Dec 16, 2002, 10:33 PM
Visalia, CA
Joined Apr 2002
GearBox on an IPS Motor
genebond,
The frame is 5 ounces as I remember, which is not bad to work from. The problem had been to get enough power without getting too heavy with the motor and battery pack. I began flying it with a Poly pack and loved it. It would MOVE and had a huge range of flight.
Then the Poly pack began to go south from being drained too fast. I bought a heavier ESC and ran 6 cell 600 mah NiMH packs. It was up to 10 oz, but could do ok. It did need a long straight-in approach for landing and was on the hot side on the ground.
By going back to the light weight motor and GB, I simply strapped it to the motor brace and flew 880 Polys with a little ESC. I did have to get the prop right. It flew best with a GWS 7 X 6. The AUW was 7 oz.
I have since retired the plane to Sarah's 1st Grade class. The most improved boy will get to take it home when school ends.
Roger
