Old Feb 03, 2008, 09:27 AM
jorgenws is offline
jorgenws
Bodo, Norway
Joined Sep 2006
thanks
do you use any speed setting for F3F?
Old Feb 03, 2008, 11:17 AM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
I haven't tried to use any reflex on the wing yet; the plane feels very fast with the wing section neutral.
Target
Old Aug 04, 2008, 04:20 AM
Gudmund is offline
Find More Posts by Gudmund
Joined Mar 2005
Target.
Was there any ballast included, or is this extra?
Brg
Gudmund
Gudmund is offline Find More Posts by Gudmund
Old Aug 04, 2008, 06:57 AM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
The ballast comes with the plane.
I have since re-built my first Ceres and purchased a second one to compete at the Viking Race in Slovakia later this month.
I'll post some pictures later, but I've changed the servo list to the following:
Ailerons: Airtronics 94761z's
Flaps: JR 3421's
Fuse: Airtronics 94761z's
With this setup, I have a 5-cell 1/2A pack configured like this:
-IIII
And the receiver right behind the battery, then the very short servo tray.
This leaves me space available behing the servo tray for a home-built ballast tube, which can hold 9 of the stock rectangular slugs.
T
Old Aug 05, 2008, 05:46 PM
Gudmund is offline
Joined Mar 2005
Ok, thanks.
I got mine yesterday and it`s allready finished, just bipping in the radio left:-)
But there was no ballast with mine, so I have to give Annette a mail about it.
Awsome quick build, thanks to a very complete "kit".
5-6 hours, and ready.
Everything was like a hand in the glove, and the quality is really amazing...
Good luck at the Viking Race, and thanks for a splendid buildingthread:-)
Brg
G. Malones
Old Aug 05, 2008, 08:20 PM
Gudmund is offline
Joined Mar 2005
Kickflaps, how do they do it?
On the left stick, progressively?
Courious..
Brg
Gudmund
Old Aug 06, 2008, 06:59 AM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Snapflap is programed into the up elevator, whichever stick normally actuates it.
You might want to get some help from a seasoned F3F or F3B pilot in your area before you fly the Ceres. Ceres is a great plane, but it's a bit of a thoroughbred, and won't take kindly to set up mistakes. It is great to fly and land when the radio setup is good, like many of the other top planes in the class.
Don't start with the CG aft of 107mm for instance.
Did you get the "B" or the "F" version, and where abouts are you located?
Target
Old Aug 06, 2008, 07:03 AM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Ah-ha!
I see now you are referring to landing flaps??
If so, yes, my landing setup is on the left stick proportionally. I have the flap servos setup on a "Curve", so that the flpas come in slower at first, and that way, the down elevator is relatively more at half flap than at full flap. This eliminated "Ballooning" at half flap.
Target
Old Aug 07, 2008, 09:26 AM
Gudmund is offline
Joined Mar 2005
No.. Not snap, but kickflaps.
I guess this a setup with a opton to give more flaps in the turns when needed? It`s cinda new to me, so widen my horizon here ..
I have flown the Aris and Race M F3F for two years now, so the Ceres is in the same line, but I have never used the kickflaps before.
Two weeks, a Acot in heading in my direction too.
So I don`t think i need help for setting them up, there are none issues...
Closing to the sub 38, hopefully right on track..
Old Aug 07, 2008, 02:36 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Hmmmm, I've never heard of "kickflaps"....
I guess you are on your own.
Sorry,
Target
Old Sep 12, 2008, 10:53 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
The Ceres served me well at the Viking Race in Slovakia.
I believe that the planes' strength lies in it's incredible straight line speed. Because of this, I think that it's best to set the plane up with minimal snapflap (about 4mm max) and make carving F3B style turns rather than harder tighter turns.
Even though the plane will happily make the tighter turns, some of the speed will be lost, and you'll effectively loose the planes' advantage. It's a very fast beast, that loves to be flown heavy in medium and strong conditions.
I REALLY like this plane.
An F3B version is a great weapon in very light, 3M/second slope conditions, and I have to assume it's really good for the f3B duration and distance tasks, but have no F3B experience.
Target
Old Jun 28, 2009, 01:02 AM
marillion1 is offline
Find More Posts by marillion1
Joined Nov 2008
Hi all,
would like to grab this threat out again, 'cause i did not find a complete Setup for the ceres. I will use today the setup above, but would like to know if someone tested a different setup. For example, what about thermik condition ?? Full Flaps to aileron ? aileron up by butterfly ??
greetings, Kai
marillion1 is offline Find More Posts by marillion1
Question Condor 3.2M from Soaring USA??? truestorys Sailplane Talk 3 Sep 07, 2006 06:01 AM
Discussion Anyone tried Waypoint Servos from Soaring USA? Lavawing Slope 15 Feb 24, 2006 11:20 PM
Anyone flying the Weasel from Soaring USA easy fly High Performance 8 Aug 26, 2005 05:46 PM
Feedback on Spyder Sixty from Soaring USA screamin' eagle Slope 6 Jun 13, 2005 06:31 PM
"Whisper" from soaring usa MonkeyBone Thermal 2 May 26, 2005 02:07 AM
