Old Oct 02, 2007, 10:36 PM
CatchmyCorsair is offline
Find More Posts by CatchmyCorsair
Ohh Snapp!
CatchmyCorsair's Avatar
Joined Sep 2005
I have TWO of those cats. Just not sure which one it is.....
Good news is...now the cat can fit inside this plane next time it happens. But I may have problems with a moving CG.
CatchmyCorsair is offline Find More Posts by CatchmyCorsair
Old Oct 02, 2007, 11:07 PM
Pistolera is offline
Find More Posts by Pistolera
I got it! I got it!
Joined Mar 2006
Give Kitty enough Prozac and it won't move much
Earle
Pistolera is offline Find More Posts by Pistolera
Old Oct 02, 2007, 11:17 PM
Jeremy Sebens is offline
Find More Posts by Jeremy Sebens
United States, OR, Corvallis
Joined Aug 2005
Joining the H-stab to the fuse
My first step is to join the h-stab to the fuse. I cut out the covering from the fuse sides, lined up the stab in it's slot, and marked the edges. Next, I trimmed the covering from the center of the stab, and test fit it in the slot.
One nice thing here is that the bottom of the stab slot is sheeted - this is great - it give lots of bonding area. On the slight complaint side of the bargain, the stab slot was a bit looser than I would have liked, but the gap's not offensively large. I suppose this is why PU glue was invented, so Sumo it is for gluing the tail in.
When you use Sumo, be sure to have lots of acetone at the ready to clean up the excess foam that's sure to squeeze out of your joint.
Jeremy Sebens is offline Find More Posts by Jeremy Sebens
Old Oct 02, 2007, 11:55 PM
Joined Aug 2005
Control horns and landing gear
A few miscellaneous tasks while the stab cures...
Assembly of the landing gear is pretty straightforward - it works pretty much exactly like the Aspera gear, although it is a one-piece unit.
I also went ahead and glued in the control horns on all surfaces. These are nice phenolic horns, and my buddy Sumo is busy permanently bonding them with the surfaces.
Old Oct 03, 2007, 12:06 AM
smsgill is offline
Find More Posts by smsgill
Scott Summersgill
smsgill's Avatar
Thousand Oaks, CA
Joined Feb 2001
Very nice!
smsgill is offline Find More Posts by smsgill
Old Oct 03, 2007, 12:41 AM
Joined Aug 2005
Puttin' it all together
Next, I glued all the hinges in, and voila - we're ready for a test assembly.
The only remaining "construction" item is the tailgear. After that, it's just radio and power system installation.
Old Oct 03, 2007, 03:04 AM
Joined Aug 2005
Motor's installed
OK, got the firewall forward work done. More details on the power system later, but the motor fit like a charm.
Very good paint match on the cowl/canopy/covering...
Old Oct 03, 2007, 03:18 AM
Joined Aug 2005
Tailwheel
OK, the tailwheel is installed. It's pretty standard 3DH fare. No problems here.
Old Oct 03, 2007, 04:26 AM
Joined Aug 2005
Aileron servos and linkages
Next up, and last thing for tonight, I installed the wing servos and hooked up the aileron linkages.
My advice on putting standard servos in the wings: don't do it. It's not worth it. I ended up having to install a new hardwood rail on the aft end of the servo bay. All in all, they're in there, but it's not very pretty.
The aileron linkage is pretty straightforward. I reversed the ball link and the L-bend for this installation, as I'm using aluminum arms on the servo.
That just leaves the elevators and the rudder to finish off. Based on the hassle of upping to standard servos in the wings, I think I'll use something that fits the servo cutouts in the tail. That might set me back by a day or two, but we'll see.
Old Oct 03, 2007, 04:29 AM
Joined Aug 2005
OK, kids - that's it for today's episode. Tune in tomorrow for the final touches.
Old Oct 03, 2007, 09:08 AM
I got it! I got it!
Joined Mar 2006
OK Jeremy...it's WAY into "tomorrow"...ya done yet?
Earle
Old Oct 03, 2007, 10:48 AM
Joined Aug 2005
Funny man...
But having just woken up, I'm too sleepy to hunt you down, so I may just send the aforementioned cats to eat your planes...
Old Oct 03, 2007, 10:57 AM
blucor basher is offline
Find More Posts by blucor basher
ExtremeFlight - 3DHS - Legacy
blucor basher's Avatar
United States, TX, Tyler
Joined Jun 2003
A plague of cats on his house?
blucor basher is offline Find More Posts by blucor basher
Old Oct 03, 2007, 11:17 AM
I got it! I got it!
Joined Mar 2006
Funny man...
I got the pistol loaded ...and LOTS of ammo
Old Oct 03, 2007, 11:39 AM
Joined Aug 2005
So my sage advice for today: when Ben tells you what servo to put in a plane, just buy it and put it in. I made the mistake of thinking "I've got some nice midrange digitals around the house, and I don't mind the extra ounce or two of weight - plus, I'll get some more speed and torque".
Silly Jeremy.
Shoehorning them into the wings wasn't any fun, and I could have completely finished the plane in the time I wasted on modifying the bays to take the 3050s. I could probably modify the bays in the tail to take standards for the elvator, but the rudder tray isn't big enough for a standard, so why bother?
This airplane is designed around mini servos, and that's a wise decision on Ben's part. They didn't seem absurdly large in the servo box, but the 3050's are really a bit big for the wings. This is a larger plane than the 47", but it's still a moderately small airplane, and the mini servos are an apropriate size.
Now I will wait impatiently for my HS5245's to arrive for the tail surfaces, and will finish the plane up as soon as they arrive. Then I will start treatment for "big-servo snob disorder".
Discussion 3D Hobby Shop 55" Extra 300 SHP: sun.flyer 3D Flying 7433 Aug 27, 2010 01:08 PM
Discussion 3D Hobby Shop 47" Katana sukhoi26mx 3D Flying 1279 Jul 31, 2010 08:41 PM
Video 3D Hobby Shop 55" Extra SHP video sukhoi26mx Electric Plane Talk 7 Sep 04, 2008 07:27 PM
Article 3D Hobby Shop 55" Extra 300 SHP Review sun.flyer 3D Flying 26 Oct 09, 2007 04:15 PM
Mini-Review Build log/review of the Charger CR-2 and 3D Hobby Shop's landing gear sharky47 3D Flying 0 Jan 22, 2006 03:21 PM
