Old Oct 02, 2007, 07:26 PM
MLem is offline
Find More Posts by MLem
MLem's Avatar
USA, CA, San Francisco
Joined Jun 2003
Question
saving more planes in a flash 5x
the flash 5x limits you to save only 5 planes. anyone out there have a hack to add more planes?
thanks, mike
MLem is offline Find More Posts by MLem
Old Oct 02, 2007, 08:06 PM
fhhuber506771 is offline
Find More Posts by fhhuber506771
Deletedfor proving Nauga wrong
Joined Mar 2005
The "hack" is to buy an Optic 6... or better.
You could try setting up planes such that all the trims are centered (including sub-trims) and control directions are the same so servo reversing is not needed.
Adjust the mechanical throws to where "100%" is the desired high rate for all models... then the ones that need a low rate you'll have to compromise on.
That assumes you have some models that use Flaperons and some that use elevons and some that use no mixing for the primary 4 controls.
Before computer radios, that was basically the way to be able to fly more than one plane with one radio.
fhhuber506771 is offline Find More Posts by fhhuber506771
Old Oct 02, 2007, 11:54 PM
ZAGNUT is online now
Find More Posts by ZAGNUT
supreme being of leisure
ZAGNUT's Avatar
Tel Aviv, Israel
Joined Jul 2004
if the model memories are stored in a separate eprom and not in the MCU itself then you could probably piggyback some more ICs in place and setup a switch to toggle between them. but then how you would initialize or format the new eproms is another problem, maybe there's a hidden service menu for this??
dave
ZAGNUT is online now Find More Posts by ZAGNUT
Old Oct 03, 2007, 02:48 AM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Originally Posted by MLem
the flash 5x limits you to save only 5 planes. anyone out there have a hack to add more planes? thanks, mike
refer to "Hitec Flash 4&5 - Double Memory " under "Transmitter - FAQ - Additions, Adjustments, Clonepacs & Repairs." on my web page. However, if you do not possess reasonable soldering skills and equipment, an Optic 6 is an easy way out with more features.
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline Find More Posts by A.T.
glid mode in flash 5X, help please rcguy01 Hitec/Multiplex USA 3 May 05, 2005 08:44 PM
Question Help dial in a little exponental or setup dual rates Flash 5X Tommy D Hitec/Multiplex USA 5 Jul 15, 2004 07:50 PM
FS: Hitec Flash 5x and 555 rx in Negative shift cadconversions Aircraft - Electric - Airplanes (FS/W) 5 Feb 09, 2004 12:23 PM
Hitec Flash 5x Tx Can I Use On Glo Planes BRIANRC Radios 6 Jan 28, 2004 03:31 PM
FS Lots of stuff, Flash 5x, Estreak, Mega motor, and more!!!!! Heli Slime Aircraft - Electric - Airplanes (FS/W) 15 Oct 27, 2002 11:53 PM
