Old Nov 10, 2008, 11:10 PM
nioa is offline
Find More Posts by nioa
More Motors, More Fun... :-)
nioa's Avatar
Phoenix, AZ
Alternative Servo Choices for Great Planes Reactor GP/EP 3D ARF 58"?
Great review! Davidsons states that he chose to use five of the Futaba S3102 servos instead of the recommended servos listed in the manual. I think that his choice is a good choice, but it never hurts to have alternatives. I would like davidsons and others thoughts on some alternative servos from HiTec.
The attached PDF contains a list of the Futaba servos that are shown in the manual (this is indicated by being shown as "RECOMMENDED BY GP". I have also listed Hitec servos that meet the same general torque and size specs.
I didn't include the Hobbico servos listed in the manual in the table as I don't know of anyone who uses them, and I am a little suspect of their quality (they may be re-branded Futaba servos, but I don't know for sure--if they are Futaba, I would consider them, they are cheaper).
I chose the HiTec brand as I have had good luck with them and I would like to know what others think of some of the alternative servo choices that are in the table.
The table in the PDF (which lists full specs) is sorted by price first, then it is split and sorted by function. The Futaba S9650 aileron servo (L) recommended by GP is (of course) the most expensive and Davidsons choice (J) is most reasonable, but is there a good HiTec alternative? Also, for davidsons build, Servo J (a mini) is a great choice for the ailerons, but wouldn't a larger servo for the remaining elevators and rudder with its supposedly larger positioning pot(s) be more accurate?
I would love to see what aileron servo and elevator/rudder servo choices you would make if:
(1) on a budget
(2) best cost/performance ratio (I'm guessing Davidsons would say his choice of five of the Futaba S3102 (item J)),
(3) best performance.
Reply's would be most appreciated. Oh - - sorry for the PDF, RCGroups won't permit an HTML table to display the info in a table. Thanks so much in advance.
Nick
Servos listed for discussion: (In Price Order)
(A) HiTec $16.99 HS-475 Deluxe Standard BB KG
(B) HiTec $20.99 HS-225 Mighty Mini BB
(C) Futaba $24.99 S3010 Standard HD 3P HT BB
(D) HiTec $27.99 HS-225 Mighty Mini BB MG
(E) HiTec $29.99 HS-635 HT 2BB KG
(F) Futaba $34.99 S3152 Standard 3P HT
(G) Futaba $34.99 S9001 Aircraft CM BB
(H) HiTec $34.99 HS-5475 Digital Standard 2BB KG
(I) HiTec $35.99 HS-645 HT 2BB MG
(J) Futaba $39.99 S3102 Aircraft Micro 3P MG
(K) HiTec $47.99 HS-5245 Digital Mighty Mini 2BB MG
(L) Futaba $64.99 S9650 Mini CM 2BB Digital
Hobbico Servos Listed in the Reactor Manual:
(M) CS-35
(N) CS-35MG
(P) CS-64
(Q) CS-70MG
Prices are current Tower Hobbies pricing.
nioa is offline Find More Posts by nioa
Old Nov 13, 2008, 08:19 PM
davidsons is offline
Find More Posts by davidsons
davidsons's Avatar
Joined Feb 2004
nioa
The only others in your list that I have experience with are 225 MG's and 5245 MG's. Both of these would work just fine on the Reactor however you would probably want to do the case mod on the 225's (not sure if it's needed on the 5245's). If you don't, you will most likely at some point crack the servo case internally on the aileron servos due to the large ailerons....at least this is what I've heard from another Reactor owner who used 225's. The 5245's are more expensive and I have had issues in the past with 225's not centering properly however I have planes that currently use 225's. I've never had a centering issue with the 3102's. That's my 2 cents for what it's worth.
Steve
davidsons is offline Find More Posts by davidsons
Discussion Great Planes Reactor GP/EP 3D ARF .46-.70 BoneDoc Sport Planes 48 Aug 09, 2013 05:10 PM
Discussion Great Planes Reactor GP/EP!! 3Deranged 3D Flying 230 Feb 06, 2013 01:05 PM
Article Great Planes FlatOut Turmoil Turbulator 3D ARF Review mordib Electric Plane Talk 13 Jul 15, 2011 02:14 AM
Discussion Great Planes Reactor GP/EP 3D ARF .46-51,58 slagger Fuel Plane Talk 7 Feb 26, 2009 07:18 AM
For Sale Great Planes U-Can-Do 3D ARF - 46 (RTF) MailOrderGuy Aircraft - Fuel - Airplanes (FS/W) 0 May 25, 2006 09:31 PM
