Old Dec 02, 2002, 08:52 AM
Aldur is offline
Find More Posts by Aldur
Freak Member
Aldur's Avatar
Seminole, FL
Joined Nov 2002
Graupner Monsun Build - Run down on electronics?
Getting ready to pull the trigger again on the Graupner Monsun.
I am saving money with parts already in-hand and purchasing others for lower cost than Hobby-Lobby (HL) has "packaged" with the Monsun sale page.
Here is their page:
http://www.hobby-lobby.com/monsun.htm
My list so far. Please comment freely and let me know what is goo, bad, and what you would change if anything.
#1) (1) HiTech (HT) Feather Reciever (6.7g)
#2) (1) Great Planes (GP) C-20 ESC (17g, 22A)
#3) (3) Futaba S3106 Servo (9.6g)
#4) (1) HL (GR170523) 400 Speed / Geardrive 2.33:1
#5) (1) HL (GPS09060) 9x6 prop
#6) (1) HL (GR1298) 30 mm Spinner (4mm shaft)
*** QUESTIONS:
#1 Is the feeather too light? I mean, should I step up to like the HT 555? It has better listed range, and an extra channel. Is the feeather okay here?
#3 Are the servos okay? I can get them at a good price comparitivly so I thought I would go with them. The weight, torque and speed look okay as well?
#4-#6 I could not find these parts much cheaper, so I thought I would just go with what they have on their sale page. I downloaded the manual for the Monsun and it shows a speed 600 configuration? Is anyone doing this, or is speed 400 more than enough?
# What about the prop/gear setup? Any problems or suggestions?
Thanks for all, and let me know if you have any comments.
Use the Force...
Scott
Aldur is offline Find More Posts by Aldur
Old Dec 02, 2002, 10:29 AM
Hiflyer is offline
Find More Posts by Hiflyer
TN
Joined May 2000
Aldur
The only thing that I would check carefully is the Rx. Personally I don't think that the feather has enough range for this plane. I would probably switch to a 555.
I am not sure what you downloaded re: instructions for a Monsun, but Graupner used to have a larger Monsun kit that was for glow or could be converted to electric. This larger model might have been appropriate for a geared 600. The new ARF Monsun is only suitable for geared 400 or 400 brushless sized motors. The weight of a larger motor would be far too much.
Mike Hines
Hiflyer is offline Find More Posts by Hiflyer
Old Dec 02, 2002, 12:52 PM
Aldur is offline
Freak Member
Aldur's Avatar
Seminole, FL
Joined Nov 2002
Check and thanks for the advise:
o Going with suggested 400/gearing
o Switching to HT-555 receiver
o After reading more, I am also going with suggested Jeti ESC
### New question:
What battery can I go with? In my experience a NiMH is better. How many cells? Suggested is 8, but I have seen 10 discussed here. How many Mah should I be looking for?
Thanks agian for all,
Scott
Old Dec 02, 2002, 01:31 PM
Aldur is offline
Freak Member
Aldur's Avatar
Seminole, FL
Joined Nov 2002
I found an 8 Cell NiMH 1100 maH battery on HL.com. Can I use it for the Monsun instead of the suggested 8 Cell NiCD 600 maH?
(Click, scroll down, and look for: B1100N8)
http://www.hobby-lobby.com/hydride.htm
Kwik-E down on the 2nd flight 13brv3 Sport Planes 4 Jul 22, 2002 12:53 AM
Pitching down on flap deployment Giovanni Day Electric Sailplanes 1 Jun 03, 2002 02:06 PM
Need longer run times on Virus acro d12bn Parkflyers 5 Apr 23, 2002 09:47 PM
Graupner Monsun dave_lilley Sport Planes 53 Apr 19, 2002 12:55 PM
Graupner Perdo ARF For sale on ebay pval3 Aircraft - Electric - Airplanes (FS/W) 0 Feb 17, 2002 10:07 AM
